PART CODE:
KBP3070000L360
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0729-KBP3070000L360
DATE
July 29, 2021
REVISION
A0
DESCRIPITION
Thru Hole Single Bridge Rectifier, KBP Series, KBP307 L Type, 4 Pins,
Reverse Voltage 700V Max. Forward Current 3.0A Max.
Operating Temp. Range -55°C ~+150°C,
Package in Bulk, 500pcs/Box
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
MDD KBP307 L
PART CODE
KBP3070000L360
VENDOR APPROVE
Issued/Checked/Approved
DATE: July 29, 2021
CUSTOMER APPROVE
DATE:
1
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
KBP3070000L360
THRU HOLE BRIDGE RECTIFER KBP SERIES
MAIN FEATURE
• The plastic package carries Underwriters Laboratory Flammability Classification 94V-0
• Glass passivated junction
• Low reverse leakage
• High forward surge current capability
• High temperature soldering guaranteed: 260 °C/10 seconds, 0.375” (9.5mm) lead length
(2.3kg) tension
APPLICATION
• For printed circuit board
RFQ
PART CODE GUIDE
Request For Quotation
KBP
3070000
L
360
1
2
3
4
1) KBP: Thru Hole Single Bridge Rectifier, KBP Series
2) 3070000: Type code for original part number KBP307 L
3) L: Package code, In Bulk, 500pcs/Box.
4) 360: Specification code for Reverse Voltage 600V Max. Forward Current 3.0A Max.
MORE ITEMS AVAILABLE
KBP2005000L205
KBP2010000L210
KBP2080000L280
KBP2100000L20A
KBP3005000L305
KPB3010000L310
KBP3080000L380
KPB3100000L30A
KBP2020000L220
KBP2040000L240
KBP2060000L260
KBP3020000L320
KBP3040000L340
KBP3070000L360
2
PART CODE:
KBP3070000L360
DIMENSION (Unit: Inch/mm)
Image for reference
Marking: KBP307
KBP
3
PART CODE:
KBP3070000L360
THRU HOLE
SMD SCHOTTKY
BRIDGE
SMD
RECTIFER
GENERAL
BARRIER
KBP
RECTIFER
RECTIFER
SERIES
MECHANICAL DATA
Case
Terminals
Polarity
Mounting
Position
Weight
per piece
JEDEC KBP molded
plastic body
Solder plated,
Solderable per
MIL-STD-750,
Method 2026
Polarity symbol
marking on body
Any
0.050 Ounce, 1.52
grams
MAX. RATING & CHARACTERISTICS
Parameter
SYMBOLS
VALUE
Min.
Typical
UNITS
Max.
Repetitive peak reverse voltage
V RRM
600
Volts
RMS voltage
V RMS
420
Volts
DC blocking voltage
V DC
600
Volts
Average forward output rectified current
I AV
3.0
A
at Tc= 100°C (see Note 3)
I FSM
Peak forward surge current 8.3ms single half
55
A
sine-wave superimposed on rated load
(JEDEC Method)
Instantaneous forward voltage at 3.0A
DC reverse current at rated DC
blocking voltage
TA=25℃
VF
1.10
Volts
IR
5.0
µA
500
mA
TA=125℃
Junction capacitance (Note 2)
Thermal resistance (Note 3)
Operating junction temperature range
Storage temperature range
CJ
40
pF
R QJA
40
°C/W
TJ
-55
+150
T STG
-55
+150
°C
Note
1. Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for
capacitive load current derate by 20%.
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3. Unit mounted on PCB with 0.47”*0.47”(12.0*12.0mm) copper pads , 0.375”(9.5mm) lead length
4
PART CODE:
KBP3070000L360
THRU HOLE BRIDGE
SMD
RECTIFER
GENERAL
KBP
RECTIFER
SERIES
RELIABILITY
Number
Experiment Items
Experiment Method And Conditions
Reference
Documents
1
Solder Resistance Test
Test 260°C± 5°C for 10 ± 2 sec.
Immerse body into solder 1/16” ± 1/32"
MIL-STD-750D
METHOD-2031.2
2
Solderability Test
230°C ±5°C for 5 sec.
MIL-STD-750D
METHOD-2026.1 0
3
Pull Test
1 kg in axial lead direction for 10 sec.
MIL-STD-750D
METHOD-2036.4
4
Bend Test
0.5Kg Weight Applied To Each Lead,
Bending Arcs 90 °C ± 5 °C For 3 Times
MIL-STD-750D
METHOD-2036.4
5
High Temperature Reverse
Bias Test
TA=100°C for 1000 Hours at VR=80%
Rated VR
MIL-STD-750D
METHOD-1038.4
6
Forward Operation Life Test
TA=25°C Rated Average Rectified
Current
MIL-STD-750D
METHOD-1027.3
7
Intermittent Operation Life
Test
On state: 5 min with rated IRMS Power
Off state: 5 min with Cool Forced Air.
On and off for 1000 cycles.
MIL-STD-750D
METHOD-1036.3
8
Pressure Cooker Test
15 PSIG, TA=121°C, 4 hours
MIL-S-19500
APPENOIXC
9
Temperature Cycling Test
-55°C~+125°C; 30 Minutes For Dwelled
Time 5 minutes for transferred time.
Total: 10 cycles.
MIL-STD-750D
METHOD-1051.7
10
Thermal Shock Test
0°C for 5 minutes., 100°C for 5minutes,
Total: 10 cycles
MIL-STD-750D
METHOD-1056.7
11
Forward Surge Test
8.3ms Single Sale Sine-wave One Surge.
MIL-STD-750D
METHOD-4066.4
12
Humidity Test
TA=65°C, RH=98% for 1000 hours.
MIL-STD-750D
METHOD-1021.3
13
High Temperature Storage
life Test
150°C for 1000 Hours
MIL-STD-750D
METHOD-1031.5
5
PART CODE:
KBP3070000L360
RATINGS AND CHARACTERISTIC CURVES (For Reference Only)
6
PART CODE:
KBP3070000L360
PACKAGE
Part
Type
Qty. Per Box
(pcs)
Inner Box
L*W*H
(mm)
Carton size
L*W*H
(mm)
Qty. Per Carton
(pcs)
G. W
(kg)
KBP
500
300*110*32
315*245*190
5,000
8.25
DISCLAIMER
NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein
without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany
the sale of any such product(s) or information
7
很抱歉,暂时无法提供与“KBP307 L”相匹配的价格&库存,您可以联系我们找货
