1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1kVA 500W Line-Interactive UPS,
Tower, LCD, USB, 6 Outlets
MODEL NUMBER: SMX1000LCD
Highlights
Corrects under- and
overvoltages from 171V to 266V
6 C13 outlets—3 surge-only
Interactive LCD monitoring
screen
Monitoring of power conditions
via PowerAlert software
11 min. runtime at half load; 3
min. at full load
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Ideal for home/office workstations, media centers and home
entertainment systems.
Description
The SMX1000LCD SmartPro 230V 1kVA 500W Line-Interactive UPS provides battery backup and AC
power protection against blackouts, brownouts, power surges and line noise that can damage electronics
or destroy data. Ideal for backing up home/office workstations, media centers and home entertainment
systems, the SMX1000LCD switches to battery mode in milliseconds to keep your connected equipment
running long enough to save files and shut down safely with no data loss.
Featuring six C13 outlets and a C14 inlet that accepts a user-supplied AC power cord, the SMX1000LCD
has an internal battery that provides 11 minutes of support at half load and three minutes at full load. It
can also power an entry-level PC up to 60 minutes or a single DVR/VCR component up to three hours.
Three of the six outlets provide surge protection only for printers and other non-essential devices. A frontpanel LCD screen lets you configure settings and monitor operating data, such as voltage, battery and
load statuses.
Automatic voltage regulation (AVR) maintains 230V nominal output over an input range of 171V to 266V
without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents
damage. A 480-joule surge suppression rating protects your equipment from harmful power surges. With
Tripp Lite’s free downloadable PowerAlert software, SMX1000LCD enables safe unattended system
shutdown and file saves in case of a prolonged power failure.
Features
Protects Mission-Critical Equipment
● Provides fully regulated AC output for home/office workstations, media centers and home entertainment
systems
Audible alarm signals loss of utility power or overload
C14 inlet accepts user-supplied AC power cord with country-specific plug
Reliable Battery Backup
● Supports half load up to 11 min. and full load up to 3 min.
1/5
UPS
USB cable
RJ11 cable
(2) IEC-320 C13-to-C14 power
cables
Owner’s manual
Cleveland, OH 44122
United States
Powers entry-level PC up to 60 min. and a DVR/VCR component up to 3 hr.
96% line-power efficiency rating saves money in energy costs
Cold-start capability enables turn-on in battery mode during blackouts
Automatic Voltage Regulation (AVR)
● Maintains 230V nominal output over input range of 171V–266V without using battery power
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s
performance
Interactive LCD Screen
● Front-panel LCD signals voltage, battery and load statuses
Supports multiple advanced user setup and operating preferences
Rotates for easy viewing in rack-mount or tower configurations
Communications Port
● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
RJ45 Telephone/Ethernet Protection Jacks
● Protect phone/DSL/fax/modem/Ethernet network against power surges
Specifications
OVERVIEW
UPC Code
037332125927
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
Attached 15cm line cord with C14 inlet. The C14 inlet accepts user-supplied AC power cord with country specific
plug.
UPS Input Cord Length (ft.)
0.5
UPS Input Cord Length (m)
0.2
OUTPUT
Output Capacity (VA)
1000
2/5
Cleveland, OH 44122
United States
Output Capacity (kVA)
1
Output Capacity (Watts)
500
Output Capacity (kW)
0.5
Nominal Voltage Details
230V nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables
UPS Output Receptacles (Surge
Suppression Only)
3 UPS outlets, 3 surge-only outlets
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3 min. (500W)
Runtime Half Load (min.)
11 min. (250W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 20 hours from 10% to 90%
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 171
Undervoltage Correction
Input voltages between 199 and 171 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Backlighted LCD screen indicates input voltage, 5-bar battery charge level, overload, AVR, on battery and replace
battery status; LCD screen rotates for rack/tower viewing
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and overload status; alarm can be disabled using PowerAlert software
3/5
Cleveland, OH 44122
United States
LED Indicators
Front panel LCD display
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
165
Primary UPS Height (mm)
305
Primary UPS Width (mm)
89
Shipping Dimensions (hwd / in.)
6.50 x 15.50 x 11.00
Shipping Dimensions (hwd / cm)
16.51 x 39.37 x 27.94
Shipping Weight (lbs.)
15.60
Shipping Weight (kg)
7.08
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
30.48 x 8.89 x 16.51
(hwd, in.)
12 x 3.5 x 6.5
UPS Power Module Weight (kg)
7.03
UPS Power Module Weight (lbs.)
15.5
Unit Weight (lbs.)
14.6000
Unit Weight (kg)
6.62
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
Battery Mode BTU / Hr. (Full Load)
510
AC Mode Efficiency Rating (100%
Load)
96%
COMMUNICATIONS
4/5
Cleveland, OH 44122
United States
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network Management Card
Description
Network management not supported
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
171
High Voltage Transfer to Battery
Power (Setpoint)
266
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
GOST (Russia)
Product Compliance
RoHS; SASO (Saudi Arabia); CE (Europe); FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMX1000LCD”相匹配的价格&库存,您可以联系我们找货
