ME6117A50B3G
ME6117A50B3G
    MICRONE(南京微盟)
    SOT-223
    VIN=18V Vo=5V Pd=750mW
ME6117A50B3G 数据手册
ME6117 1A Adjustable Voltage High Speed LDO Regulators ME6117 Series General Description Features The ME6117 series are highly accurate, low noise, LDO Voltage Regulators that are capable of providing an output current that is in excess of 800mA with a maximum dropout voltage of 1.2 V at 800mA.This series contains two fixed output voltages of 3.3 V, and 5.0 V that have no minimum load requirement to maintain regulation. On chip trimming adjusts the reference/output voltage to within ±2% accuracy. Internal protection features consist of output current limiting, safe operating area compensation, and thermal shutdown. The ME6117 series can operate with up to 15 V input. Devices are available in SOT223. l l l l l l l l l l l Output Current in Excess of 800mA Dropout Voltage: 120mV@ IOUT =100mA Operating Voltage Range: 3.6V~15V Highly Accuracy: ±2% Adjustable Output Voltage Option Standby Current: 90uA(TYP.) High Ripple Rejection: 72dB@1KHz(ME6117A33) Line Regulation: 0.1%(TYP.) Temperature Stability≤0.5% Thermal Shutdown Protection:150℃ Packages:SOT223、SOT89-3 Typical Application l Selection Guide l l l Consumer and Industrial Equipment Point of Regulation Switching Power Supply Post Regulation Hard Drive Controllers Battery Chargers Typical Application Circuit V05 www.microne.com.cn Page 1 of 11 ME6117 Pin Configuration SOT223 SOT89-3 Pin Assignment ME6117AXX Pin Number Pin Name Functions SOT223 SOT89-3 1 1 GND Ground 2 3 VOUT Output 3 2 VIN Power Input Absolute Maximum Ratings Parameter Symbol Ratings Units Input Voltage VIN 18 V Output Current IOUT 1.1 A Output Voltage VOUT Vss-0.3~VIN +0.3 V 750 mW 500 mW Power Dissipation SOT223 SOT89-3 PD Operating Temperature Range TOPR -40~+125 ℃ Storage Temperature Range TSTG -40~+150 ℃ Lead Temperature V05 260℃,4sec www.microne.com.cn Page 2 of 11 ME6117 Block Diagram Electrical Characteristics ME6117A33 (VIN= VOUT +1.5V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN= VOUT +1.5V X 0.98 VOUT (T) (Note 1) X 1.02 V Maximum Output Current IOUTMAX VIN= VOUT +1.5V 800 Load Regulation ∆VOUT VIN= VOUT +1.5V , 0mA≤IOUT≤800mA 5 VDIF1 IOUT =100mA 120 mV VDIF2 IOUT =500mA 620 mV VDIF3 IOUT =800mA 1050 mV Quiescent Current Iss VIN= VOUT +1.5V 90 uA Line Regulation ∆VOUT ∆VIN • VOUT IOUT =0mA VOUT+1.5V ≤VIN≤15V 2 Dropout Voltage (Note 3) Ripple Rejection Rate V05 PSRR VIN = 6.3V +1Vp-pAC IOUT=100mA,1kHZ 72 IOUT=200mA,1kHZ 68 IOUT=500mA,1kHZ 61 www.microne.com.cn mA 10 5 mV mV dB Page 3 of 11 ME6117 ME6117A50 (VIN= VOUT +1.5V,CIN=CL=10uF,Ta=25OC, unless otherwise noted) Parameter Symbol Conditions Min. Typ. Max. Units X 0.98 VOUT (T) (Note 1) X 1.02 V Output Voltage VOUT(E) (Note 2) IOUT=10mA, VIN= VOUT +1.5V Maximum Output Current IOUTMAX VIN= VOUT +1.5V 800 Load Regulation ∆VOUT VIN= VOUT +1.5V , 0mA≤IOUT≤800mA 5 VDIF1 IOUT =100mA 100 mV VDIF2 IOUT =500mA 520 mV VDIF3 IOUT =800mA 880 mV Quiescent Current Iss VIN= VOUT +1.5V 90 uA Line Regulation ∆VOUT ∆VIN • VOUT IOUT =0mA VOUT+1.5V ≤VIN≤15V 2 Dropout Voltage (Note 3) Ripple Rejection Rate PSRR VIN = 8.0V +1Vp-pAC IOUT=100mA,1kHZ 72 IOUT=200mA,1kHZ 68 IOUT=500mA,1kHZ 61 mA 10 5 mV mV dB Note : 1. VOUT (T) :Specified Output Voltage 2.VOUT (E) :Effective Output Voltage ( ie. The output voltage when “VOUT (T)+1.5V”is provided at the Vin pin while maintaining a certain Iout value.) 3.VDIF:VIN1 –VOUT (E)’ VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased. VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized Iout and {VOUT (T)+1.5V} is input. V05 www.microne.com.cn Page 4 of 11 ME6117 Type Characteristics (1) Output Voltage Change VS. Output Current (VIN=VOUT+1.5V, Ta = 25 °C) ME6117A33 (2) Output Voltage Change vs. Temperature (VIN=VOUT+1.5V , IOUT=10mA) ME6117A33 Output Voltage Change VS.Temperature 0.0 -0.1 -0.1 -0.2 Output Voltage Change(%) Output Voltage Change(%) Output Voltage Change VS. Output Current -0.2 -0.3 -0.3 -0.4 0 200 400 600 800 1000 2.00 1.50 1.00 0.50 0.00 -0.50 -1.00 -1.50 -2.00 1200 10 30 50 Output Current(mA) 70 90 110 130 150 Temperature(℃) (3)Droput Voltage VS. Output Current(Ta = 25 °C) (4)Ripple Rejection vs. Frequency(Io=100mA) ME6117A33 ME6117A33 Dropout Voltage VS.Output Current Ripple Rejection VS. Frequency 90 Ripple Rejection (dB) Dropout Voltage(V) 1200 1000 800 600 400 200 0 80 70 60 50 40 30 0 100 200 300 400 500 600 700 800 10 1000 10000 Frequency(Hz) Output Current (mA) V05 100 www.microne.com.cn Page 5 of 11 ME6117 (5)Output Voltage VS. Input Voltage(Ta = 25 °C) (6)Quiescent Current VS. Iutput Voltage ME6117A33 ME6117A33 Output Voltage VS. Input Voltage Quiescent Current VS. Input Voltage 150 3.330 140 Quiescent Current (uA) Output Voltage(V) 3.320 3.310 3.300 3.290 3.280 130 120 110 100 90 80 70 60 3.270 50 3 5 7 9 11 13 15 17 19 21 Input Voltage(V) 4 6 8 10 12 14 16 18 Input Voltage(V) (7)Line Transient Response ME6117A33 Ch1:Input Voltage Ch2:Output Voltage VIN=4.8V,IOUT=1000mA,Ta = 25 °C V05 2 (8)Load Transient Response ME6117A33 Ch1:Onput Voltage Ch2:Load Current VIN=4.8V,Ta = 25 °C www.microne.com.cn Page 6 of 11 ME6117 Applications Information 1. Input Bypass Capacitor An input capacitor is recommended.A 10uF tantalum on the input is a suitable input bypassing for almost all applications. 2. Output Capacitor The output capacitor is critical in maintaining regulator stability,and must meet the required conditions for both minimum amount of capacitance and ESR (Equivalent Series Resistance).The minimum output capacitance required by the ME6117 is 10µF,if a tantalum capacitor is used.Any increase of the output capacitance will merely improve the loop stability and transient response.The ESR of the output capacitor should be less than 0.5Ω . 3. Load Regulation The ME6117 regulates the voltage that appears between its output and ground pins,or between its output and adjust pins. In some cases, line resistances can introduce errors to the voltage across the load. To obtain the best load regulation, a few precautions are needed. Figure1, shows a typical application using a fixed output regulator.The Rt1 and Rt2 are the line resistances.It is obvious that the VLOAD is less than the VOUT by the sum of the voltage drops along the line resistances. In this case, the load regulation seen at the RLOAD would be degraded from the datasheet specification. To improve this , the load should be tied directly to the output terminal on the positive side and directly tied to the ground terminal on the negative side. FIGURE 1. Typical Application using Fixed Output Regulator V05 www.microne.com.cn Page 7 of 11 ME6117 Application Circuit (1)Regulator with Reference (2)Adjusting Output of Fixed Voltage Regulators (3)Battery Backed−Up Power Supply (4)Low Dropout Negative Supply V05 www.microne.com.cn Page 8 of 11 ME6117 Packaging Information ● SOT223 V05 www.microne.com.cn Page 9 of 11 ME6117 ● SOT89-3 V05 www.microne.com.cn Page 10 of 11 ME6117 l l l l l V05 The information described herein is subject to change without notice. Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. www.microne.com.cn Page 11 of 11
ME6117A50B3G 价格&库存
很抱歉,暂时无法提供与“ME6117A50B3G”相匹配的价格&库存,您可以联系我们找货
