1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 230V 3kVA 2.1kW DoubleConversion UPS, Tower, Network Card Options,
DB9 Serial
Highlights
3000VA on-line, doubleconversion, extended-run tower
UPS system
Maintains 220/230/240V
selectable output within +/-2%
during overvoltages to 280V and
brownouts as low as 80V
(50/60Hz auto-sensing)
Network communications
supported via serial port and
network management card
options
Fault-tolerant auto-bypass and
current monitoring
Input: C20 inlet / Output: 8 x
C13 outlets (3 x C13-to-C14
jumper cables included)
MODEL NUMBER: SUINT3000XL
Package Includes
Description
Tripp Lite's SmartOnline SUINT3000XL on-line, double-conversion UPS protects critical server,
networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges.
Space-saving upright tower format. Large capacity 3000VA/2100W UPS continuously converts incoming
AC to DC, then back to perfect sine wave AC output at selectable 220/230/240V AC (+/-2%). Removes
harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power
problems not addressed by other UPS types. True sine wave output and zero transfer time offers
guaranteed compatibility with all equipment types. Includes 8 C13 outlets. Battery support can be
extended through the addition of external battery packs. Includes slot for internal network management
card options, plus DB9 enhanced serial monitoring port for unattended shutdown, remote control and
monitoring of UPS system and power data.
Features
True on-line, double conversion UPS provides pure sine wave AC output at all times
Maintains continuous operation with zero transfer time through blackouts, voltage fluctuations and
surges
Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power
problems
Corrects brownouts and overvoltages from 175-280V at full load. Input voltage range extends to 80280V at 50% load or less
3000VA/2100W power capacity with 8 C13 outlets
IEC320-C20 input connection accepts a variety of detachable cordsets to match country or site-specific
wall receptacles
Standard internal battery set provides 14 min. runtime at half load and 5 min. runtime at full load
Intelligent battery management system extends battery life
Expandable runtime with multiple external battery packs
1/5
SUINT3000XL UPS System
Serial cable
3 C13-to-C14 jumper cables
Owner's manual with warranty
information
Cleveland, OH 44122
United States
DB9 serial port for network interface; SNMP compatible
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Diagnostic LEDs
Optional PDUBHV20 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
3 C13-to-C14 jumper cables included
Specifications
OVERVIEW
UPC Code
037332128607
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
13.6A (220V), 13A (230V), 12.5A (240V)
Nominal Input Voltage(s) Supported
220V AC; 230V AC; 240V AC
UPS Input Connection Type
C20 inlet
UPS Input Connection Description
IEC320-C20 input connection accepts a variety of detachable cordsets to match country or site-specific wall
receptacles
Input Circuit Breakers
20A
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2100
Output Capacity (kW)
2.1
Power Factor
0.7
Crest Factor
3:1
Nominal Voltage Details
230V default
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 50 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
2/5
Cleveland, OH 44122
United States
Output Voltage Regulation (Battery
Mode)
+/- 2%
Included Output Power Cables
Includes 3 C13 to C14 output power cables
Hot-Swap PDU options
PDUBHV20 (2U / 6 C13, 2 C19 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(8) C13
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
5 min. (2100w)
Runtime Half Load (min.)
14 min. (1050w)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 90%
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 280
Undervoltage Correction
2% output voltage regulation during undervoltages to 175
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 80 (under 50% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
3/5
Cleveland, OH 44122
United States
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Primary UPS Depth (mm)
424
Primary UPS Height (mm)
373
Primary UPS Width (mm)
140
Shipping Dimensions (hwd / in.)
18.80 x 10.00 x 23.40
Shipping Dimensions (hwd / cm)
47.75 x 25.40 x 59.44
Shipping Weight (lbs.)
71.20
Shipping Weight (kg)
32.30
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
37.34 x 13.97 x 42.42
(hwd, in.)
14.7 x 5.5 x 16.7
UPS Power Module Weight (kg)
30.48
UPS Power Module Weight (lbs.)
67.2
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
758
Battery Mode BTU / Hr. (Full Load)
950
AC Mode Efficiency Rating (100%
Load)
90%
AC Economy Mode Efficiency Rating
(100% Load)
94%
Audible Noise
< 45 dB at front side 1m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX ; MODBUSCARD ; RELAYIOCARD
4/5
Cleveland, OH 44122
United States
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cabling included
Communications Interface
DB9 Serial; Contact closure; Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
175V (100% load), 80V (
