74LVC2G17-Q100
Dual non-inverting Schmitt trigger with 5 V tolerant input
Rev. 3 — 14 December 2016
Product data sheet
1. General description
The 74LVC2G17-Q100 provides two non-inverting buffers with Schmitt trigger input. It is
capable of transforming slowly changing input signals into sharply defined, jitter-free
output signals.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these
devices as translators in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD-8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
24 mA output drive (VCC = 3.0 V)
CMOS low-power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
3. Applications
Wave and pulse shapers for highly noisy environments
74LVC2G17-Q100
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC2G17GW-Q100
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC2G17GV-Q100
40 C to +125 C
TSOP6
plastic surface-mounted package (TSOP6); 6 leads SOT457
5. Marking
Table 2.
Marking codes
Type number
Marking code[1]
74LVC2G17GW-Q100
VV
74LVC2G17GV-Q100
VV
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
PQE
Fig 1.
PQE
Logic symbol
Fig 2.
IEC logic symbol
PQE
Fig 3.
Logic diagram
74LVC2G17_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
74LVC2G17-Q100
Nexperia
7. Pinning information
7.1 Pinning
/9&*4
*1'
9&&
DDD
Fig 4.
Pin configuration SOT363 and SOT457
7.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
8. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
74LVC2G17_Q100
Product data sheet
3 of 16
74LVC2G17-Q100
Nexperia
9. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
mA
0.5
+6.5
V
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
VO < 0 V
IO
output current
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
300
mW
[1]
VO = 0 V to VCC
V
Tamb = 40 C to +125 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
10. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
74LVC2G17_Q100
Product data sheet
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
VCC
V
40
+125
C
4 of 16
74LVC2G17-Q100
Nexperia
11. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 40 C to +85
VOL
VOH
Conditions
Min
Typ
Max
Unit
IO = 100 A; VCC = 1.65 V to 5.5 V
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
V
IO = 8 mA; VCC = 2.3 V
0.3
V
C[1]
LOW-level output voltage
HIGH-level output voltage
VI = VT+ or VT
IO = 12 mA; VCC = 2.7 V
0.4
V
IO = 24 mA; VCC = 3.0 V
0.55
V
IO = 32 mA; VCC = 4.5 V
0.55
V
VI = VT+ or VT
VCC 0.1
V
1.2
V
1.9
V
2.2
V
2.3
V
3.8
V
II
input leakage current
VI = 5.5 V or GND; VCC = 5.5 V
0.1
1
A
IOFF
power-off leakage current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
0.1
4
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
A
CI
input capacitance
3.5
pF
0.1
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
VCC 0.1
V
0.95
V
VOL
VOH
VI = VT+ or VT
VI = VT+ or VT
74LVC2G17_Q100
Product data sheet
1.7
V
1.9
V
2.0
V
3.4
V
5 of 16
74LVC2G17-Q100
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ
Max
II
IOFF
0.1
1
A
2
A
ICC
supply current
VCC = 5.5 V
4
A
ICC
500
A
[1]
Unit
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
12. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6.
Symbol Parameter
tpd
40 C to +85 C
Conditions
Max
Min
Max
VCC = 1.65 V to 1.95 V
1.5
5.6
10.5
1.5
13.1
VCC = 2.3 V to 2.7 V
1.0
3.7
6.5
1.0
8.5
ns
VCC = 2.7 V
1.0
3.8
6.5
1.0
8.5
ns
VCC = 3.0 V to 3.6 V
1.0
3.6
5.7
1.0
7.1
ns
1.0
2.7
4.3
1.0
5.4
ns
16.3
pF
propagation delay nA to nY; see Figure 5
[1]
power dissipation
capacitance
Unit
Typ[1]
[2]
VCC = 4.5 V to 5.5 V
CPD
40 C to +125 C
Min
per buffer; VCC = 3.3 V;
VI = GND to VCC
[3]
ns
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74LVC2G17_Q100
Product data sheet
6 of 16
74LVC2G17-Q100
Nexperia
13. Waveforms
9,
Q$LQSXW
90
90
*1'
W3/+
W3+/
92+
90
Q
很抱歉,暂时无法提供与“74LVC2G17GV-Q100H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.102001+0.37630
- 10+2.5072010+0.30420
- 100+1.45770100+0.17690
- 1000+0.965601000+0.11720
- 3000+0.755703000+0.09170
- 9000+0.747509000+0.09070
- 24000+0.6880024000+0.08350
- 45000+0.6799045000+0.08250
- 99000+0.6635099000+0.08050
