1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 230V 1kVA 800W DoubleConversion UPS, 2U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial
Highlights
1000VA / 1kVA / 800 watt online double-conversion 2U
rack/tower UPS
200/208/220/230/240V 50/60Hz
output; High efficiency economy
mode option
Expandable runtime; Hot-swap
batteries; 13.5 in / 34.3cm
installed depth
USB, RS232 & EPO ports;
Network management card
options
Front panel status LEDs with
detailed load and battery
metering
C14 inlet, C13 outlets, 2 C13 to
C14 power cables included
MODEL NUMBER: SUINT1000RTXL2UA
Package Includes
SUINT1000RTXL2Ua
Rack/Tower UPS System
USB & DB9 Cabling
4-Post Rackmount Installation
Hardware
Warranty Information and
Owner's Manual
2 IEC C13 to C14
interconnection cables
Description
1000VA online, double-conversion UPS system for critical server, network and telecommunications
equipment. 2U rackmount form factor with an installed depth of only 13.5 in (34.3 cm). Expandable battery
runtime with optional external battery packs: BP24V15RT2U, BP24V28-2U (maximum of 1 per UPS) or
BP24V70-3U (multiple battery packs can be daisy-chained). Full-time sine wave 200, 208, 220, 230 or
240V +/-2% output. Uninterruptible Power Supply (UPS) continuously converts raw incoming AC power to
DC, then re-converts output back to completely regulated, filtered AC output. Corrects brownouts as low
as 130V and overvoltages as high as 275V without draining battery power. IEC-320-C14 inlet input
connection; IEC-320-C13 output receptacles. Network-grade AC surge and noise suppression. Zero
transfer time between AC and battery operation. Highly efficient operation in optional Economy Mode
setting, saving BTU heat output and energy costs. Network management interfaces support simultaneous
communications via USB port, DB9 serial port and slot for network management card options. HIDcompliant USB interface enables integration with built-in power management and auto shutdown features
of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test
data and utility power conditions via all 3 communications interfaces. PowerAlert monitoring software is
available via free download. Emergency Power Off (EPO) interface. 3-stage metered current monitoring
and battery charge status LEDs. LED display panel easily rotates for more convenient viewing in
rackmount or tower configurations. Data-line surge suppression for dialup, DSL or Ethernet network
connection. Utility power and voltage regulation LEDs. Audible alarm. Self-test. Fault-tolerant auto bypass
mode. 4-post rackmount accessories included; optional 2-9USTAND tower stand kit and
2POSTRMKITWM 2-post rack & wall-mount accessories available. Field-replaceable, hot-swappable
internal batteries and external battery packs. Attractive all-black color scheme.
Features
True online, double-conversion power conditioning offers network-grade pure sine wave AC power for
1/6
Cleveland, OH 44122
United States
critical fileservers, internetworking equipment and other sensitive electronics
Maintains output within 2% of selectable 200/208/220/230/240V at 50/60Hz (+/-0.05Hz)
Neutralizes hard-to-solve problems like frequency variations, fast electrical impulses, harmonics and
other power problems not addressed by other UPS types
Zero transfer time, on-line, double-conversion and economy-mode operation supported
Versatile rack/tower format requires only 2 rack spaces (2U) in rackmount applications
Maintains AC output at near perfect levels even during extended-duration brownouts as low as 130V
and overvoltages to 275V without using battery power. (For loads under 70%, brownout support extends
to 130V; for loads over 70%, brownout support extends to 160V)
During power failures, internal batteries support connected equipment for 12 minutes at half load
(500VA / 400W) and 4 minutes at full load (1000VA / 800W)
Battery backup runtime is expandable with the addition of external 2U or 3U rack/tower battery packs
(Part Number BP24V15RT2U (limit 1), BP24V28-2U (limit 1), BP24V70-3U (multi-pack compatible) and
BP24V36-2US (multi-pack compatible)
Intelligent battery management system extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Built-in USB port, DB9 serial port and slot for network management card options are simultaneously
addressable and support comprehensive network management features; USB and DB9 serial cables
included
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD and MODBUSCARD
HID-compliant USB interface enables integration with built-in power management and auto shutdown
features of Windows and Mac OS X
Includes 6 UPS supported IEC-320-C13 output receptacles and two C13 to C14 interconnection cables
(additional interconnection cables available - Part Number P004-006)
IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific
wall receptacles
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Compatible with Tripp Lite's WatchDog software
Front panel LEDs and audible alarm offer notification of power conditions and full UPS status
information
Optional tower stands allow vertical tower configuration (Part Number 2-9USTAND)
Optional 2POSTRMKITWM enables 2 post rack / wallmount installation
Built-in Emergency Power Off (EPO) interface with cable
Optional PDUBHV10 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
Specifications
OVERVIEW
UPC Code
037332126504
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
2/6
Cleveland, OH 44122
United States
Rated input current (Maximum Load)
5.1A (200V), 4.9A (208V), 4.6A (220V), 4.4A (230V), 4.2A (240V)
Nominal Input Voltage(s) Supported
200V AC; 220V AC; 230V AC; 240V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific wall
receptacles
Input Circuit Breakers
8A
OUTPUT
Output Capacity (VA)
1000
Output Capacity (kVA)
1
Output Capacity (Watts)
800
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.8
Crest Factor
3:1
Nominal Voltage Details
230V default
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 50 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Included Output Power Cables
Includes 2 C13 to C14 power cables
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 220V; 230V; 240V
Output Receptacles
(6) C13
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
4 min. (800w)
Runtime Half Load (min.)
12 min. (400w)
Expandable Runtime
Yes
3/6
Cleveland, OH 44122
United States
External Battery Pack Compatibility
BP24V15RT2U (limit 1); BP24V28-2U (limit 1); BP24V70-3U (multi-pack
compatible); BP24V362US (multi-pack compatible)
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC92-2U
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 275
Undervoltage Correction
2% output voltage regulation during undervoltages to 156
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 130 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
1225
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
4 post rackmount installation accessories included
4/6
Cleveland, OH 44122
United States
Installation Form Factors Supported
with Optional Accessories
2 post rackmount ( 2POSTRMKITWM ); Wallmount
( 2POSTRMKITWM ); Tower ( 29USTAND )
Minimum Required Rack Depth with
External Battery Pack (cm)
42
External Battery Pack (in.)
16.5
without External Battery Pack (cm)
40
without External Battery Pack (in.)
15.75
Primary UPS Depth (mm)
343
Primary UPS Height (mm)
89
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
8.70 x 19.80 x 23.50
Shipping Dimensions (hwd / cm)
22.10 x 50.29 x 59.69
Shipping Weight (lbs.)
41.80
Shipping Weight (kg)
18.96
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
8.89 x 44.45 x 34.29
(hwd, in.)
3.5 x 17.5 x 13.5
UPS Power Module Weight (kg)
12.70
UPS Power Module Weight (lbs.)
28
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
408
Battery Mode BTU / Hr. (Full Load)
444
AC Mode Efficiency Rating (100%
Load)
87%
AC Economy Mode Efficiency Rating
(100% Load)
94%
COMMUNICATIONS
5/6
Cleveland, OH 44122
United States
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable
connection OR via select Network Management Card options
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB (HID enabled); DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
160V (100% load), 130V (
