1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 208/240, 230V 6kVA 5.4kW DoubleConversion UPS, 4U Rack/Tower, Extended Run,
Network Card Options, USB, DB9 Serial, Bypass
Switch, C19
MODEL NUMBER: SU6000RT4UHVG
Highlights
6000VA / 6kVA / 5400W on-line
double-conversion 4U
rack/tower UPS, Sine Wave
Included maintenance bypass
switch enables live replacement
of UPS with zero downtime
Extended runtime options,
Interactive LCD interface,
Economy-mode option, 0.9
power factor
Add optional WEBCARDLX with
latest version of PADM20 for
enhanced remote management
Hardwire 200-240V 50/60Hz
input; C19 outlets; Configurable
for 200/208/220/230/240V
50/60Hz output
Package Includes
SU6000RT4UHVPM Hotswappable UPS Power Module
SUPDMB6KIEC Detachable
PDU with Maintenance Bypass
Switch
1 x 6-ft. USB Cable
Description
1 x 6-ft. DB9 Cable
Tripp Lite SU6000RT4UHVG 6000VA / 6kVA / 5400 watt on-line, double-conversion UPS system offers
complete power protection for critical server, network and telecommunications equipment in a single 4U
rack/tower compatible housing. Full-time active power conditioning provides clean, continuous dualconversion AC output free of voltage fluctuations, power interruptions and line noise. Fault-tolerant autobypass prevents unexpected service interruptions during UPS overload or internal fault conditions.
Detachable back panel PDU with manual bypass switch supports hot-swappable whole UPS replacement
with no interruption to connected equipment. Single all-in-one rack / tower housing installs in only 4 rack
spaces (4U) with a maximum installed depth of only 20.7 in. / 52.6cm. Maintains full-time sine wave output
within 2% of selectable 200/208/220/230/240V nominal during brownouts as low 100V and overvoltages
as high as 300V. Expandable runtime is supported with optional BP192V12-3U external battery packs.
Battery independent restart ensures automatic UPS power-up without user interaction after lengthy power
outages, even when batteries are expired and require replacement. Double-conversion operation converts
raw input from AC to DC, then re-synthesizes output power back to perfect sine wave AC with enhanced
protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not
addressed by other UPS types. Highly efficient operation in optional economy mode significantly reduces
BTU heat output and operating energy costs. Network-grade AC surge and noise suppression. Supports
detailed monitoring of equipment load levels, self-test data and utility power conditions via built-in RS-232
and USB interfaces. Optional network management card options available. HID-compliant USB interface
enables integration with built-in power management and auto shutdown features of Windows and Mac OS
X. PowerAlert monitoring software offers detailed site power and UPS updates with support for safe autoshutdown of connected systems as UPS batteries become depleted. Supports Emergency Power Off
(EPO) via built-in interface. Front panel LEDs and LCD readout with scroll controls support front-panel
visual monitoring of all major UPS for a variety of control options to support advanced UPS settings and
configurations. LED / LCD display panel rotates for viewing in rackmount or tower configurations.
Hardwire input and 4 C19 outlets. Support for optional North American and International cordsets.
External battery packs are field replaceable and hot swappable.
4-Post Rackmount Hardware
Features
Tripp Lite SU6000RT4UHVG 6000VA / 6kVA / 5400 watt on-line, double-conversion UPS system in a
single 4U rack/tower compatible housing (output is limited to 4992 watts when used at 208V with L630P input plug)
Full-time active power conditioning maintains clean, continuous dual-conversion AC output free of
1/7
Cleveland, OH 44122
United States
Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions
Detachable back panel PDU contains hardwire input line cord connection, output receptacles and
manual bypass switch to support hot-swappable whole UPS replacement with no interruption to
connected equipment
Hardwire input and 4 C19 output receptacles
Included rail kit supports 4U 19 inch rackmount installation in 4 post racks
Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks (1 required for
SU6000RT4UHVG)
Optional 2-9USTAND supports upright tower placement (1 required for SU6000RT4UHVG)
Maximum installed rack depth of only 20.7 in. / 52.6cm
Maintains full-time sine wave output within 2% of selected 200/208/220/230/240V nominal in double
conversion mode
Corrects brownouts to 156V at full load (100V at 50% load or less)
Corrects overvoltages to 290V at full load (300V at 90% load or less)
Supports 50/60Hz operation for worldwide frequency compatibility
Double-conversion operation offers full-time AC to DC, then DC to AC conversion to maintain perfectly
regulated sine wave AC output with enhanced protection from harmonic distortion, fast electrical
impulses and other hard-to-solve power problems not addressed by other UPS types
High efficiency ECONOMY MODE operation significantly reduces BTU heat output and operating
energy costs
Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via
built-in RS-232, USB and network management card options
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX,
SNMPWEBCARD, MODBUSCARD and RELAYIOCARD
Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities
PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance
functions in large installations, including firmware update checks and backup and restoration of device
configurations
Optional RELAYIOMINI interface module offers three configurable hard contact closure outputs for
custom event notification (requires removal of USB interface module)
HID-compliant USB interface enables integration with built-in power management and auto shutdown
features of Windows and Mac OS X
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Front panel LEDs and LCD readout with scroll controls support front-panel visual monitoring of all major
UPS functions with support for a variety of control options to support advanced UPS settings and
configurations
LED/LCD display panel rotates for viewing in rackmount or tower configurations
Supports Emergency Power Off (EPO) via built-in interface
power outages, even when batteries are expired and require replacement
BP192V12-3U external battery packs are field replaceable and hot swappable
Intelligent battery management system with temperature-compensated charging extends battery life
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Frequency conversion mode enables conversion of 60Hz to 50Hz or 50Hz to 60Hz (no de-rating)
2/7
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332157232
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
31.9A (200V), 30.6A (208V), 29A (220V), 27.7A (230V), 26.6A (240V)
Nominal Input Voltage(s) Supported
200V AC; 208V AC; 220V AC; 230V AC; 240V AC
Nominal Input Voltage Description
Factory configured to 208V
UPS Input Connection Type
Hardwire
UPS Input Connection Description
Supports North American 208/240V input (L1,L2,G) or International 230/220/240V (L,N,PE) input wiring; Optional
SU30ACORD offers NEMA L6-30P input
Recommended Electrical Service
40A (200/208v); 30-32A (220/230/240v)
OUTPUT
Output Capacity (VA)
6000
Output Capacity (kVA)
6
Output Capacity (Watts)
5400
Output Capacity (kW)
5.4
Output Capacity Details
Output capacity de-rates to 4992 watts when used at 208V with optional L6-30P line cord; Supports up to 105% load
continuously in double conversion mode, 106 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over
150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion
mode is automatically restored as the overload is cleared
Power Factor
0,9
Crest Factor
3:1
Nominal Voltage Details
Voltage selection via front panel LCD interface
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup; Frequency conversion mode enable conversion of 60Hz to
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Output Receptacle Details
Output receptacle and input connections are mounted on a detachable PDU backplate with bypass switch to enable
hot-swappable power module replacement
Output Circuit Breakers
Two 20A breakers protect 2 C19 outlets each
Output AC Waveform (AC Mode)
Pure Sine wave
3/7
Cleveland, OH 44122
United States
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
200V; 208V; 220V; 230V; 240V
Output Receptacles
(4) C19
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
2 min. (5400W)
Runtime Half Load (min.)
8.5 min. (2700W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP192V12-3U ; BP192V5RT2U (limit 1); BP192V787C-1PH
DC System Voltage (VDC)
192
Battery Recharge Rate (Included
Batteries)
6 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC5-192
Battery Replacement Description
Hot-swappable, user replaceable internal batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
Corrects overvoltages as high as 300V (
