1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 1440VA 1100W Line-Interactive Sine
Wave UPS, AVR, 120V, 5 Outlets, Network Card
Option, LCD, USB, 1U Rack/Tower
Highlights
Protects equipment against
blackouts, brownouts, transient
surges and line noise
Keeps AC power running during
outages to allow time for file
saves and safe shutdown
Maintains continuous 120V
nominal output during
brownouts as low as 90V
5-15R outlets power and protect
networking, telecom and other
sensitive equipment
Optional WEBCARDLX offers
24/7 remote access for
enhanced real-time
management
MODEL NUMBER: SMC1500RT1U
Package Includes
Provides complete battery backup and power protection for servers, switches and other in-rack IT
equipment in small-to-mid-size networks.
Features
1440VA/1100W/120V Battery Backup for PC Networks, Security Systems or Digital Signage
This SmartPro® line-interactive UPS system with AVR provides reliable battery backup and AC power
protection against blackouts, brownouts, surges and line noise that can damage valuable electronics or
destroy data. The SMC1500RT1U is ideal protection for point-of-sale and kiosk applications, a smallbusiness VoIP network or rack-mount equipment, such as servers and switches, in your server room or
network closet.
Reliable Battery Backup Keeps You Operational Through Power Outages
The field-replaceable, hot-swappable internal battery provides eight minutes of support at half load
(550W) and two minutes at full load (1100W), allowing you to work through short power failures and giving
you enough time to safely save files and shut down your system in case of a prolonged blackout.
Optional WEBCARDLX Network Interface Offers 24/7 Remote Access for Monitoring and Control
The optional WEBCARDLX (sold separately) with the latest version of PowerAlert® Device Manager
firmware (PADM20) provides enhanced remote management capabilities, including customizable
dashboard graphs to fit user preferences. The PADM20 upgrade and PowerAlert Element Manager
(PAEM) software form a powerful tool for expanding maintenance functions in large installations, including
firmware update checks and backup and restoration of device configurations.
NEMA 5-15R Outlets Protect Your Connected Components
Five 5-15R outlets provide connected equipment with pure sine wave AC output during blackouts,
overvoltages and severe brownout conditions. Power provided by these outlets is filtered to protect
connected equipment against damaging surges and line noise.
Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage Conditions
AVR protects your equipment from incremental hardware damage, data loss and performance problems
caused by brownouts. The SMC1500RT1U maintains regulated 120V nominal output during brownouts as
low as 90V, while keeping the battery fully charged and ready to take over in case of power failure.
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better
1/6
1440VA 1100W 120V LineInteractive UPS with 5 Outlets
USB cable
EPO/ROO connector
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
This UPS system filters out disruptive electromagnetic and radio frequency interference that can inflict
hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform
better and last longer.
Designed for High Efficiency to Help You Save Money and Protect the Environment
A 98% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs.
Intuitive Front-Panel Interface for Convenient UPS Operation and Monitoring
The front-panel LCD features detailed UPS and site power status and operating data (including load,
voltage and battery data) and multiple screens of configuration and setup options. LEDs indicate AC
output availability and fault status. On-screen operational diagram offers an easy-to-grasp visual
representation of line and battery modes.
Advanced Communications Ports Allow for Automatic Saves and Shutdowns
An HID-compliant USB port connects to a computer running free downloadable PowerAlert software to
enable safe unattended shutdown in case of a prolonged power failure. The EPO/ROO port supports
emergency shutdown in large facilities or remote On/Off capability. USB cable is included.
Versatile Installation Options
Hardware is included for mounting the UPS in just 1U of space in an EIA-standard 19-inch 4-post or 2post rack. You can also adapt it for tower mounting using the included hardware. The six-foot power cord
with NEMA 5-15P plug connects to a compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332239358
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
11.3A (100V); 12A (120V); 10.8A (127V)
Nominal Input Voltage(s) Supported
100V AC; 120V AC; 127V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1440
Output Capacity (kVA)
1.44
Output Capacity (Watts)
1100
Output Capacity (kW)
1.1
Output Capacity Details
1440 VA @ 120VAC and 127VAC, 100VAC: 1080 VA
2/6
Cleveland, OH 44122
United States
Power Factor
0.76
Nominal Voltage Details
120V sinusoidal in line mode and 120V sinusoidal in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal.
Output Voltage Regulation (Line
Mode)
For 100V: 90VAC +/-5% -115VAC +/- 5% (78VAC +/- 5% -115VAC +/- 5%(@70VAC Input)) For 120V: 102VAC +/5% -139VAC +/- 5%, (78VAC +/- 5% -139VAC +/- 5%(@70VAC Input)), For 127V: 108VAC +/- 5% -145VAC +/- 5%
(78VAC +/-5% -145VAC +/- 5% (@70VAC Input))
Output Voltage Regulation (Battery
Mode)
-10%, +6%
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(5) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
2 min. (1100W)
Runtime Half Load (min.)
8 min. (550W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
6 Hours to 90%
Battery Access
Battery access panel
Internal UPS Replacement Battery
Cartridge
RBC367-1U
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 70V @
120V/127V/100V (±5%). Input voltage range of 70V to 139V @ 100V; 70V to 162V @ 120V / 127V settings
Overvoltage Correction
Voltage reduction of 15% applies when input is 139V to 162V (120V), 145V to 162V (127V), 115V to 139V (100v);
All voltage setpoints within ±5% tolerance
Undervoltage Correction
Voltage boost of 15% applies when input is 89V (HI Sensitivity) / 70V (LO sensitivity) to 102V @120V, 93V (HI
sensitivity) / 70V (LO sensitivity) to 108V @127V, 80V (Hi sensitivity)/ 70V @100V; All voltage setpoints within ±5%
tolerance
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data,
plus configuration of voltage, frequency, operating mode, alarm function and a variety of additional options (see
manual)
3/6
Cleveland, OH 44122
United States
Switches
ON button controls UPS ON, Cold-start, Self-test, and menu functions. OFF button controls unit off, fault clearance,
and menu functions. Alarm/Enter button control audible alarm state and menu confirmation.
Audible Alarm
Audible alarm indicates UPS startup, power-failure, warnings, and low-battery conditions
LED Indicators
2 LEDs indicate AC output status (Green); UPS fault (Solid Red)/ UPS abnormal conditions (Flashing Red).
SURGE / NOISE SUPPRESSION
EMI / RFI AC Noise Suppression
Yes
AC Suppression Joule Rating
540
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount; Tower
Rack Height
1U
Cooling Method
Fan
Included Mounting Accessory
Description
Included mounting brackets provide front-rail installation in 2 or 4 post racks, plus upright tower configurations
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount; Tower
Maximum Device Depth (cm)
55.37
Maximum Device Depth (in.)
21.8
Maximum Device Depth (mm)
554
Minimum Required Rack Depth (cm)
63.50
(inches)
25
Primary UPS Depth (mm)
554
Primary UPS Height (mm)
44
Primary UPS Width (mm)
440
UPS Housing Material
Steel
UPS Power Module Weight (kg)
16.80
UPS Power Module Weight (lbs.)
37.037
Unit Weight (lbs.)
37.037
Unit Weight (kg)
16.80
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode Efficiency Rating (100%
Load)
98%
4/6
Cleveland, OH 44122
United States
Operating Elevation (ft.)
3280 ft. (1000 m) above sea level
Audible Noise
40 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
WEBCARDLXE
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
(1) EPO (emergency power off); Slot for SNMP/Web interface; (1) USB (HID enabled)
Emergency Power Off
(EPO)/Remote On-Off (ROO)
Yes
Emergency Power Off/Remote OnOff Details
Phoenix-style connection supports Emergency Power Off and Remote ON/OFF functions.
LINE / BATTERY TRANSFER
Transfer Time
6-8 ms typical ( < 10 ms max)
Low Voltage Transfer to Battery
Power (Setpoint)
100V: 80VAC +/- 5% (HI sensitivity), 70VAC +/- 5%, (LO sensitivity), @120V: 89VAC +/- 5% (HI sensitivity),
70VAC+/- 5% (LO sensitivity), @127V: 93VAC+/- 5%, (HI sensitivity), 70VAC+/- 5%, (LO sensitivity)
High Voltage Transfer to Battery
Power (Setpoint)
162 VAC (120VAC/127VAC INPUT), 139 VAC (100VAC INPUT) +/- 5%
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLXE); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
Grounding Details
Back panel grounding lug
APPLICATIONS
UPS Applications
High-End Desktop/Small Network; Retail/Point of Sale; Hospitality
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
ENERGY STAR Qualified; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
5/6
Cleveland, OH 44122
United States
Extended Warranties
1-year and 2-year extensions available
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
