WSF09N20
N-Ch MOSFET
General Description
Product Summery
The WSF09N20 is the highest performance trench
N-Ch MOSFET with extreme high cell density,which
provide excellent RDSON and gate charge for most
of the synchronous buck converter applications .
BVDSS
RDSON
ID
200V
0.21Ω
9A
Applications
The WSF09N20 meet the RoHS and Green
Product requirement , 100% EAS guaranteed with
full function reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
TO-252 Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=100℃
ID@TA=25℃
ID@TA=70℃
IDM
EAS
Rating
Units
Drain-Source Voltage
200
V
Gate-Source Voltage
±30
V
1
9
A
1
3.13
A
1
9
A
1
5.8
A
36
A
Single Pulse Avalanche Energy
320
mJ
A
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
3
IAS
Avalanche Current
9
PD@TC=25℃
Total Power Dissipation3
83
W
PD@Tc=100℃
47
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
30
℃/W
1.6
℃/W
Dec.2014
WSF09N20
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
200
V
0.25
VGS=10V , ID=4.5A
0.21
0.25
V/℃
Ω
VGS=6.0V , ID=3.6A
0.26
0.29
Ω
1.0
1.8
2.5
V
-4.63
mV/℃
VDS=200V , VGS=0V , TJ=25℃
1
VDS=160V , VGS=0V , TJ=125℃
10
VGS=0V , ID=250uA
Reference to 25℃ , ID=1mA
VGS=VDS , ID =250uA
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±30V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=30V , ID=4.5A
0.21
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2
4
Ω
11.8
2.36
Qg
Total Gate Charge (10V)
Qgs
Gate-Source Charge
Qgd
Td(on)
VDS=160V , VGS=10V , ID=9A
Gate-Drain Charge
3.98
Turn-On Delay Time
10.33
uA
nC
Rise Time
VDD=100V , VGS=10V ,
10.7
Turn-Off Delay Time
RG=10Ω ID=9A RL=10Ω
29.1
Fall Time
11.1
Ciss
Input Capacitance
509
Coss
Output Capacitance
51.2
Crss
Reverse Transfer Capacitance
3.2
Min.
Typ.
Max.
Unit
mJ
Tr
Td(off)
Tf
VDS=25V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=5A
320
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current
2,6
Pulsed Source Current
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Conditions
1,6
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=5A , TJ=25℃
IF=5A , dI/dt=100A/µs , TJ=25℃
Min.
Typ.
Max.
Unit
9
A
36
A
1.4
V
201
nS
663
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSF09N20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.27170
- 10+1.15020
- 30+1.06920
- 100+0.94770
- 500+0.89100
- 1000+0.85050
