1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 230V 1kVA 700W DoubleConversion UPS, Tower, C14 inlet, DB9 Serial
MODEL NUMBER: SUINT1000XL
Highlights
1000VA on-line, doubleconversion, tower UPS system
Maintains sine-wave
220/230/240V +/-2% output
during overvoltages to 280V and
brownouts as low as 80V
(50/60Hz auto-sensing)
Network communications
supported via serial port
Fault-tolerant auto-bypass mode
and current monitoring
C14 inlet, C13 outlets, 2 C13 to
C14 power cables included
Package Includes
Description
Tripp Lite's SmartOnline SUINT1000XL on-line, double-conversion UPS protects critical server,
networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges.
Space-saving upright tower format. Large capacity 1000VA/700W UPS continuously converts incoming
AC to DC, then back to perfect sine wave AC output at selectable 220/230/240V AC (+/-2%). Removes
harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power
problems not addressed by other UPS types. True sine wave output and zero transfer time offers
guaranteed compatibility with all equipment types. Includes 4 C13 outlets. Includes enhanced DB9 serial
monitoring port for unattended shutdown, remote control and monitoring of UPS system and power data.
Features
True on-line, double conversion UPS provides pure sine wave AC output at all times
Maintains continuous operation with zero transfer time through blackouts, voltage fluctuations and
surges
Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power
problems
Corrects brownouts and overvoltages from 175-280V at full load. Input voltage range extends to 80280V at 50% load or less
1000VA/700W power capacity with 4 C13 outlets
IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific
wall receptacles
Standard internal battery set provides 14 min. runtime at half load and 5 min. runtime at full load
Intelligent battery management system extends battery life
DB9 serial port for network interface
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Diagnostic LEDs
2 C13 to C14 power cables included
1/5
SUINT1000XL UPS System
Serial cable
2 IEC320 C13-to-C14 jumper
cables
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332128584
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
3.7A (220V),3.5A (230V),3.4A (240V)
Nominal Input Voltage(s) Supported
220V AC; 230V AC; 240V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific wall
receptacles
Input Circuit Breakers
8A
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
700
Power Factor
0.7
Crest Factor
3:1
Nominal Voltage Details
230V default
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 50 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Included Output Power Cables
Includes 2 C13 to C14 power cables
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(4) C13
Individually Controllable Load Banks
No
2/5
Cleveland, OH 44122
United States
BATTERY
Runtime Full Load (min.)
5 min. (700w)
Runtime Half Load (min.)
14 min. (350w)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90% (typical, full load discharge)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 280
Undervoltage Correction
2% output voltage regulation during undervoltages to 175
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 80 (under 50% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information - includes 4-LED meter display for load and battery charge level
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Primary UPS Depth (mm)
366
Primary UPS Height (mm)
241
Primary UPS Width (mm)
140
Shipping Dimensions (hwd / in.)
12.50 x 19.20 x 9.10
Shipping Dimensions (hwd / cm)
31.75 x 48.77 x 23.11
Shipping Weight (lbs.)
34.50
3/5
Cleveland, OH 44122
United States
Shipping Weight (kg)
15.65
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
24.13 x 13.97 x 36.58
(hwd, in.)
9.5 x 5.5 x 14.4
UPS Power Module Weight (kg)
13.97
UPS Power Module Weight (lbs.)
30.8
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
265
Battery Mode BTU / Hr. (Full Load)
399
AC Mode Efficiency Rating (100%
Load)
90%
AC Economy Mode Efficiency Rating
(100% Load)
94%
Audible Noise
< 45 dB at front side 1m
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 communications
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cabling included
Communications Interface
DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
175V (100% load), 80V (
