1000 Eaton Boulevard
Cleveland, OH 44122
United States
208/230V 1000VA 900W Double-Conversion UPS
- 6 Outlets, Extended Run, WEBCARDLX, LCD,
USB, DB9, 2U
Highlights
Offers network-grade protection
against power failures and
voltage fluctuations
Zero transfer time between online and battery modes for
uninterrupted operation
Optional external battery packs
provide additional runtime for
applications requiring it
Pre-installed WEBCARDLX with
latest version of PADM20
supports Auto Probe feature
ENERGY STAR-certified to
save electricity, lower costs, and
protect the environment
MODEL NUMBER: SUINT1000LCD2UN
Applications
On-line double-conversion UPS provides pure sine wave AC output to server and network equipment in
data centers and computer rooms.
Deliver perfectly regulated sine
wave output to mission-critical
equipment
Protect connected components
from dangerous surges, spikes
and line noise
Keep equipment operational
through power failures
Allow time to save data and
safely shut down components in
case of a prolonged blackout
Features
Double-Conversion UPS Protects Equipment against Damage, Downtime and Data LossThis
200/208/220/230/240V 50/60 Hz UPS system maintains perfect output by converting AC input to DC, then
reconverting UPS output to fully regulated sine wave AC with +/-2% voltage regulation in online and
battery modes. Featuring a 900W capacity, high 0.9 power factor, 627 joules of surge suppression, true
on-line operation with pure sine wave output and zero transfer time to battery mode in on-line doubleconversion mode, the SmartOnline® SUINT1000LCD2UN double-conversion UPS provides the highest
level of AC power protection and battery backup for critical network closet, computer room and data
center equipment.
Set Power Strategies to Reflect Your Protection PrioritiesPick your power strategy, from precise
power for sensitive systems to the highest possible electrical efficiency, while ensuring 100% uptime.
Choose from five selectable strategies: Max Efficiency, Max Quality, Frequency Regulation, Frequency
Conversion and Auto Adaptive, which automatically offers increased efficiency when power conditions are
good and enhanced power quality when power conditions are poor.
Individually Controllable Load Banks Let You Access and Control Outlets RemotelyFour C13
outlets are split evenly into two switchable load banks, allowing you to reboot select components or shed
loads remotely. In addition to those four outlets, this UPS provides two more C13 outlets in their own
unswitched bank for powering critical components.
Reliable, Expandable Battery Backup Keeps You Operational Through Power OutagesThe fieldreplaceable, hot-swappable internal battery (RBC24S) provides 12.3 minutes of support at half load
(450W) and 4.7 minutes at full load (900W), keeping protected equipment operational through power
failures. For mission-critical applications demanding scalable extended runtime, the UPS supports “smart”
external battery packs, such as BP24V36-2US (sold separately). Both the internal and external batteries
are automatically sensed and configured during replacement to offer accurate runtime-remaining and
battery age notifications during outages. The intelligent battery management system with temperaturecompensated charging extends battery life.
Automatic Bypass Maintains Utility Output During Fault ConditionsAuto-bypass mode keeps
connected equipment powered and operational, even during UPS fault conditions.
1/7
Package Includes
SUINT1000LCD2UN
SmartOnline Double-Conversion
UPS
WEBCARDLX network interface
card
USB cable
RS-232 cable
EPO cable
(2) C13-to-C14 power cables
4-post rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
ENERGY STAR-Certified Economy Mode Helps You Save Money and Protect the EnvironmentBy
meeting strict EPA efficiency guidelines, this ENERGY STAR-certified UPS system helps you save money
and energy. A power-saving Economy mode setting option offers enhanced efficiency and reduced BTU
output when utility power is already high quality.
Automatically Turns Back On After Power Is RestoredBattery-independent restart ensures automatic
UPS power-up without user interaction after lengthy power outages, even when batteries are expired and
require replacement.
Intuitive Front-Panel Interface for Convenient UPS Operation and MonitoringThe front-panel LCD
screen reports UPS operating mode, detailed UPS status and site-power information, as well as a variety
of advanced UPS setup and configuration options. LEDs indicate AC input/output, battery and fault status.
Advanced Communications Ports Allow for Automatic Saves and ShutdownsRS-232 and HIDcompliant USB ports connect to a computer running free downloadable PowerAlert® software to enable
safe unattended file saves and system shutdown in case of a prolonged power failure. An EPO port
connects the UPS to a contact closure switch to enable emergency inverter shutdown. Cables are
included.
Pre-Installed WEBCARDLX Network Interface Offers 24/7 Remote Access for Monitoring and
ControlThe built-in WEBCARDLX with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities, including customizable dashboard
graphs to fit user preferences. The PADM20 upgrade and PowerAlert Element Manager (PAEM) software
form a powerful tool for expanding maintenance functions in large installations, including firmware update
checks and backup and restoration of device configurations. PADM20’s Auto Probe feature allows a UPS
with switched loads to automatically reboot devices if a network communication failure is detected. This
preserves uptime and minimizes the time and expense associated with on-site support.
Versatile Installation OptionsHardware is included for mounting the UPS system in 2U of space in an
EIA-standard 19-inch 4-post rack. Use the optional 2POSTRMKITWM (sold separately) for 2-post rack
mounting or the optional 2-9USTAND (sold separately) for mounting in an upright tower position. The C14
power inlet accepts a variety of user-supplied input cords.
Specifications
OVERVIEW
UPC Code
037332253569
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
4.99A
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
UPS Input Connection Type
C14 inlet
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
900
2/7
Cleveland, OH 44122
United States
Output Capacity (kW)
0.9
Output Capacity Details
DE-RATING INFORMATION: Max output in Frequency Conversion mode is reduced to 630 watts for
208/220/230/240V output voltages; Max output is 720W (504W in Frequency Conversion mode) at 200V output
voltage
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% for 3 minutes, 150% for
30 seconds and >150% for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are
WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits).
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
Nominal output voltage is user configured on first power-on
Frequency Compatibility
50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion
Frequency Compatibility Details
Output frequency matches input nominal on startup; Output capacity de-rates by 30% during frequency conversion
operation
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Included Output Power Cables
Includes 2 C13 to C14 power cables
Load Management Receptacles
Two switchable 2-outlet load banks
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 220V; 230V; 240V
Output Receptacles
(6) C13
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4.7 min. (900W)
Runtime Half Load (min.)
12.3 min. (450W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP24V15RT2U (limit 1); BP24V28-2U (limit 1); BP24V36-2US (multi-pack compatible); BP24V70-3U (multi-pack compatible)
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 4.1 hours from 10% to 90% (typical, full load discharge)
3/7
Cleveland, OH 44122
United States
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC24S
Battery Replacement Description
Hot-swappable, replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 288V
Undervoltage Correction
2% output voltage regulation during undervoltages to 160V (100% load), 130V (70% load), 100V (30% load)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Interactive front-panel LCD interface reports UPS operating mode, detailed UPS status and site-power information;
LCD interface also enables a variety of advanced UPS setup and configuration options
Switches
5 front panel switches: On/Off, Up, Down and Escape
Alarm Cancel Operation
Power-fail alarm can be silenced by following on-screen prompts
Audible Alarm
Audible alarm indicates power failure, low battery, overload and fault
LED Indicators
4 front panel LEDs: AC input (green), AC output (green), Battery (yellow), Fault (red)
SURGE / NOISE SUPPRESSION
UPS Dataline Suppression Details
Single line dialup / network dataline protection included
EMI / RFI AC Noise Suppression
Yes
AC Suppression Joule Rating
627
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to
914mm)
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail
rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM )
Minimum Required Rack Depth (cm)
48.26
(inches)
19
4/7
Cleveland, OH 44122
United States
Minimum Required Rack Depth with
External Battery Pack (cm)
48
External Battery Pack (in.)
18.75
without External Battery Pack (cm)
46
without External Battery Pack (in.)
18
Optional Mounting Accessory Notes
Optional 2-9USTAND enables upright tower UPS placement; 2POSTRMKITWM enables wall-mount and 2-post rackmount installation;
4POSTRAILKITWM enables installation in 4-post short-depth
racks from 14.5 to 23.5 inches (368 to 597mm); UPSHDEARKIT enables installation in 2 or 4-post
racks using front vertical rails only, without rear support
Primary UPS Depth (mm)
397
Primary UPS Height (mm)
88
Primary UPS Width (mm)
438
Shipping Dimensions (hwd / in.)
9.60 x 19.80 x 23.50
Shipping Weight (kg)
19.96
UPS Housing Material
Metal
UPS Power Module Dimensions
(hwd, in.)
3.46 x 17.24 x 15.63
UPS Power Module Weight (kg)
12.70
UPS Power Module Weight (lbs.)
28
Unit Weight (lbs.)
28.000
Unit Weight (kg)
12.70
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
5 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
245
AC Economy Mode BTU / Hr. (Full
Load)
128
AC Mode Efficiency Rating (100%
Load)
>93%
AC Economy Mode Efficiency Rating
(100% Load)
>96%
Online Mode Heat Dissipation
(BTU/Hr) @ Full Load
245
Battery Mode Heat Dissipation
500
5/7
Cleveland, OH 44122
United States
Audible Noise
