XT30UPB-M
XT30UPB-M
    AMASS(艾迈斯)
    CONN_10.2X5.2MM_TM
    电源连接器 500V 15A 2Pins
XT30UPB-M 数据手册
c/J• 0 - il*~ ~iiJc:::> CHIC 7;::~1iU $JT :ZERQTECH • 1 11!: 1 f!l 1 !2 ninebot Persor: ran p lrtatlon Robot YUnc.c.~ ELECTR I C A V I AT I ON L\.LIGN Conquer Your Heart cHERVo H · 6 l"ilZOI" Parrof .;JP J>fl!lli!!it1''1'JiiHI ·~•U •~ • •••••. 1:.?"1'!Jtb rr-;;1!1 o't:lt!ilrntil!ix: n.~ mrr"ff2'!llil 7' L: 11! llllill: 213m This ls to certify that reprttenta tlve samplet of ~>0~111:. tr;JS:1f·~·ffl m-Jti£ IB: *LJ!il'l i'!i'f ~ lti/;0!1! Have been investigated by UL in ac.cordance with the Standard(s) indicated on this Certificate. il.iiE/i±llllfilE!I >lffltlii#BUi~~n (Material & Parameter) fE~~~(ltem No) XT60-M ltem No. ~@, Wi!W~ FR LEVEL 2.00 5.00 ~~M~ B!l.i.?t.\w~& USE TIMES _J 0 0 3 15.70 lOOOTIMES 0 q LI") DC SOOV - Plastic Material 20.20 8.10 11.00 M Wj~Eg)Jit Metal Material B!l.i.?t.\w~& O.SSmO ~@, DC SOOV Plastic Material 13.95 9.00 XT60-F ltem No. COLOR ~~M~ XT SERIERS fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60-F ltem No. ~;JU~ (Patent) 201530416577.6 ~9~ I f'FiU TEMPERATURE -20°c to 120°c ~i.A.iil: If'FiU CERTIFICATION TEMPERATURE -20°c to 120°c 15/16 XT ~.,SS ~9~ XT SERIERS fE~~tm!J)Ui~~n (Material & Parameter) fE~~~(ltem No) XT60U-F ;rr~~-'5- XT60U-F XT P.~.,SS XT SERIERS fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60UPB-F ;rr~~-'5- 0.45m0 ltem No. ~@, ~9~ XT60UPB-F 0.30m0 ltem No. .. ~@, DC SOOV 3 COLOR DC SOOV COLOR 30A ~:JU~ (Patent) 201530451153.3 BPlmmi (Drawing) Brass Gold Plated RC ~!S~M~ PA ~B1Eg)Jit Plastic Material 17.20 7.90 Metal Material 30A ~:JU~ (Patent) --- 60A BPlmmi (Drawing) MC 7.70 B.§i.?t.\w~& UL94 VO FR LEVEL ttE'FT fief§ ));:~ 2.10 EgitP. ttE'FT~nll Recommend USE BATIERY Cable SPEC. ~!S~M~ PA RC ~B1Eg)Jit 60A MC 7.70 B.§i.?t.\w~& lOOOTIMES USE TIMES ttE'FTmm Brass Gold Plated Plastic Material 15.60 7.90 13.50 Metal Material UL94 VO FR LEVEL 12AWG 0 ttE'FT fief§ ));:~ lOOOTIMES USE TIMES ttE'FTmm EgitP. ttE'FT~nll Recommend USE BATIERY Cable SPEC. 3i.'nl\i,A.l:iE CE/ UL If'Figfit PCB M .,f 3i.'nl\i,A.iil: If'Figfit CE/ UL CERTIFICATION ;rr~~-'5- r!.J TEMPERATURE CERTIFICATION fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60U-M e -20°( to 120°C XT60U-M TEMPERATURE fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60UPB-M ;rr~~-'5- 0.45m0 ltem No. ~@, XT60UPB-M 0.30m0 ltem No. .. ~@, DC SOOV 3 COLOR DC SOOV 3 COLOR 30A ~:JU~ (Patent) 201530451153.3 BPlmmi (Drawing) Metal Material Brass Gold Plated RC ~!S~M~ PA ~B1Eg)Jit Plastic Material 17.20 13.50 60A BPlmmi (Drawing) MC 15.60 7.90 UL94 VO FR LEVEL ttE'FT fief§ ));:~ Recommend USE CONTROLLER ~i,A.iil: CE/ UL CERTIFICATION lOOOTIMES USE TIMES ftE'FT~nl\ www.china-amass.com 30A ~:JU~ (Patent) --- 7.90 B.§i.?t.\ w~& -20°C to 120°C I f'FiU Brass Gold Plated ~!S~M~ PA Plastic Material ~B1Eg)Jit 60A 2.10 B.§i.?t.\w~& UL94 VO ttE'FT fief§ ));:~ ftE'FT~nl\ Recommend USE CONTROLLER/ CHARGER ~i,A.iil: CE/ UL CERTIFICATION lOOOTIMES USE TIMES 12AWG -20°c to 120°c RC MC FR LEVEL Cable SPEC. TEMPERATURE Metal Material PCB Cable SPEC. If'FiU -20°c to 120°c TEMPERATURE 17/18 XT ~.,SS ~9~ XT SERIERS fE~~tm!J)Ui~~n (Material & Parameter) fE~~~(ltem No) XT60PW-F ;rr~~-'5- XT60PW-F XT P.~.,SS ~9~ XT SERIERS fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60PT-F ;rr~~-'5- O.SOmO ltem No. XT60PT-F O.SOmO ltem No. ~@, ~@, DC SOOV COLOR DC SOOV COLOR 30A ~:JU~(Patent) 201530511914.X BPlmmi (Drawing) 2.10 Brass Gold Plated RC ~!S~M~ PA ~B1Eg)Jit Plastic Material 17.70 8.10 Metal Material 7.70 B.§i.?t.\w~& 0 '-'! 0 N r....: 60A BPlmmi (Drawing) MC UL94 VO FR LEVEL I../") 30A ~:JU~ (Patent) 201630023590.X ftE§'fleffl ));:~ EgJtP. ttE'FT~~lll Recommend USE BATIERY Cable SPEC. 1000 TIMES 8.40 PCB 0 Lf) CE/ UL CERTIFICATION If'Figfit ;rr~~-'5- 0 ~B1Eg)Jit rti UL94 VO ftE§'fleffl ));:~ ttE'FTmm EgJtP. ttE'FT~~lll Recommend USE BATIERY Cable SPEC. 3i.'~ll\i,A. l:iE CE/ UL If'Figfit PCB -20°C to 120°C TEMPERATURE fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60PT-M ;rr~~-'5- O.SOmO XT60PT-M O.SOmO ltem No. ~@, DC SOOV 3 DC SOOV 3 COLOR 30A BPlmmi (Drawing) 1000 TIMES USE TIMES CERTIFICATION COLOR ~:JU~(Patent) 201530511914.X 60A MC CXl r...: ltem No. ~@, RC 0 N TEMPERATURE XT60PW-M PA FR LEVEL -20°( to 120°C fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60PW-M ~!S~M~ B.§i.?t.\w~& 21.70 19.80 9.35 7.70 LI) 3i.'~ll\i,A.iil: Brass Gold Plated Plastic Material USE TIMES ttE'FTmm Metal Material Metal Material Brass Gold Plated RC ~!S~M~ PA ~B1Eg)Jit Plastic Material 30A ~:JU~ (Patent) 201630023587.8 60A BPlmmi (Drawing) MC Metal Material Brass Gold Plated ~!S~M~ PA Plastic Material RC ~B1Eg)Jit 60A MC 18.10 8.10 2.10 B.§i.?t.\w~& UL94 VO FR LEVEL ftE§'fleffl ));:~ B.§i.?t.\w~& 1000 TIMES USE TIMES 8.40 22.70 20.80 UL94 VO FR LEVEL ftE§'fleffl ));:~ 1000 TIMES USE TIMES 10.35 ftE§'~~ Recommend USE 0 M "Ui~~n (Material & Parameter) fE~~~(ltem No) XT60L-F ;rr~~-'5- O.SOmO ltem No. XT60L-F O.SOmO ltem No. ~@, ~@, DC SOOV COLOR DC SOOV COLOR 30A ~:JU~ (Patent) 201530348205.4 BP!mmi (Drawing) Metal Material Brass Gold Plated RC ~@~M~ PA ~B1Eg)Jit Plastic Material 9.20 \Ci 0 r....: B.§m\w~& UL94 VO ttE'FT fief§ ));:~ EgitP. ttE'FT~~lll Recommend USE BATIERY Cable SPEC. CE/ UL CERTIFICATION If'!=)gfit 12AWG 0 0 \Ci r....: 0\ N -20°( to 120°C TEMPERATURE XT60H-M ~@~M~ PA B.§m\w~& RC ~B1Eg)Jit UL94 VO ttE'FT fief§ ));:~ USE TIMES ttE'FTmm EgitP. ttE'FT~~lll Recommend USE BATIERY Cable SPEC. 3i.'~llli.AJiE CE/ UL If'!=)gfit ;rr~~-'5- O.SOmO ~@, DC SOOV 3 XT60L-M O.SOmO DC SOOV 3 COLOR Metal Material Brass Gold Plated RC ~@~M~ PA ~B1Eg)Jit UL94 VO \Ci r....: ttE'FT~ml Recommend USE CONTROLLER ~i,A.iil: CE/ UL CERTIFICATION www.china-amass.com ttE'FT fief§ ));:~ lOOOTIMES If'!=iU 23.80 20.50 Metal Material Brass Gold Plated ~@~M~ PA Plastic Material B.§m\w~& UL94 VO ~B1Eg)Jit ttE'FT fief§ ));:~ ttE'FT~ml Recommend USE CONTROLLER/ CHARGER ~i,A.lil: CE/ UL CERTIFICATION 60A lOOOTIMES USE TIMES 12AWG -20°c to 120°c RC MC FR LEVEL Cable SPEC. TEMPERATURE BP!mmi (Drawing) 10.10 USE TIMES Oo '=:!° N 60A MC FR LEVEL 30A ~:JU~ (Patent) 201520067495.X 23.80 20.50 B.§m\ w~& -20°C to 120°C ltem No. Plastic Material 9.20 12AWG TEMPERATURE 30A BP!mmi (Drawing) lOOOTIMES fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT60L-M COLOR ~:JU~ (Patent) 201530348205.4 60A MC CERTIFICATION ltem No. ~@, Brass Gold Plated FR LEVEL fE~~tm!J>Ui~~n (Material & Parameter) ;rr~~-'5- 7.70 lOOOTIMES Metal Material Plastic Material 23.50 20.20 USE TIMES ttE'FTmm 3i.'~llli.AJiE fE~~~(ltem No) XT60H-M BP!mmi (Drawing) MC FR LEVEL N 60A 9.50 23.50 20.20 7.70 0 '=:!° 30A ~:JU~ (Patent) 201520067495.X 12AWG Cable SPEC. If'!=iU -20°c to 120°c TEMPERATURE 21/22 XT ~.,SS ~9~ XT SERIERS fE~~tm!J)Ui~~n (Material & Parameter) fE~~~(ltem No) XT90H-F ;rr~~-'5- XT90H-F XT P.~.,SS XT SERIERS fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT90PB-F ;rr~~-'5- 0.30m0 ltem No. XT90PB-F 0.30m0 ltem No. ~@, COLOR ~9~ ~@, DC SOOV - 3 DC SOOV COLOR 40A ~:JU~ (Patent) 201220179912.6 BPlmmi (Drawing) Metal Material Brass Gold Plated RC ~!S~M~ PA ~B1Eg)Jit Plastic Material 11.70 B.§i.?t.\w~& UL94 VO FR LEVEL oo 00 ci I../") q ttE'FT fief§ ));:~ \.0 ttE'FTmm EgitP. ttE'FT~nll Recommend USE BATIERY Cable SPEC. 9.90 3i.'nlli.AJil: If'Figfit CERTIFICATION TEMPERATURE ;rr~~-'5- XT90H-M Metal Material Brass Gold Plated ~!S~M~ PA Plastic Material 22.50 2.80 B.§i.?t.\w~& lOOOTIMES lOAWG ~ ci 0 q N -20°( to 120°C RC ~B1Eg)Jit UL94 VO ttE'FT fief§ ));:~ USE TIMES ttE'FTmm EgitP. ttE'FT~nll Recommend USE BATIERY Cable SPEC. 3i.'nl\i,AJiE If'Figfit CERTIFICATION TEMPERATURE ;rr~~-'5- 0.30m0 XT90PB-M ~@, DC SOOV COLOR - 3 Metal Material Brass Gold Plated RC ~!S~M~ PA ~B1Eg)Jit Plastic Material 9.90 DC SOOV 3 COLOR 00 ci N 0 q 40A ~:JU~ (Patent) --- 90A MC BPlmmi (Drawing) Brass Gold Plated ~!S~M~ PA Plastic Material 9.90 23.50 Metal Material RC ~B1Eg)Jit 90A MC 2.80 B.§i.?t.\w~& UL94 VO FR LEVEL 0 -20°C to 120°C 0.30m0 40A 30.70 26.20 PCB ltem No. ~@, BPlmmi (Drawing) lOOOTIMES fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT90PB-M ltem No. ~:JU~ (Patent) 201220179912.6 90A MC FR LEVEL fE~~tm!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT90H-M BPlmmi (Drawing) USE TIMES N ci N 90A MC 29.70 25.20 9.90 40A ~:JU~ (Patent) --- ttE'FT fief§ ));:~ B.§i.?t.\w~& lOOOTIMES USE TIMES UL94 VO FR LEVEL ttE'FT fief§ ));:~ lOOOTIMES USE TIMES I../") ftE'FT~nl\ \.0 ci N www.china-amass.com Recommend USE CONTROLLER/ CHARGER lOAWG Cable SPEC. 0 q ftE'FT~nl\ 0 00 ci Recommend USE N ~i,AJiE I f'FiU CERTIFICATION TEMPERATURE -20°c to 120°c CONTROLLER/ CHARGER PCB Cable SPEC. ~i),Jil: If'FiU CERTIFICATION TEMPERATURE -20°c to 120°c 23/24 AS ~9~(1J1jfl*fi!k) AS SERIERS(Anti-spark connector) ~.,SS fE~~~m!J)Ui~~n (Material & Parameter) fE~~~(ltem No) AS150-F ;rr~~-'5- ltem No. ~@, COLOR ASlSO-F AS ~9~(1J1jfl*fi!k) AS SERIERS(Anti-spark connector) fE~~~m!J>Ui~~n (Material & Parameter) fE~~~(ltem No) XT90S-F ;rr~~-'5- 0.2m0 XT90S-F 0.56m0 ltem No. -- ~@, DC SOOV DC SOOV COLOR 70A ~:JU~ (Patent) --- BP!mmi (Drawing) Metal Material Brass Gold Plated ~!S~M~ PA 40A ~:JU~ (Patent) 201420181100.4 RC lSOA BP!mmi (Drawing) Plastic Material 35.10 31.10 16.50 0 l.f) rri Metal Material Brass Gold Plated ~!S~M~ PA RC 90A Plastic Material 26.60 B.§m\w~& 0 oq UL94 VO FR LEVEL m'FTflem1;;:~ 9.90 lOOOTIMES USE TIMES 13.10 B.§m\w~& UL94 VO FR LEVEL m'FTflem 1;;:~ lOOOTIMES USE TIMES e e m'FT~~m 28.62 Recommend USE BATIERY m'FT~~ 6AWG 0 00 Cable SPEC. ci 0 q Recommend USE BATIERY lOAWG Cable SPEC. N 3i.'~ll\i)-.iiE If'Fi.ffil.fit CERTIFICATION TEMPERATURE ;rr~~-'5- ASlSO-M Item No. -- ~@, COLOR ~:JU~ (Patent) 201420553770.4 BP!mmi (Drawing) 0 0 e ~[ ~~~ www.china-amass.com Wl~Etlffi DC SOOV 70A Wi!W~ Wl~Etlilit Brass Gold Plated RC ~!S~t.t~ PA If'Fi.ffil.fit TEMPERATURE -20°C to 120°C ~B1Etlilit lSOA MC UL94 VO FR LEVEL m'FTflem 1;;:~ lOOOTIMES USE TIMES e 23.70 iid 0.2m0 Metal Material B.§m\w~& 0 l.f) rri t~MIJlEtlB.§ CR ~rnH.t~ Plastic Material 30.20 0\ '~Jllli.AJiE CERTIFICATION fE~~~m!J>Ui~~n (Material & Parameter) fE~~~(ltem No) AS150-M ci -20°C to 120°C m'FTim:m ~iM~ m'FT~~m Recommend USE CONTROLLER Cable SPEC. 6AWG 0 CXl I 1111 I '° e mll\i)-.iiE If'FiU CERTIFICATION TEMPERATURE -20°( to 120°C 27/28 AM~;~ ~.,SS fE~~tm!J)Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-1015-F r"~li!!-'5- Item No. ffll!@, COLOR ~~MJ1Q ~;JU~ (Patent) --- BPlmmi (Drawing) AM-1015-F -Wi!W~ t~MIJlEgB.§ ®j!j~Egffi r"~li!!-'5- 0.45m0 Item No. ffll!@, DC 500V COLOR ®j!j~Eg)Jit Brass Gold Plated RC ~!S~MJ1Q PA ~B'-J-Eg)Jit 25A ~;JU~ (Patent) --- 50A BPlmmi (Drawing) MC 0 M cvi 5.00 B.§~w~& UL94 VO FR LEVEL rn B 7.60 Eg)tB ftE'FT~ml Recommend USE BATIERY Cable SPEC. 3i:m! ~.A.iiE If'FiU CERTIFICATION TEMPERATURE 1tem No. ffll!@, COLOR ~;JU~ (Patent) --- BPlmmi (Drawing) AM-1015-M = 7.60 www.china-amass.com RC ~!S~MJ1Q PA ®j!j~Eg)Jit Brass Gold Plated RC ~!S~MJ1Q PA ~B'-J-Eg)Jit UL94 VO ftE§'fleffl ));:~ 50A lOOOTIMES USE TIMES Eg)tB ftE'FT~ml Recommend USE BATIERY Cable SPEC. 3i:m! ~.A.iiE If'FiU CERTIFICATION TEMPERATURE r"~li!!-'5- ffll!@, 25A ~;JU~ (Patent) --- 50A ~B'-J-Eg)Jit MC ttE'FTim:m COLOR Wi!W~ 12AWG BPlmmi (Drawing) MC -20°C to 120°C AM-1015B-M -- 0.45m0 ®j!j~Egffi DC 500V 25A ~~t;JJ1Q Wi!W~ ®j!j~Eg)Jit Metal Material Brass Gold Plated RC ~!S~MJ1Q PA Plastic Material 19.10 t~MIJlEgB.§ CR ~B'-J-Eg)Jit 50A MC 5.00 B.§~w~& 0 N 0 Brass Gold Plated fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-10158-M 6.30 5.00 cvi Metal Material ~ 7.60 19.10 6.30 ' DC 500V Metal Material 25A ®j!j~Eg)Jit Item No. ~~MJ1Q DC 500V Wi!W~ FR LEVEL D B -20°( to 120°C 0.45m0 ®j!j~Egffi ~~MJ1Q B.§~w~& 0.45m0 -- Plastic Material / 12AWG -- t~MIJlEgB.§ CR 5.00 m USE TIMES ttE'FTim:m 1"~lili-'5- 0 lOOOTIMES fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-1015-M M :ftH~fleffl /J;:~ AM-1015B-F Plastic Material 15.30 6.30 15.20 6.30 AM SERIERS fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-10158-F CR Metal Material Plastic Material AM~;~ AM SERIERS UL94 VO FR LEVEL ftE§'fleffl));:~ USE TIMES r-.i D 0 ttE'FTim:m ~iM~ ftE'FT~ml Recommend USE CONTROLLER Cable SPEC. 3i:m! ~.A.iiE If'Fi.ffil.m CERTIFICATION TEMPERATURE B.§~w~& lOOOTIMES 12AWG M cvi u 0 -20°( to 120°C 7.60 H I D 0 - I p UL94 VO FR LEVEL N r-.i ftE§'fleffl));:~ lOOOTIMES USE TIMES ttE'FTim:m ~iM~ ftE'FT~ml Recommend USE CONTROLLER Cable SPEC. 3i:m! ~.A.iiE If'Fi.ffil.m CERTIFICATION TEMPERATURE 12AWG -20°C to 120°C 29/30 AM~;~ ~.,SS fE~~tm!J)Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-1015E-F ;rr~~-'5- ltem No. ~@, COLOR AM~;~ AM SERIERS AM-1015E-F fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-1009L 0.45m0 - AM SERIERS ;rr~~-'5- AM-1009L 0.65m0 ltem No. - DC SOOV ~@, DC SOOV COLOR 2SA ~;JU~ (Patent) 201530005180.8 BP!mmi (Drawing) Metal Material Brass Gold Plated ~!S~M~ PA 32A ~;JU~ (Patent) --- RC SOA BP!mmi (Drawing) Plastic Material 9.20 Metal Material Brass Gold Plated ~!S~M~ PA RC 70A Plastic Material 23.05 ~~~~~~~~~~ ~ N B.§m\w~& UL94 VO FR LEVEL :ftH~fleffl/J;:~ lOOOTIMES 22.90 I 1 $l ~ J USE TIMES $ g QJ li'FTmm EtlitB li'FT~~lll Recommend USE BATIERY Cable SPEC. 3i:~lll~.A.iiE If'FiU CERTIFICATION TEMPERATURE -20°( to 120°C Ji'FTfleffl));:~ lOOOTIMES ,_F_R-LE-vE_L- - - + - - - - - - + - u _ s _ ET-IM-ES--+------. li'FT~~lll Recommend USE BATIERY/ CONTROLLER 12AWG Cable SPEC. 3i:~lll~.A.iiE If'FiU CERTIFICATION TEMPERATURE -20°C to 120°C PRODUCTS SHOW AM-1015E-M 0.45m0 ltem No. - DC SOOV ~@, UL94 VO 12AWG ;rr~~-'5- COLOR B.§m\w~& 22.90 fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) AM-1015E-M oo ~ :;'; t'~lim 2SA ~;JU~ (Patent) 201530005180.8 BP!mmi (Drawing) 9.20 19.25 Metal Material Brass Gold Plated ~!S~M~ PA RC SOA Plastic Material B.§m\w~& UL94 VO FR LEVEL li'FTfleffl));:~ li'FT~~ Recommend USE 15.10 www.china-amass.com lOOOTIMES USE TIMES CONTROLLER 12AWG Cable SPEC. 3i:~~.A.iiE I f'Fi.ffil.fit CERTIFICATION TEMPERATURE -20°C to 120°C 31/32 EC ~.,SS ~;~ fE~~tm!J)Ui~~~ (Material & Parameter) ]Z~~~(ltem No) EC2-F ;rr~~-'5- ltem No. ~@, COLOR EC~;~ EC SERIERS EC2-F fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) EC3-F ;rr~~-'5- 0.80m0 .. EC SERIERS ltem No. ~@, DC SOOV COLOR EC3-F 0.60m0 .. DC SOOV lSA ~;JU~ (Patent) --- BPlmmi (Drawing) 13.00 7.20 6.10 Metal Material Brass Gold Plated ~!S~M~ PA 2SA ~;JU~ (Patent) --- RC 30A BPlmmi (Drawing) Plastic Material EE B.§~w~& FR LEVEL :ftH~fleffl /J;:~ *~~mi Recommend USE BATIERY If'FiU CERTIFICATION TEMPERATURE ;rr~~-'5- EC2-M COLOR .. Metal Material Brass Gold Plated ~!S~M~ PA ltem No . ~@, UL94 VO RC SOA li~fleffl ));:~ *~~mi Recommend USE -20°( to 120°C BATIERY 3i:mi~.A.ilE If'FiU CERTIFICATION TEMPERATURE BPlmmi (Drawing) ;rr~~-'5- 0.80m0 .. Metal Material Brass Gold Plated ~!S~M~ PA ~@, DC SOOV EC3-M COLOR ltem No. 0.60m0 DC SOOV Plastic Material 13.30 UL94 VO FR LEVEL li~fleffl ));:~ www.china-amass.com lOOOTIMES USE TIMES *~~mi Recommend USE BPlmmi (Drawing) 8.00 6.10 B.§~w~& 2SA ~;JU~ (Patent) --- 30A CONTROLLER 3i:mi~.A.ilE I f'Fi.ffil.fit CERTIFICATION TEMPERATURE 17.50 B.§~w~& UL94 VO SOA li~fleffl ));:~ *~~mi Recommend USE lOOOTIMES USE TIMES 18AWG -20°C to 120°C RC Plastic Material FR LEVEL Cable SPEC. -20°C to 120°C fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) EC3-M RC 12AWG Cable SPEC. lSA ~;JU~ (Patent) --- lOOOTIMES USE TIMES 18AWG fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) EC2-M PA FR LEVEL Cable SPEC. 3i:mi~.A. m: ~!S~M~ B.§~w~& lOOOTIMES USE TIMES [[] Brass Gold Plated Plastic Material 17.50 UL94 VO Metal Material CONTROLLER 12AWG Cable SPEC. 3i:mi~.A.ilE If'Fi.ffil.fit CERTIFICATION TEMPERATURE -20°C to 120°C 33/34 EC ~.,SS ~;~ fE~~tm!J)Ui~~~ (Material & Parameter) fE~~~(ltem No) EC5-F ;rr~~-'5- ltem No . ~@, COLOR EC~;~ EC SERIERS ECS-F fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) MR30-FB ;rr~~-'5- 0.40m0 .. EC SERIERS MR30-FB 0.70m0 ltem No. ~@, DC SOOV DC SOOV COLOR 40A ~;JU~ (Patent) --- BPlmmi (Drawing) 24.00 Metal Material Bra ss Gold Plated ~!S~M~ PA lSA ~;JU~ (Patent) 201530314656.6 RC 90A BPlmmi (Drawing) Plastic Material Metal Material Brass Gold Plated ~!S~M~ PA RC 30A Plastic Material 14.40 B.§~w~& 0 UL94 VO FR LEVEL ci 4.90 :ftH~fleffl /J;:~ 12.40 lOOOTIMES USE TIMES ~D r ~ BB r 1 11~ Recommend USE EtlitB BATIERY UL94 VO FR LEVEL 0 ftE=FTmm 21.00 B.§~w~& Ji=FT~nl\ 1OA WG Cable SPEC. 0 ~ Ji=FT~nl\ M 0 M t - --+++ttr-+--JtH 0 Recommend USE CONTROLLER 3i:nl\~,A.ilE CE/ UL 16A WG Cable SPEC. I..() cvi o~ 3i:nll~.A. m: I f'FiU CERTIFICATION TEMPERATURE -20°c to 120°c CERTIFICATION fE~~tm!J>Ui~~~ (Material & Parameter) fE~~~(ltem No) EC5-M ;rr~~-'5- ECS-M COLOR .. Metal Material Brass Gold Plated ~!S~M~ PA ltem No . ~@, If'FiU BPlmmi (Drawing) 9.90 fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) MR30-M ;rr~~-'5- 0.40m0 MR30-M 0.70m0 ltem No. ~@, DC SOOV DC SOOV COLOR lSA ~;JU~ (Patent) 201530314656.6 RC 90A BPlmmi (Drawing) Plastic Material B.§~w~& UL94 VO FR LEVEL ftE=FTiiem 1;;:~ lOOOTIMES USE TIMES Ji=FT~nl\ Recommend USE Metal Material Brass Gold Plated ~!S~M~ PA RC 30A Plastic Material 0 ci -20°c to 120°c TEMPERATURE 40A ~;JU~ (Patent) --- 22.60 lOOOTIMES USE TIMES 0 L'1 ftE=FTiiem 1;;:~ CONTROLLER 1OA WG 15.40 13.40 4.90 0 L'1 ~Ui~~~ (Material & Parameter) ]Z~~~(ltem No) MR30PW-FB ;rr~~-'5- 0.75m0 ltem No. MR30PW-FB 0.80m0 ltem No. ~@, ~@, DC SOOV COLOR DC SOOV COLOR lSA ~;JU~ (Patent) 201530410534.7 BP!mmi (Drawing) Metal Material Brass Gold Plated ~!S~M~ PA lSA ~;JU~ (Patent) 201530415881.9 RC 30A BP!mmi (Drawing) Plastic Material Brass Gold Plated ~!S~M~ PA RC 30A Plastic Material 11.40 4.90 Metal Material 15.00 2.00 B.§m\w~& UL94 VO FR LEVEL 0 li'FT~~lll Recommend USE CONTROLLER Cable SPEC. 3i:~ll\~,A.iiE CE/ UL If'FiU CERTIFICATION ;rr~~-'5- li'FT~~lll -20°( to 120°C Recommend USE CONTROLLER Cable SPEC. 3i:~ll\~,A.iiE CE/ UL If'FiU CERTIFICATION 10.20 ;rr~~-'5- 0.75m0 MR30PW-M 0.80m0 ~@, DC SOOV 3 DC SOOV COLOR Metal Material Brass Gold Plated ~!S~M~ PA 30A B.§m\w~& BP!mmi (Drawing) UL94 VO FR LEVEL li'FTfleffl ));:~ 0 ~ M 0 0 '11 li'FT im:m EflJJL Ji'FT~nl\ Recommend USE MOTOR Cable SPEC. ~ PCB Uj cvi 3i::J;lll~,A.ilE CERTIFICATION www.china-amass.com CE/ UL I f'Fi.ffil.fit TEMPERATURE -20°C to 120°C Brass Gold Plated ~!S~M~ PA B.§m\w~& lOOOTIMES USE TIMES 0 '11 Metal Material ~ '---- -J 9.00 RC 30A Plastic Material 14.05 12.40 2.00 lSA ~;JU~ (Patent) 201530415881.9 RC Plastic Material 4.90 -20°C to 120°C TEMPERATURE lSA BP!mmi (Drawing) PCB ltem No. COLOR ~;JU~ (Patent) 201530410534.7 lOOOTIMES fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) MR30PW-M ltem No. ~@, li'FTfleffl ));:~ USE TIMES PCB TEMPERATURE MR30PB-M UL94 VO FR LEVEL fE~~tm!J>Ui~~~ (Material & Parameter) ]Z~~~(ltem No) MR30PB-M B.§m\w~& lOOOTIMES USE TIMES M ci :ftH~fleffl /J;:~ 5.30 13.00 UL94 VO FR LEVEL '"} ftt,~ l~ li'FTfleffl ));:~ lOOOTIMES USE TIMES I li'FT im:m EflJJL Ji'FT~nl\ Recommend USE MOTOR Cable SPEC. 3i::J;lll~,A.ilE CE/ UL CERTIFICATION If'Fi.ffil.fit PCB -20°C to i20°C TEMPERATURE 37/38 MT~;~ ~.,SS MT SERIERS fE~~tm!J)Ui~~~ (Material & Parameter) fE~~~(ltem No) MT30-F ;rr~~-'5- MT30-F MT ;rr~~-'5- l.OOmO ~~M~ BPlmmi (Drawing) .. ~@, DC SOOV 3 ®W~ ®j!j~Eg)Jit Metal Material Brass Gold Plated RC ~!S~M~ PA ~B'-J-Eg)Jit lSA ~;JU~ (Patent) 201430028774.6 30A BPlmmi (Drawing) MC 3-12.00 ci M' oi ~ ,.- USE TIMES I - m=FTim:m ~iM~ ftE=FT~ml Recommend USE CONTROLLER Cable SPEC. 3i:m!~.A. m: If'FiU CERTIFICATION TEMPERATURE MT30-M ~ BE °' Ui~~~ (Material & Parameter) ]Z~~~(ltem No) MT60-F ltem No. ~@, ~;~ ftE§'fleffl));:~ lOOOTIMES USE TIMES m=FTim:m ~iM~ ftE=FT~ml Recommend USE CONTROLLER Cable SPEC. 12AWG ~ ~ 3i:m!~,AJiE If'Fi.ffil.fit CERTIFICATION TEMPERATURE -20°C to 120°C 39/40 GC ~9~ GC SERIE RS ~.,SS fE~~tlm&¥~~ft (Material & Parameter) ;z~~~(ltem No) GC2010-F 1"~~-'5- GC2010-F Item No. t~MIJlEtlB.§ GC ~9~ GC SERIE RS P.~.,SS fE~~tlm&¥~~ft (Material & Parameter) ;z~~~(ltem No) GC2011-F 1"~~-'5- 1.SOmO Wi!W~ ~~M~ Brass Gold Metal Material ftE'FT~ml Plated 18AWG Wl!EEtliJit ~~M~ 1SA RC ~BtEtliJit Metal Material li'FT~ml 30A MC Cable SPEC. li'FTfleffl));:~ t~MIJlEtlB.§ GC2011-F Item No. CR Wi!W~ Wl!EEtliJit Brass Gold li'FTfleffl));:~ 2000TIMES 1SA RC Plated ~BtEtliJit 18AWG 30A MC Cable SPEC. USE TIMES 0.80m0 CR 2000TIMES USE TIMES BPmlmi (Drawing) BPmlmi (Drawing) 12.40 18.10 -fE- - -$ tJ1j1 0 0 0 LI') r-.i r-.i 0 e e f'~Mlm&¥~~ft (Material & Parameter) ;z~~~(ltem No) GC2010-M 1"~~-'5- GC2010-M Item No. ~~M~ Metal Material li'FT~ml Wi!W~ Brass Gold Plated 18AWG Wl!EEtliJit e e N e fE~~tlm&¥~~ft (Material & Parameter) 1"~~-'5- 1.SOmO t~MIJlEtlB.§ GC2011-M Item No. ~~M~ 1SA Metal Material li'FT~ml 30A MC li'FTfleffl));:~ 2000TIMES 0.80m0 CR Wi!W~ Wl!EEtliJit Brass Gold 1SA RC Plated ~BtEtliJit 18AWG 30A MC Cable SPEC. USE TIMES BPmlmi (Drawing) LI') N ;z~~~(ltem No) GC2011-M RC ~BtEtliJit 0 q CR Cable SPEC. li'FTfleffl));:~ t~MIJlEtlB.§ 0 oq 2000TIMES USE TIMES BPmlmi (Drawing) 12.40 16.50 ;;!< !!§ E E N 0 www.china-amass.com 0 oq LI') e e r-.i 43/44 GC ~9~ GC SERIE RS ~.,SS fE~~tlm&¥~~ft (Material & Parameter) ;z~~~(ltem No) GC2014-F 1"~~-'5- t~MIJlEtlB.§ GC2014-F Item No. ~~M~ Metal Material ftE'FT~ml P.~.,SS fE~~tlm&¥~~ft (Material & Parameter) ;z~~~(ltem No) GC3010-F 1"~~-'5- 1.20m0 Wi!W~ Wl!EEtliJit Brass Gold ~~M~ 1SA RC Plated ~BtEtliJit 16AWG Metal Material li'FT~ml 30A MC li'FTfleffl));:~ 2000TIMES Wi!W~ Wl!EEtliJit Brass Gold 20A RC Plated ~BtEtliJit 16AWG 40A MC 2000TIMES USE TIMES BPmlmi (Drawing) BPmlmi (Drawing) 15.00 17.00 0 0 tvi e T~ L_jP'zi_~~~~~_J_---1lL_jzzJ_zzzt=t----1 0 0 0 0 e e e
XT30UPB-M 价格&库存
很抱歉,暂时无法提供与“XT30UPB-M”相匹配的价格&库存,您可以联系我们找货
XT30UPB-M
  • 1+6.707171+0.81360
  • 5+3.688955+0.44748
  • 20+2.7108220+0.32883
  • 100+2.34751100+0.28476
XT30UPB-M
  • 1+1.09501
  • 30+1.05751
  • 100+1.02001
  • 500+0.94501
  • 1000+0.90750
  • 2000+0.88500
库存:1854
XT30UPB-M
    • 500+1.35140
    • 1000+1.29780
    • 2000+1.26560
