1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 230V 3kVA 2.4kW DoubleConversion UPS, 3U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial
Highlights
3000VA / 3kVA / 2400 watt
online, double conversion 3U
rack / tower UPS
200/220/230/240V 50/60Hz
output
Expandable runtime; Hot-swap
batteries; 19.8 in / 50.3cm
installed depth
RS232 & EPO ports; Network
management card options
Front panel status LEDs with
detailed load and battery
metering
2 independently switchable
output load banks
C20 inlet, C13 & C19 outlets, 1
C19 to C20 and 2 C13 to C14
power cables included
MODEL NUMBER: SUINT3000RTXL3U
Package Includes
Description
SUINT3000RTXL3U
Rack/Tower UPS System
DB9 cabling
4 Post Rackmount installation
flanges and adjustable depth
mounting rails/or tower stands
for upright tower configuration
(2)6ft IEC320-C13 to IEC320C14, (1)10ft. IEC320-C19 to
IEC320-C20 AC interconnection
cables
Warranty information and
instruction manual
Tripp Lite's SUINT3000RTXL3U UPS System offers complete power conditioning and battery support for
critical fileservers and internetworking equipment in a versatile 3U rack/tower configuration. Offers
compatibility with 200/208/220/230/240V applications at 50/60Hz. Double conversion power conditioning
process removes line noise, voltage fluctuations and frequency variations by converting incoming AC to
DC, then back to universally compatible pure sine wave AC output. Standard internal batteries offer
seamless support of connected equipment during power failures with zero transfer time. Support through
extended power failures is available with the addition of 2U rack/tower compatible battery packs
BP72V15-2U (limit 1), BP72V28RT-3U (multi-pack compatible) and BP72V18-2US (multi-pack
compatible). Maintains continuous output over an input range of 160 to 275V without depleting battery
reserves. Brownout support extends to 130V when loaded to 70% or less. Intelligent DB9 monitoring port
works with PowerAlert software, available via free download, for unattended shutdown and remote
monitoring of UPS and site power conditions. Network accessory slot houses optional network
management card options. Includes 10 outlets total, 8 of which are arranged in two customized load
management banks that can be remotely powered off and on via software interface to reboot locked
equipment or extend battery runtime for more critical equipment by shedding non-essential loads. C20
input connection accepts a variety of detachable cordsets to match country- or site-specific wall
receptacles. 3000VA/2400W power-handling ability with full CE rating and Class A EMI/RFI rating
supports a wide range of fileservers and internetworking equipment, plus other sensitive loads requiring
full-time power conditioning, regulation and battery support. Compatible with Tripp Lite's WatchDog
system service software.
Features
True online, double-conversion power conditioning offers enhanced, network-grade pure sine wave AC
power for critical fileservers, internetworking equipment and sensitive electronics
1/6
Cleveland, OH 44122
United States
Maintains output within 2% of selectable 200/208/220/230/240V at 50/60Hz (+/-0.05Hz)
Neutralizes frequency variations, fast electrical impulses, harmonics and other hard-to-solve power
problems not addressed by other UPS types
Versatile rack/tower format requires only 3 rack spaces (3U) in rackmount applications; included tower
stand set supports upright configuration
Maintains AC output at near-perfect levels even during long-duration brownouts as low as 160V and
overvoltages to 275V without using battery power. Brownout support extends to 130V when loaded to
70% or less
Set of internal batteries supports connected equipment during power failures for 14 minutes at half load
(1500VA/1200W) and 5 minutes at full load (3000VA/2400W)
Expandable battery runtime with the addition of external battery packs BP72V15-2U (limit 1),
BP72V28RT-3U (multi-pack compatible) and BP72V18-2US (multi-pack compatible)
Intelligent battery management system extends battery life
Intelligent DB9 monitoring port communicates site power and UPS status information including line
power status, input voltage, battery status, load level and more - with full support for applications
requiring basic contact closure power-fail and low-battery messaging
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Emergency Power Off (EPO) support available; contact Tripp Lite
Includes 10 outlets (8 IEC320-C13 and 2 IEC320-C19)
1 C19 to C20 and 2 C13 to C14 power cables included
Two separate banks of individually controllable outlets enable remote reboot of locked network
equipment without disrupting power to other loads; accessible via PowerAlert, NMS or enabled web
browser - also supports automatic load shedding of non-essential items to extend battery runtime for
critical equipment
Compatible with Tripp Lite's WatchDog system service software
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Front panel LEDs and audible alarm provide notification of power status and full UPS status information
Optional 2POSTRMKITHD enables 2 post rackmount installation
Optional PDUBHV20 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
CE Certified
Specifications
OVERVIEW
UPC Code
037332117960
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
14.9A (200V),14.3A (208V). 13.1A (220V), 12.6A (230V), 12.1A (240V)
Nominal Input Voltage(s) Supported
200V AC; 220V AC; 230V AC; 240V AC
UPS Input Connection Type
C20 inlet
2/6
Cleveland, OH 44122
United States
UPS Input Connection Description
Supports a variety of user supplied input power cables
Input Circuit Breakers
25A
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
Output Capacity (kW)
2.4
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0,8
Crest Factor
3:1
Nominal Voltage Details
230V default
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 50 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Included Output Power Cables
Includes 1 C19 to C20 and 2 C13 to C14 output power cables
Load Management Receptacles
Two switchable four-outlet C13 load banks
Output Circuit Breakers
10A (x2) each breaker protects 4 C13 outlets, C19 is unbreakered
Hot-Swap PDU options
PDUBHV20 (2U / 6 C13, 2 C19 outlets)
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 220V; 230V; 240V
Output Receptacles
(8) C13; (2) C19
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
5 min. (2400w)
Runtime Half Load (min.)
14 min. (1200w)
Expandable Runtime
Yes
3/6
Cleveland, OH 44122
United States
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible); BP72V18-2US (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC53 (quantity 2)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 275
Undervoltage Correction
2% output voltage regulation during undervoltages to 156
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 130 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
3U
Cooling Method
Fan
Included Mounting Accessory
Description
4 post rackmount installation accessories included
Installation Form Factors Supported
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
4/6
Cleveland, OH 44122
United States
Minimum Required Rack Depth (cm)
81.28
(inches)
32
Primary UPS Depth (mm)
533
Primary UPS Height (mm)
133
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
25.00 x 13.00 x 23.00
Shipping Dimensions (hwd / cm)
63.50 x 33.02 x 58.42
Shipping Weight (lbs.)
94.80
Shipping Weight (kg)
43.00
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.34 x 44.45 x 53.34
(hwd, in.)
5.25 x 17.5 x 21
UPS Power Module Weight (kg)
33.97
UPS Power Module Weight (lbs.)
74.9
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1117
Battery Mode BTU / Hr. (Full Load)
1225
AC Mode Efficiency Rating (100%
Load)
87%
AC Economy Mode Efficiency Rating
(100% Load)
94%
Audible Noise
47dBA At Front Side 1 Meter
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable
connection OR via select Network Management Card options
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cable included
5/6
Cleveland, OH 44122
United States
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
DB9 Serial; Contact closure; Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
160V (100% load), 130V (
