1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1000VA 900W Line-Interactive
Sine Wave UPS, 2U, WEBCARDLX, LCD, USB,
DB9, 6 Outlets
MODEL NUMBER: SMX1000RT2UN
Highlights
Protects equipment against
blackouts, brownouts,
overvoltages, surges and line
noise
Keeps AC power running during
blackouts to allow time for file
saves and safe shutdown
Maintains continuous 230V
nominal output during
brownouts and overvoltages
Pre-installed WEBCARDLX with
latest version of PADM20
supports Auto Probe feature
Easy-to-read LCD allows realtime monitoring of voltage,
battery status and other data
Applications
Protect your small network
server and other network
components against power
surges, line noise, brownouts,
overvoltages and blackouts
Line-interactive UPS offers complete power protection for professional applications, including retail, casino
and hotel management.
Operate essential equipment
during short-term power outages
using battery backup power
Features
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Connect high-end security
systems, casino gaming
machines or digital signage in a
small network
1kVA/900W/230V Battery Backup for PC Networks, Security Systems or Digital SignageThe
SmartPro® line-interactive SMX1000RT2UN UPS system with AVR provides reliable battery backup and
AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage
valuable electronics or destroy data. The six-outlet 230V battery backup with 0.9 power factor is ideal
protection for small networks, wiring closets, security systems, telecom, high-end PC gaming, digital
signage equipment and other professional applications, including retail, casino and hotel/motel
management.
Reliable, Expandable Battery Backup Keeps You Operational Through Power OutagesThe fieldreplaceable, hot-swappable internal battery provides 11.9 minutes of support at half load (450W) and 3.6
minutes at full load (900W), allowing you to work through short power failures and giving you enough time
to safely save files and shut down your system in case of a prolonged blackout.
Pre-Installed WEBCARDLX Network Interface Offers 24/7 Remote Access for Monitoring and
ControlThe built-in WEBCARDLX with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities, including customizable dashboard
graphs to fit user preferences. The PADM20 upgrade coincides with the introduction of New PowerAlert
Element Manager (PAEM) software. PADM20 and PAEM together form a powerful tool for expanding
maintenance functions in large installations, including firmware update checks and backup and restoration
of device configurations. WEBCARDLX also supports Auto Probe, which can prevent costly service calls
by automatically rebooting non-responsive network devices.
6 Outlets Protect Your Connected ComponentsSix C13 outlets provide battery backup, 350 joules of
surge protection and voltage regulation for your crucial components. Two independently switched twooutlet load banks enable both scheduled and real-time remote rebooting and load shedding.
Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage ConditionsAVR protects your
equipment from incremental hardware damage, data loss and performance problems caused by
brownouts and overvoltages. The SMX1000RT2UN can correct brownouts as low as 182V and
overvoltages as high as 278V back to nominal 230V power continuously, all while keeping the battery fully
charged and ready to take over in case of power failure.
1/6
Package Includes
SMX1000RT2UN 230V 1000VA
900W Line-Interactive UPS with
6 Outlets
WEBCARDLX network
management card
USB cable
DB9 cable
EPO cable
(2) C13-to-C14 AC power cords
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterThis UPS
system filters out disruptive electromagnetic and radio frequency interference that can inflict hardware
damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last
longer.
Designed for High Efficiency to Help You Save Money and Protect the EnvironmentA 97% efficiency
rating reduces BTU emissions, energy consumption and, ultimately, your energy costs.
Silenceable Alarm and Easy-to-Read LCD Keep You Informed Around the ClockThe front-panel LCD
lets you monitor important data, such as load level, power factor, voltage, battery charge and estimated
runtimes. It rotates for comfortable viewing in both rack and tower configurations. The audible alarm
sounds for power failure, low battery and overloads. You may silence it using the built-in switch or disable
it.
Advanced Communications Ports Allow for Automatic Saves and ShutdownsRS-232 and HIDcompliant USB ports connect to a computer running free downloadable PowerAlert® software to enable
safe unattended file saves and system shutdown in case of a prolonged power failure. The EPO port
supports emergency shutdown in large facilities. Cables are included.
Versatile Installation OptionsHardware is included for mounting the SmartPro UPS system in 2U of
space in an EIA-standard 19-inch 4-post rack. Using optional mounting accessories (sold separately), you
can adapt the SMX1000RT2UN for 2-post (2POSTRMKITWM), front-rail (UPSHDEARKIT), 4-post shortdepth (4POSTRAILKITWM), tower (2-9USTAND) or wall mounting (2POSTRMKITWM).
Specifications
OVERVIEW
UPC Code
037332256416
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
4.8A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
IEC320-C14 input connection accepts a variety of user supplied detachable C13 output cordsets to match country or
site-specific power sources
Input Circuit Breakers
10A
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Power Factor
0.9
Nominal Voltage Details
230V nominal output in battery mode
2/6
Cleveland, OH 44122
United States
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Line
Mode)
+6%, -11%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables
Load Management Receptacles
Two switchable two-outlet C13 load banks
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.6 min. (900W)
Runtime Half Load (min.)
11.9 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC24V-LCD (quantity 1)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 182 to 278
Overvoltage Correction
Input voltages between 244 and 278 are reduced by 12%
Undervoltage Correction
Input voltages between 182 and 206 are boosted by 12%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data,
plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for
detailed LCD configuration and monitoring options)
Switches
3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions
3/6
Cleveland, OH 44122
United States
Alarm Cancel Operation
Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option
available
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
350
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to
914mm)
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail
rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM )
Minimum Required Rack Depth (cm)
40.64
(inches)
16
Optional Mounting Accessory Notes
Optional 2-9USTAND enables upright tower UPS placement; 2POSTRMKITWM enables wall-mount and 2-post rackmount installation;
4POSTRAILKITWM enables installation in 4-post short-depth
racks from 14.5 to 23.5 inches (368 to 597mm); UPSHDEARKIT enables installation in 2 or 4-post
racks using front vertical rails only, without rear support
Primary UPS Depth (mm)
343
Primary UPS Height (mm)
89
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
8.50 x 23.10 x 18.20
Shipping Weight (kg)
20.82
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, in.)
3.5 x 17.5 x 13.5
4/6
Cleveland, OH 44122
United States
UPS Power Module Weight (kg)
15.42
UPS Power Module Weight (lbs.)
34
Unit Weight (lbs.)
34.000
Unit Weight (kg)
15.42
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
100
AC Mode Efficiency Rating (100%
Load)
97%
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
WEBCARDLXE
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card included
Communications Interface
DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID
enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
182
High Voltage Transfer to Battery
Power (Setpoint)
278
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS; Individually controllable load banks
Grounding Details
Back panel grounding lug
5/6
Cleveland, OH 44122
United States
APPLICATIONS
UPS Applications
Large Network; High-End Desktop/Small Network
STANDARDS & COMPLIANCE
Product Certifications
GOST (Russia); IEC/EN 62040
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
