1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 1.5kVA 900W Line-Interactive
Sine Wave UPS, Tower, USB, DB9, 8 Outlets
MODEL NUMBER: SMC1500T
Highlights
Corrects under- and
overvoltages from 95V to 145V
(120V)
8 NEMA 5-15R outlets
Monitoring of power conditions
via PowerAlert software
Front-panel LEDs indicate load,
power, voltage and battery
statuses
17.4 min. runtime at half load;
6.4 min. at full load
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Pure sine wave output is compatible with active PFC power
supplies.
Description
The SMC1500T SmartPro 120V 1.5kVA 900W Line-Interactive Sine Wave UPS provides battery backup
and AC power protection against blackouts, brownouts, power surges and line noise that can damage
electronics or destroy data. Ideal for backing up high-performance workstations, servers and network
equipment, the SMC1500T switches to battery mode in milliseconds to keep your connected equipment
running long enough to save files and shut down safely with no data loss. Pure sine wave output is
compatible with active power factor correction (PFC) power supplies.
Featuring eight NEMA 5-15R outlets and a six-foot power cord with NEMA 5-15P input, the SMC1500T
has an internal battery that provides 17.4 minutes of support at half load and 6.4 minutes at full load.
Front-panel LEDs indicate load level, power, voltage correction, site wiring fault and battery statuses.
Automatic voltage regulation (AVR) maintains selectable 100V, 110V or 120V nominal output over an
input range of 83V–121V (100V), 87V–133V (110V) or 95V–145V (120V) without using battery power.
EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 570-joule surge
suppression rating protects your equipment from harmful power surges. With Tripp Lite’s free
downloadable PowerAlert software, the SMC1500T enables safe unattended system shutdown and file
saves in case of a prolonged power failure.
Features
Protects Mission-Critical Electronic Equipment
● Provides fully regulated pure sine wave AC output compatible with active PFC power supplies
Audible alarm signals loss of utility power, overload and low battery
6 ft. power cord with NEMA 5-15P input
570-joule surge suppression rating
Reliable Battery Backup
● Supports half load up to 17.4 min. and full load up to 6.4 min.
Internal batteries designed for hot-swap field replacement
95% line-power efficiency rating saves money in energy costs
1/5
Sine Wave UPS
USB cable
Owner’s manual
Cleveland, OH 44122
United States
Automatic Voltage Regulation (AVR)
● Maintains selectable nominal output without using battery power
Corrects brownouts and overvoltages from 83V–121V (100V), 87V–133V (110V) or 95V–145V (120V)
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s
performance
LED Indicators
● Front-panel LEDs indicate load level, power, voltage correction, site wiring fault and battery statuses
Communications Ports
● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
RJ45 Telephone/Ethernet Protection Jacks
● Protect phone/DSL/fax/modem/Ethernet network against power surges
Specifications
OVERVIEW
UPC Code
037332188809
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10.1A (120V), 9.3A (110V), 8.6A (100V)
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
900
Nominal Voltage Details
120V default (voltage selection via back panel switches)
Frequency Compatibility
50 / 60 Hz
2/5
Cleveland, OH 44122
United States
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Line
Mode)
-13%, + 15%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
6.4 min. (900w)
Runtime Half Load (min.)
17.4 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC36-SLT
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 95 to 145 (120v),
87 to 133 (110v), 83 to 121 (100v)
Overvoltage Correction
Voltage reduction of 12% applies when input is 127 to 145 (120v), 116 to 133 (110v), 111 to 121 (100v)
Undervoltage Correction
Voltage boost of 14% applies when input is 95 to 108 (120v), 87 to 99 (110v), 83 to 90 (100v)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support
nominal voltage selection
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power failure and overload conditions
LED Indicators
Status LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter
for load and battery charge level
Site Wiring Fault Indication
Rear panel site wiring fault LED
SURGE / NOISE SUPPRESSION
3/5
Cleveland, OH 44122
United States
UPS AC Suppression Joule Rating
570
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
335
Primary UPS Height (mm)
259
Primary UPS Width (mm)
173
Shipping Dimensions (hwd / in.)
14.00 x 9.60 x 18.30
Shipping Dimensions (hwd / cm)
35.56 x 24.38 x 46.48
Shipping Weight (lbs.)
43.90
Shipping Weight (kg)
19.91
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
25.91 x 17.27 x 33.53
(hwd, in.)
10.2 x 6.8 x 13.2
UPS Power Module Weight (kg)
20.41
UPS Power Module Weight (lbs.)
45
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius.
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius.
Relative Humidity
5 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
148
Battery Mode BTU / Hr. (Full Load)
500
AC Mode Efficiency Rating (100%
Load)
95%
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
4/5
Cleveland, OH 44122
United States
Communications Cable
USB cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications.
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Network Management Card
Description
Network management not supported
Communications Interface
DB9 Serial; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
95V (120V), 87V (110V), 83V (100V)
High Voltage Transfer to Battery
Power (Setpoint)
145V (120V), 133V (110V), 121V (100V)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Sine wave output; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
