PSMN7R0-30YLC
N-channel 30 V 7.1 mΩ logic level MOSFET in LFPAK using NextPower technology
Table 1.
Quick reference data …continued
Symbol
Parameter
Conditions
Min
Typ
Max Unit
Dynamic characteristics
QGD
gate-drain charge
VGS = 4.5 V; ID = 20 A;
VDS = 15 V; see Figure 14;
see Figure 15
2.5
nC
QG(tot)
total gate charge
see Figure 15
7.9
nC
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
S
source
Simplified outline
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to drain
Graphic symbol
mb
D
G
mbb076
S
1 2 3 4
SOT669 (LFPAK;
Power-SO8)
3. Ordering information
Table 3.
Type number
Package
Name
Description
Version
PSMN7R0-30YLC
LFPAK; Power-SO8
plastic single-ended surface-mounted package; 4 leads
SOT669
PSMN7R0-30YLC
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
30
V
VDGR
drain-gate voltage
25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ
30
V
VGS
gate-source voltage
ID
drain current
-20
V
VGS = 10 V; Tmb = 25 °C; see Figure 1
61
A
VGS = 10 V; Tmb = 100 °C; see Figure 1
43
A
IDM
peak drain current
pulsed; tp ≤ 10 µs; Tmb = 25 °C;
see Figure 4
245
A
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
48
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Tsld(M)
peak soldering temperature
VESD
electrostatic discharge voltage
260
°C
MM (JEDEC JESD22-A115)
190
V
Source-drain diode
IS
source current
Tmb = 25 °C
44
A
ISM
peak source current
245
A
VGS = 10 V; Tj(init) = 25 °C; ID = 61 A;
Vsup ≤ 30 V; RGS = 50 Ω; unclamped;
see Figure 3
15
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
003a a g120
80
ID
(A)
03na19
120
Pder
60
80
40
40
Fig 1.
50
100
150
200
Tmb (C)
Continuous drain current as a function of
mounting base temperature
PSMN7R0-30YLC
Product data sheet
100
150
200
Tmb (°C)
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
All information provided in this document is subject to legal disclaimers.
Rev. 2 — 1 September 2011
Nexperia B.V. 2017. All rights reserved
3 of 15
PSMN7R0-30YLC
003aag121
102
IAL
(A)
(1)
10
(2)
1
10-3
Fig 3.
10-2
10-1
1
tAL (ms)
10
Single pulse avalanche rating; avalanche current as a function of avalanche time
003a a g122
103
ID
(A)
Limit R DS on = VDS / ID
102
tp =10 s
100 s
DC
10
1 ms
10 ms
1
100 ms
10-1
10-1
Fig 4.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PSMN7R0-30YLC
Product data sheet
4 of 15
PSMN7R0-30YLC
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from junction to mounting base
see Figure 5
2.9
3.13
K/W
003a a g123
10
Zth(j-mb)
(K/W)
= 0.5
1
0.2
0.1
0.05
P
10-1
0.02
tp
T
s ingle s hot
t
tp
T
10-2
10-6
Fig 5.
10-5
10-4
10-3
10-2
10-1
tp (s )
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN7R0-30YLC
Product data sheet
5 of 15
PSMN7R0-30YLC
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V
Static characteristics
V(BR)DSS
drain-source breakdown
voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
ID = 250 µA; VGS = 0 V; Tj = -55 °C
27
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10
1.05
1.58
1.95
V
ID = 10 mA; VDS = VGS; Tj = 150 °C;
see Figure 11
0.5
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 11
2.35
V
IDSS
drain leakage current
VDS = 30 V; VGS = 0 V; Tj = 25 °C
1
µA
VDS = 30 V; VGS = 0 V; Tj = 150 °C
100
µA
IGSS
gate leakage current
VGS = 16 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -16 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 4.5 V; ID = 20 A; Tj = 25 °C;
see Figure 12
7.6
8.9
mΩ
VGS = 4.5 V; ID = 20 A; Tj = 150 °C;
see Figure 12; see Figure 13
14.7
mΩ
VGS = 10 V; ID = 20 A; Tj = 25 °C;
see Figure 12
6
7.1
mΩ
VGS = 10 V; ID = 20 A; Tj = 150 °C;
11.8
mΩ
f = 1 MHz
2.2
4.4
Ω
ID = 20 A; VDS = 15 V; VGS = 10 V;
see Figure 14; see Figure 15
16
nC
ID = 20 A; VDS = 15 V; VGS = 4.5 V;
7.9
nC
ID = 0 A; VDS = 0 V; VGS = 10 V;
see Figure 15
14
nC
2.7
nC
1.7
nC
1
nC
RDSon
RG
drain-source on-state
resistance
gate resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGS(th)
pre-threshold gate-source
charge
QGS(th-pl)
post-threshold gate-source
charge
QGD
gate-drain charge
2.5
nC
VGS(pl)
gate-source plateau voltage
ID = 20 A; VDS = 15 V; see Figure 14;
see Figure 15
2.77
V
Ciss
input capacitance
1057
pF
Coss
output capacitance
VDS = 15 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 16
235
pF
Crss
reverse transfer capacitance
77
pF
PSMN7R0-30YLC
Product data sheet
6 of 15
PSMN7R0-30YLC
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
td(on)
turn-on delay time
15
ns
tr
rise time
VDS = 15 V; RL = 0.75 Ω; VGS = 4.5 V;
RG(ext) = 4.7 Ω
18
ns
td(off)
turn-off delay time
ns
tf
fall time
Qoss
output charge
7.5
ns
VGS = 0 V; VDS = 15 V; f = 1 MHz;
Tj = 25 °C
6.4
nC
Source-drain diode
VSD
source-drain voltage
IS = 20 A; VGS = 0 V; Tj = 25 °C;
see Figure 17
0.86
1.1
V
trr
reverse recovery time
25
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs;
13
nC
ta
reverse recovery rise time
16
ns
tb
reverse recovery fall time
9
ns
VGS = 0 V; IS = 20 A;
dIS/dt = -100 A/µs; VDS = 15 V;
see Figure 18
003a a g124
80
RDS on
(m)
10 4.5
ID
(A)
003a a g125
15
60
3.0
10
2.8
40
2.6
5
VGS (V) =2.4
2.2
2
3
4
4
8
12
VDS (V)
Fig 6.
Output characteristics; drain current as a
function of drain-source voltage; typical values
PSMN7R0-30YLC
Product data sheet
Fig 7.
VGS (V)
16
Drain-source on-state resistance as a function
of gate-source voltage; typical values
7 of 15
PSMN7R0-30YLC
003a a g126
100
gfs
(S )
003a a g127
80
ID
(A)
80
60
60
40
40
Tj = 150 C
Fig 8.
60
I D (A)
80
Forward transconductance as a function of
drain current; typical values
003a a g128
10-1
ID
(A)
10
Tj = 25 C
Fig 9.
2
3
VGS (V)
4
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
003a a g129
3
VGS (th)
(V)
-2
1
Max (1mA)
I D = 5mA
Min
10-3
2
Typ Max
1mA
10-4
1 Min (5mA)
10-5
10-6
2
VGS (V)
3
Fig 10. Sub-threshold drain current as a function of
gate-source voltage
PSMN7R0-30YLC
Product data sheet
120
Tj (C)
180
Fig 11. Gate-source threshold voltage as a function of
8 of 15
PSMN7R0-30YLC
003a a g130
30
RDS on
(m)
25
003a a g131
2
3.0
2.8
a
4.5V
1.5
VGS=10V
15
VGS (V) = 3.5
10
1
4.5
0.5
10
5
60
I D (A)
80
Fig 12. Drain-source on-state resistance as a function
of drain current; typical values
120
180
Fig 13. Normalized drain-source on-state resistance
factor as a function of junction temperature
003a a g132
10
VDS
Tj (C)
VGS
(V)
ID
8
VGS(pl)
6
24V
VGS(th)
VGS
15V
VDS = 6V
4
QGS1
QGS2
QGS
QGD
QG(tot)
2
003aaa508
Fig 14. Gate charge waveform definitions
PSMN7R0-30YLC
Product data sheet
4
8
12
16
QG (nC)
Fig 15. Gate-source voltage as a function of gate
charge; typical values
9 of 15
PSMN7R0-30YLC
003a a g133
104
003a a g134
80
IS
(A)
C
(pF)
60
Cis s
103
40
Cos s
102
Crs s
Tj = 150 C
10
10-1
1
10
VDS (V)
Tj = 25 C
Fig 16. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
0.3
0.6
0.9
VS D (V)
1.2
Fig 17. Source current as a function of source-drain
003a a f 444
ID
(A)
trr
ta
tb
0.25 IRM
I RM
t (s )
Fig 18. Reverse recovery timing definition
PSMN7R0-30YLC
Product data sheet
10 of 15
PSMN7R0-30YLC
7. Package outline
Plastic single-ended surface-mounted package (LFPAK; Power-SO8); 4 leads
A2
A
E
SOT669
C
c2
b2
E1
b3
L1
mounting
base
b4
D1
D
H
L2
1
2
3
e
4
w M A
b
1/2
X
c
e
A
(A 3)
A1
C
θ
L
detail X
y C
5 mm
scale
DIMENSIONS (mm are the original dimensions)
A
UNIT
A1
A2
A3
b
b2
1.20 0.15 1.10
0.50 4.41
0.25
1.01 0.00 0.95
0.35 3.62
mm
b3
b4
2.2
2.0
0.9
0.7
c
D (1)
c2
D1(1)
E(1) E1(1)
max
0.25 0.30 4.10
4.20
0.19 0.24 3.80
5.0
4.8
3.3
3.1
e
H
L
L1
L2
w
y
θ
1.27
6.2
5.8
0.85
0.40
1.3
0.8
1.3
0.8
0.25
0.1
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT669
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
06-03-16
11-03-25
MO-235
Fig 19. Package outline SOT669 (LFPAK; Power-SO8)
PSMN7R0-30YLC
Product data sheet
11 of 15
PSMN7R0-30YLC
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN7R0-30YLC v.2
20110901
Product data sheet
PSMN7R0-30YLC v.1
Modifications:
PSMN7R0-30YLC v.1
PSMN7R0-30YLC
Product data sheet
Status changed from objective to product.
Various changes to content.
20110711
Objective data sheet
12 of 15
PSMN7R0-30YLC
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
9. Legal information
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to the accuracy
or completeness of information included herein and shall have no liability for
the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
PSMN7R0-30YLC
Product data sheet
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of a Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the product
for such automotive applications, use and specifications, and (b) whenever
13 of 15
PSMN7R0-30YLC
customer uses the product for automotive applications beyond Nexperia’
specifications such use shall be solely at customer’s own risk, and (c)
customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PSMN7R0-30YLC
Product data sheet
14 of 15
PSMN7R0-30YLC
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .5
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12
Legal information. . . . . . . . . . . . . . . . . . . . . . . .13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14
Contact information. . . . . . . . . . . . . . . . . . . . . .14
Date of release: 01 September 2011
