KBP3005 THRU KBP310
SILICON BRIDGE RECTIFIERS
Reverse Voltage - 50 to 1000 Volts
FEATURES
KBP
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Ideal for printed circuit boards
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.600(15.24)
0.560(14.22)
0.460(11.68)
0.420(10.67)
0.460(11.68)
0.420(10.6)
0.035(0.9)DIA.
0.028(0.7)TPY.
0.05(1.27)
AC
Forward Current - 3.0 Amperes
0.640(16.25)
MIN
0.50(12.7)
MIN
MECHANICAL DATA
Case: Molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Mounting Position: Any
Weight:0.069 ounce, 1.95 grams
0.160(4.1)
0.140(3.6)
0.153(3.9)
0.146(3.7)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
output rectified current at
TC=50 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per birdge element at 1.5A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=125 C
Typical Thermal Resistance (Note 1)
Operating junction temperature range
storage temperature range
SYMBOLS
KBP
3005
KBP
301
KBP
302
KBP
304
KBP
307
KBP
308
KBP
310
UNITS
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
VOLTS
VOLTS
VOLTS
I(AV)
3.0
Amps
IFSM
80
Amps
VF
1.0
Volts
IR
10
0.5
µA
mA
RθJA
TJ
TSTG
30
-55 to +150
-55 to +150
NOTES: 1.Unit mounted on 0.47 x 0.47”(12x12mm) copper pads.
C/W
C
C
RATINGS AND CHARACTERISTIC CURVES KBP3005 THRU KBP310
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
很抱歉,暂时无法提供与“KBP307”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61042
- 50+0.51970
- 150+0.47304
- 500+0.34260
- 2500+0.32919
- 5000+0.32012
