74AHC3GU04
Triple unbuffered inverter
Rev. 6 — 27 February 2019
Product data sheet
1. General description
The 74AHC3GU04 is a high-speed Si-gate CMOS device. This device provides three inverter gates
with unbuffered outputs.
2. Features and benefits
Symmetrical output impedance
High noise immunity
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101D exceeds 1000 V
Low power dissipation
Balanced propagation delays
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74AHC3GU04DP
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package;
8 leads; body width 3 mm; lead length 0.5 mm
SOT505-2
74AHC3GU04DC
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
4. Marking
Table 2. Marking codes
Type number
Marking code [1]
74AHC3GU04DP
AU4
74AHC3GU04DC
AU4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AHC3GU04
Nexperia
5. Functional diagram
1
1A
1Y
1
1
7
3
1
5
6
1
2
7
3
2A
2Y
5
6
3A
3Y
2
A
mna720
Fig. 1.
Logic symbol
Y
mna721
Fig. 2.
mna045
IEC logic symbol
Fig. 3.
Logic diagram (one gate)
6. Pinning information
6.1. Pinning
74AHC3GU04
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aaj517
Fig. 4.
Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
GND
4
ground (0 V)
1Y, 2Y, 3Y
7, 5, 2
data output
VCC
8
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
A
Y
L
H
H
L
74AHC3GU04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 13
74AHC3GU04
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
VI
input voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V
[1]
-20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±25
mA
ICC
supply current
75
mA
IGND
ground current
-75
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
Min
Typ
Max
Unit
2.0
5.0
5.5
V
[1]
[2]
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 3.3 V ± 0.3 V
100
ns/V
VCC = 5.0 V ± 0.5 V
ns/V
74AHC3GU04
Product data sheet
3 / 13
74AHC3GU04
Nexperia
10. Static characteristics
Table 7. Static characteristics
Symbol Parameter
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 3.0 V
2.4
2.4
2.4
V
VCC = 5.5 V
4.4
4.4
4.4
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 3.0 V
0.6
0.6
0.6
V
VCC = 5.5 V
1.1
1.1
1.1
V
IO = -50 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -50 μA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = -50 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = -8.0 mA; VCC = 4.5 V
3.94
3.8
3.70
V
IO = 50 μA; VCC = 2.0 V
0.1
0.1
V
IO = 50 μA; VCC = 3.0 V
0.1
0.1
V
IO = 50 μA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
μA
CI
input
capacitance
3.0
10
10
10
pF
74AHC3GU04
Product data sheet
4 / 13
74AHC3GU04
Nexperia
10.1. Typical transfer characteristics
mna397
2.0
VO
(V)
1.6
mna398
1.0
VO
ICC
(mA)
0.8
1.2
0.6
0.8
0.4
3.0
10
VO
VO
(V)
8
ICC
(mA)
6
1.5
0.4
ID (drain current)
ID (drain current)
0.2
0.8
1.2
1.6
VI (V)
2
a. VCC = 2.0 V; IO = 0 A
1
2
VI (V)
3
b. VCC = 3.0 V; IO = 0 A
mna399
6
50
VO
(V)
ICC
(mA)
40
VO
30
3
ID (drain current)
10
4
VI (V)
6
c. VCC = 5.5 V; IO = 0 A
Fig. 5.
74AHC3GU04
Product data sheet
5 / 13
74AHC3GU04
Nexperia
mna400
40
gfs
(mA/V)
30
Rbias = 560 kΩ
VCC
0.47 µF
10
input
output
100 µF
VI
(f = 1 kHz)
Fig. 6.
A IO
GND
4
VCC (V)
mna050
6
Typical forward transconductance gfs as a
function of the supply voltage at Tamb = 25 °C
gfs = ΔIO/ΔVI at VO is constant
Fig. 7.
Test set-up for measuring forward
transconductance
11. Dynamic characteristics
Table 8. Dynamic characteristics
GND = 0 V; For test circuit see Fig. 9.
Symbol Parameter
tpd
propagation
delay
CPD
[1]
[2]
[3]
[4]
power
dissipation
capacitance
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 3.0 V to 3.6 V; CL = 15 pF [2]
3.0
7.1
1.0
8.5
1.0
10.0 ns
VCC = 3.0 V to 3.6 V; CL = 50 pF [2]
4.3
10.6
1.0
12.0
1.0
13.5 ns
VCC = 4.5 V to 5.5 V; CL = 15 pF [3]
2.5
5.5
1.0
6.0
1.0
7.0
ns
VCC = 4.5 V to 5.5 V; CL = 50 pF [3]
3.5
7.0
1.0
8.0
1.0
9.0
ns
4
pF
nA to nY; see Fig. 8
[1]
per buffer; VI = GND to VCC
[4]
tpd is the same as tPLH and tPHL.
Typical values are measured at VCC = 3.3 V.
Typical values are measured at VCC = 5.0 V.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of the outputs.
74AHC3GU04
Product data sheet
6 / 13
74AHC3GU04
Nexperia
11.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
VM
nY output
VM
VOL
mna344
Measurement points are given in Table 9.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 8.
The input (nA) to output (nY) propagation delays.
Table 9. Measurement points
Input
Output
VM
VM
0.5VCC
0.5VCC
VI
negative
pulse
tW
90 %
VM
VM
10 %
0V
tf
tr
VI
positive
pulse
0V
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RL
RT
S1
open
CL
001aad983
Test data is given in Table 10.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 9.
Test circuit for measuring switching times
Table 10. Test data
Input
Load
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
VCC
≤ 3 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74AHC3GU04
Product data sheet
S1 position
7 / 13
74AHC3GU04
Nexperia
12. Application information
Some applications are:
Linear amplifier (see Fig. 10)
In crystal oscillator design (see Fig. 11)
Remark: All values given are typical unless otherwise specified.
R2
VCC
1 µF
R1
R1
U04
ZL
R2
U04
mna052
out
Maximum Vo(p-p) = VCC - 1.5 V centered at
0.5 × VCC.
C2
mna053
C1 = 47 pF (typ.)
C2 = 22 pF (typ.)
R1 = 1 MΩ to 10 MΩ (typ.)
R2 optimum value depends on the frequency
and required stability against changes in VCC or
average minimum ICC (ICC is typically 2 mA at
VCC = 3 V and f = 1 MHz).
Gol = open loop gain
Gv = voltage gain
R1 ≥ 3 kΩ, R2 ≤ 1 MΩ
ZL > 10 kΩ; Gol = 20 (typ.)
Typical unity gain bandwidth product is 5 MHz.
Fig. 10. Used as a linear amplifier
C1
Fig. 11. Crystal oscillator configuration
Table 11. External components for resonator (f < 1 MHz)
All values given are typical and must be used as an initial set-up.
Frequency
R1
R2
C1
C2
10 kHz to 15.9 kHz
22 MΩ
220 kΩ
56 pF
20 pF
16 kHz to 24.9 kHz
22 MΩ
220 kΩ
56 pF
10 pF
25 kHz to 54.9 kHz
22 MΩ
100 kΩ
56 pF
10 pF
55 kHz to 129.9 kHz
22 MΩ
100 kΩ
47 pF
5 pF
130 kHz to 199.9 kHz
22 MΩ
47 kΩ
47 pF
5 pF
200 kHz to 349.9 kHz
22 MΩ
47 kΩ
47 pF
5 pF
350 kHz to 600 kHz
22 MΩ
47 kΩ
47 pF
5 pF
Table 12. Optimum value for R2
Frequency
R2
3 kHz
6 kHz
10 kHz
14 kHz
>14 kHz
74AHC3GU04
Product data sheet
Optimum for
2.0 kΩ
minimum required ICC
8.0 kΩ
minimum influence due to change in VCC
1.0 kΩ
4.7 kΩ
minimum influence by VCC
0.5 kΩ
2.0 kΩ
0.5 kΩ
1.0 kΩ
replace R2 by C3 with a typical value of 35 pF
8 / 13
74AHC3GU04
Nexperia
13. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 12. Package outline SOT505-2 (TSSOP8)
74AHC3GU04
Product data sheet
9 / 13
74AHC3GU04
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 13. Package outline SOT765-1 (VSSOP8)
74AHC3GU04
Product data sheet
10 / 13
74AHC3GU04
Nexperia
14. Abbreviations
Table 13. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
15. Revision history
Table 14. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AHC3GU04 v.6
20190227
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74AHC3GU04GD (SOT996-2) removed.
Package outline drawing SOT765-1 (VSSOP8) updated
74AHC3GU04 v.5
20130508
Modifications:
74AHC3GU04 v.4
20100107
74AHC3GU04 v.5
Product data sheet
74AHC3GU04 v.4
For type number 74AHC3GU04GD XSON8U has changed to XSON8.
Product data sheet
74AHC3GU04 v.3
Marking code for 74AHC3GU04DP package changed from AU04 to AU4
74AHC3GU04 v.3
20090126
Product data sheet
74AHC3GU04 v.2
74AHC3GU04 v.2
20040923
Product specification
74AHC3GU04 v.1
74AHC3GU04 v.1
20040305
74AHC3GU04
Product data sheet
11 / 13
74AHC3GU04
Nexperia
16. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AHC3GU04
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
74AHC3GU04
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 1
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 2
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................4
10.1. Typical transfer characteristics.................................. 5
11. Dynamic characteristics.............................................6
11.1. Waveforms and test circuit........................................ 7
12. Application information............................................. 8
13. Package outline.......................................................... 9
14. Abbreviations............................................................ 11
15. Revision history........................................................11
16. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 27 February 2019
74AHC3GU04
Product data sheet
13 / 13
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC3GU04DC,125 74AHC3GU04DP,125 74AHC3GU04GD,125
