SU6000RT3U
SU6000RT3U
    TRIPPLITE
    UPS TRUE ONLINE 6KVA 4200W RKMNT
SU6000RT3U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 208/240 & 120V 6kVA 4.2kW DoubleConversion UPS, 9U Rack/Tower, Extended Run, Network Card Slot, DB9, Bypass Switch, Hardwire Highlights ● 6000VA / 6kVA / 4200W on-line double-conversion UPS ● 208/120V or 240/120V 50/60Hz output; Economy mode option ● 9U Rack/Tower compatible; Hotswap power and battery modules ● RS232 & EPO ports; Slot for network management card options ● Front panel LEDs with detailed LCD monitoring and control screen ● Expandable runtime with optional external battery packs ● Hardwire input (3 wire); Hardwire output MODEL NUMBER: SU6000RT3U Package Includes Description ● SU6000RT3UPM 3U power module ● SU6000XFMRRT3U 3U stepdown isolation transformer ● 240V 3U external battery pack ● Four post compatible rack rail kit (3 sets) ● DB9 & EPO cables Tripp Lite SU6000RT3U on-line, double-conversion UPS protects server, networking or telecommunications equipment from blackouts, voltage fluctuations and surges in a compact tower/rackmount housing. In a rack configuration, the power module, step-down transformer, and battery pack occupy only 3 rack spaces each (9U total). Upright tower placement of entire system supported with included tower stands. Large capacity 6000VA/4200 watt power module double-conversion technology converts raw input AC to DC, then resynthesizes it back to perfect sine wave AC output within 2% of userselectable 208V/240V and 120V AC output voltages. Frequency regulation locks output power to 50/60Hz (+/-0.2 Hz), removing harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types. Perfectly regulated, continuous sine wave output with zero transfer time offers guaranteed uptime and compatibility with all equipment types. Hardwire input and output connections support a variety of permanent or plug-in power connections. Highly efficient operation in optional economy mode setting, saving BTU heat output and energy costs. Battery support can be extended through the addition of external battery packs. Includes accessory slot for optional monitoring and management cards, plus DB9 contact-closure, and DB9 enhanced serial monitoring ports for unattended shutdown, remote control and monitoring of UPS system and power data. Features ● Tripp Lite SU60000RT3U 6kVA / 6,000VA / 4200 watt on-line, double-conversion UPS system in 9U total rack/tower configuration (3U UPS power module, 3U external battery pack and 3U step-down transformer) ● Included step-down transformer with manual bypass switch enables hot-swappable UPS power module replacement with no interruption in output power to connected networking equipment ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Hardwire input and output connections 1/7 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Full-time active power conditioning provides clean, continuous dual-conversion AC output free of voltage fluctuations, power interruptions and line noise ● Double-conversion operation converts raw input from AC to DC, then re-synthesizes output power back to perfect sine wave AC with enhanced protection from harmonic distortion, fast electrical impulses and other hard-to-solve power problems not addressed by other UPS types ● Accepts input voltages between 156 and 276, regulating output within 2% of selectable 208/240 and 120V AC output ● Standard included 3U battery pack provides 20 minutes runtime at half load (3000VA) and 8 minutes at full load (6000VA) ● Expandable runtime is supported with optional BP240V10RT3U; BP240V787C-1PH external battery packs ● Intelligent battery management system extends battery life ● Highly efficient operation in optional economy mode significantly reduces BTU heat output and operating energy costs ● Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via built-in RS-232 interfaces ● Optional network management and contact-closure communications card accessories available. ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● Supports Emergency Power Off (EPO) via built-in interface ● Included rail kit supports 9U 19 inch rackmount installation in 4 post racks ● Optional 2POSTRMKITHD supports installation in 2 post 19 inch racks ● Front panel LED's and LCD readout with scroll controls and supports visual monitoring of all major UPS functions and advanced UPS settings for nominal voltage selection, economy mode, and other operational parameters ● LED / LCD display panel rotates for viewing in rackmount or tower configurations ● Network-grade AC surge and noise suppression ● External battery packs are field replaceable and hot swappable Specifications OVERVIEW UPC Code 037332121417 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 30A Nominal Input Voltage(s) Supported 208V AC; 240V AC UPS Input Connection Type Hardwire UPS Input Connection Description 3 wire single phase input (L1, L2, G); optional, country-specific backplates SUPDM12 (for 208v nominal), SUPDM14 (for 240v nominal), SUPDM16 (for 208v nominal) add low and high voltage outlets, plus L6-30P input cord Input Circuit Breakers 40A double-pole 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 30A 208V or 240V OUTPUT Output Capacity (VA) 6000 Output Capacity (kVA) 6 Output Capacity (Watts) 4200 Output Capacity (kW) 4.2 Output Capacity Details Supports up to 102% load continuously in double conversion mode, 102 to 125% for 1 minute, 126% to 150% for 30 seconds; Loads over 150% trigger immediate bypass mode operation to support loads directly from mains power; Double conversion mode is automatically restored as load levels are reduced to 90% or less Power Factor 0.7 Crest Factor 3:1 Nominal Voltage Details Voltage selection via front panel LCD interface Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Output Receptacle Backplate Options Optional backplates SUPDM12 (for 208v nominal), SUPDM14 (for 240v nominal), SUPDM16 (for 208v nominal) add low and high voltage outlets, plus L6-30P input cord Output Circuit Breakers 40A double-pole Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V; 208V; 240V Output Receptacles Hardwire Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 8 min. (4200w) Runtime Half Load (min.) 20 min. (2100w) Expandable Runtime Yes External Battery Pack Compatibility  BP240V10RT3U ;  BP240V787C-1PH  DC System Voltage (VDC) 240 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% (typical, full load discharge) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 276 Undervoltage Correction 2% output voltage regulation during undervoltages to 156 USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Selectable LCD display with scroll and selection buttons enables UPS control and detailed monitoring options; LED/LCD panel rotates for viewing in rack/tower formats (see manual) Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; 2 additional switches support set and execute scrolling LCD functions; bundled transformer includes bypass switch to enable hot-swap UPS power module replacement Alarm Cancel Operation Alarm cancel switch Audible Alarm Unique audible alarms for all major UPS, environmental and power conditions (see manual) LED Indicators 6 LEDs indicate line power, online mode, economy/bypass mode, on-battery, charger and AC output status; LCD screen offers additional information and control options ISOLATION Output Isolation Transformer 120V output includes load isolation transfomer protection SURGE / NOISE SUPPRESSION UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 9U Cooling Method Fan Included Battery Pack Dimensions (hwd / in.) 5.2 x 17.5 x 25 Included Battery Pack Weight (lbs.) 136.5 Included Battery Pack Weight (kg) 61.92 Included Mounting Accessory Description 3 sets of adjustable 4 post rack rails included (for UPS, transformer and battery pack components); 2-9USTAND tower kit included (supports up to 9U in tower format) Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITHD ) Maximum Device Depth (cm) 66.04 Maximum Device Depth (in.) 26 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Device Depth (mm) 660 Minimum Required Rack Depth (cm) 83.82 Minimum Required Rack Depth (inches) 33 Optional Mounting Accessory Notes 3 sets of  2POSTRMKITHD  required for 2 post rackmount installation of separate UPS, transformer and battery pack Primary UPS Depth (mm) 660 Primary UPS Height (mm) 132 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 36.00 x 24.00 x 35.00 Shipping Dimensions (hwd / cm) 91.44 x 60.96 x 88.90 Shipping Weight (lbs.) 436.00 Shipping Weight (kg) 197.77 Stepdown Transformer Dimensions (hwd / cm) 13.21 x 44.45 x 66.04 Stepdown Transformer Dimensions (hwd / in.) 5.2 x 17.5 x 26 Stepdown Transformer Height (mm) 132 Stepdown Transformer Width (mm) 445 Stepdown Transformer Depth (mm) 660 Stepdown Transformer Weight (kg) 40.82 Stepdown Transformer Weight (lbs.) 90 Unit Dimension Details Includes 3U UPS/power module, 3U stepdown transformer and 3U battery pack UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 13.21 x 44.45 x 66.04 UPS Power Module Dimensions (hwd, in.) 5.2 x 17.5 x 26 UPS Power Module Weight (kg) 19.87 UPS Power Module Weight (lbs.) 43.8 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 1418 Battery Mode BTU / Hr. (Full Load) 1593 AC Mode Efficiency Rating (100% Load) 91% 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Economy Mode Efficiency Rating (100% Load) 96% Operating Elevation (ft.) 0-3000m (0 to 10,000 ft.) Audible Noise 53dBA At Front Side 1 Meter Operating Elevation (m) 0-3000 m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description RS232 and contact closure communications are located on two separate DB9 ports PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable DB9 cable included Communications Interface DB9 Serial; Contact closure; EPO (emergency power off); Slot for SNMP/Web interface LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Transfer Time (Economy Mode) 8ms. typical power failure response in optional economy mode Low Voltage Transfer to Battery Power (Setpoint) 156 High Voltage Transfer to Battery Power (Setpoint) 276 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported Economy Mode Operation Optional economy mode enables high efficiency bypass operation with a maximum output voltage variation of +/10%. Double conversion mode is automatically restored as mains voltage varies beyond +/-10% with less than 1 millisecond transfer time between modes. High Availability UPS Features Automatic inverter bypass; Manual bypass switch; Hot swappable UPS power module; Hot swappable batteries Green Energy-Saving Features High efficiency economy mode operation; Schedulable daily hours of economy mode operation WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SU6000RT3U 价格&库存
很抱歉,暂时无法提供与“SU6000RT3U”相匹配的价格&库存,您可以联系我们找货
