1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1kVA 900W Line-Interactive Sine
Wave UPS, 2U Rack/Tower, Network Card
Options, LCD, USB, DB9, 6 Outlets
MODEL NUMBER: SMX1000RT2U
Highlights
Corrects under- and
overvoltages from 182V to 278V
6 C13 outlets—4 switchable via
network interface
Network power management
and control capability
Interactive LCD monitoring
screen
11.9 min. runtime at half load;
3.6 min. at full load
Add optional WEBCARDLX with
latest version of PADM20 for IPbased Auto Probe feature
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, surges and line noise. Ideal solution for point-of-sale applications, VoIP systems and small
business networks.
Description
The SMX1000RT2U SmartPro 230V 1kVA 900W Line-Interactive Sine Wave UPS provides battery
backup and AC power protection against blackouts, brownouts, power surges and line noise that can
damage electronics or destroy data. Ideal for backing up point-of-sale applications, VoIP systems and
small business networks, the SMX1000RT2U switches to battery mode in milliseconds to keep your
connected equipment running long enough to save files and shut down safely with no data loss.
Featuring six C13 outlets (four switchable) and a C14 inlet that accepts a user-supplied AC power cord,
the SMX1000RT2U has an internal battery that provides 11.9 minutes of support at half load and 3.6
minutes at full load. A front-panel LCD screen lets you configure settings and monitor important data, such
as load level, voltage, battery charge and estimated runtimes.
Automatic voltage regulation (AVR) maintains 230V nominal output over an input range of 182V to 278V
without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents
damage. A 350-joule surge suppression rating protects your equipment from harmful power surges. With
Tripp Lite’s free downloadable PowerAlert® software, the SMX1000RT2U enables safe unattended
system shutdown and file saves in case of a prolonged power failure. Adding an optional Network
Management Card permits remote management of the UPS.
Features
Protects Mission-Critical Rack-Mounted Equipment
● Provides fully regulated sine wave AC output for point-of-sale applications, VoIP systems and small
business networks
Audible alarm signals loss of utility power, overload, low battery and fault conditions
6 C13 outlets
C14 inlet accepts user-supplied AC power cord with country-specific plug
Reliable Battery Backup
● Supports half load up to 11.9 min. and full load up to 3.6 min.
1/7
Sine Wave UPS
USB cable
DB9 cable
EPO cable
(2) IEC-320 C13-to-C14 power
cables
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Internal batteries designed for hot-swap field replacement
97% line-power efficiency rating saves money in energy costs
2 Load Banks with Switchable Outlets
● Can control 4 outlets remotely to reboot equipment or shed nonessential loads
Automatic Voltage Regulation (AVR)
● Maintains 230V nominal output over input range of 182V–278V without using battery power
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s
performance
Interactive LCD Screen
● Front-panel LCD signals voltage, battery and load statuses
Supports multiple advanced user setup and operating preferences
Rotates for easy viewing in rack-mount or tower configurations
Optional Network Management Cards
● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and
SNMPWEBCARD
Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities
PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance
functions in large installations, including firmware update checks and backup and restoration of device
configurations
IP-based Auto Probe detects lost connectivity and restores service autonomously
Communications Ports
● USB and DB9 ports enable data-saving unattended shutdown when used with Tripp Lite’s Power Alert
software (available via free download at tripplite.eaton.com/products/power-alert)
EPO port supports emergency shutdown in large facilities
Versatile Installation Options
● Hardware included for 4-post mounting in 2U of EIA-standard 19 in. rack
Mounts on wall or 2-post rack with optional 2POSTRMKITWM accessory
Mounts in upright tower position with optional 2-9USTAND accessory
Specifications
OVERVIEW
UPC Code
037332119223
UPS Type
Line-Interactive
INPUT
2/7
Cleveland, OH 44122
United States
Input Phase
Single-Phase
Rated input current (Maximum Load)
4.8A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific wall
receptacles
Input Circuit Breakers
10A
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Power Factor
0.9
Nominal Voltage Details
230V nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Line
Mode)
+6%, -11%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables
Load Management Receptacles
Two switchable two-outlet C13 load banks
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.6 min. (900W)
Runtime Half Load (min.)
11.9 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
24
3/7
Cleveland, OH 44122
United States
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
IMPORTANT BATTERY REPLACEMENT INFORMATION > If your SMX1000RT2U UPS is equipped with a LCD
front-panel screen, order Tripp Lite RBC24V-LCD (quantity 1) replacement
battery; If your SMX1000RT2U UPS is equipped with LED front-panel indicators, order Tripp Lite RBC92-2U (quantity 1) replacement battery
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 182 to 278
Overvoltage Correction
Input voltages between 244 and 278 are reduced by 12%
Undervoltage Correction
Input voltages between 182 and 206 are boosted by 12%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data,
plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for
detailed LCD configuration and monitoring options)
Switches
3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions
Alarm Cancel Operation
Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option
available
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
350
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to
914mm)
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
4/7
Cleveland, OH 44122
United States
with Optional Accessories
2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail
rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM )
Minimum Required Rack Depth (cm)
40.64
(inches)
16
Optional Mounting Accessory Notes
Optional 2-9USTAND enables upright tower UPS placement; 2POSTRMKITWM enables wall-mount and 2-post rackmount installation;
4POSTRAILKITWM enables installation in 4-post short-depth
racks from 14.5 to 23.5 inches (368 to 597mm); UPSHDEARKIT enables installation in 2 or 4-post
racks using front vertical rails only, without rear support
Primary UPS Depth (mm)
343
Primary UPS Height (mm)
89
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
8.50 x 23.10 x 18.20
Shipping Dimensions (hwd / cm)
21.59 x 58.67 x 46.23
Shipping Weight (lbs.)
45.90
Shipping Weight (kg)
20.82
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
8.89 x 44.45 x 34.29
(hwd, in.)
3.5 x 17.5 x 13.5
UPS Power Module Weight (kg)
15.42
UPS Power Module Weight (lbs.)
34
Unit Weight (lbs.)
34.0000
Unit Weight (kg)
15.42
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
100
Battery Mode BTU / Hr. (Full Load)
918
AC Mode Efficiency Rating (100%
Load)
97%
5/7
Cleveland, OH 44122
United States
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
SNMPWEBCARD; TLNETCARD ; WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
182
High Voltage Transfer to Battery
Power (Setpoint)
278
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable
batteries; Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS; Individually controllable load banks
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
GOST (Russia); IEC/EN 62040
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
6/7
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
7/7
