WSG02P06
P-Ch MOSFET
General Description
Product Summery
This P-Channel enhancement mode power
FETs are produced with high cell density, DMOS
trench technology, which is especially used to
minimize on-state resistance. This device is
particularly suited for low voltage application
such as portable equipment, power management
and other battery powered circuits, and low inline power loss are needed in a very small outline
surface mount package.
BVDSS
RDSON
ID
-60V
215mΩ
-2A
Applications
z High Frequency Point-of-Load Synchronous
Buck Converter.
z Networking DC-DC Power System
z Load Switch
Features
SOT-223 Pin Configuration
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ -10V
-2
A
ID@TA=70℃
-1.6
A
IDM
Pulsed Drain Current
A
PD@TA=25℃
Total Power Dissipation
-10
2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
Max.
Unit
RθJA
Thermal Resistance Junction-Ambient
62
℃/W
RθJC
Thermal Resistance Junction-Case
5.4
℃/W
www.winsok.tw
Page 1
Rev 1: Apr.2019
WSG02P06
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
Conditions
Min.
Typ.
Max.
Unit
-60
V
-0.03
V/℃
175
215
205
260
-1.2
-1.9
-3.0
V
4.56
mV/℃
VDS=-60V , VGS=0V , TJ=25℃
-1
VDS=-60V , VGS=0V , TJ=55℃
-5
VGS=±20V , VDS=0V
±100
nA
5
S
6.3
2.3
VGS=0V , ID -250uA
Reference to 25℃ , ID=-1mA
VGS=-10V , ID -2A
VGS=-4.5V , ID -2A
VGS=VDS , ID =-250uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
gfs
Forward Transconductance
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
1.8
Turn-On Delay Time
Td(on)
Tr
Td(off)
VDS=-15V , ID -2A
VDS=-48V , VGS=-4.5V , ID=-1A
Rise Time
VDD=-30V , VGS=-10V ,
.3
Turn-Off Delay Time
RGEN=3.3Ω,RL=30Ω.
5.2
Fall Time
3.8
Ciss
Input Capacitance
364
Coss
Output Capacitance
41
Crss
Reverse Transfer Capacitance
12
Tf
VDS=-15V , VGS=0V , f=1MHz
mΩ
uA
nC
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source Current
Diode Forward Voltage
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
Conditions
-2
A
VGS=0V , IS=-1.2A , TJ=25℃
-1.2
V
A: The value of RθJA is measured with the device mounted on 1in² FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The value in any
given application depends on the user's specific board design.
B: The power dissipation PD is based on TJ(MAX)=150℃, u s i n g ≤10s junction-to-ambient thermal resistance.
C: Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150℃. Ratings are based on low frequency and duty cycles to keep initial T J=25℃.
D: The RθJA is the sum of the thermal impedence from junction to lead RθJA and lead to ambient.
E: The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“WSG02P06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.77500
- 10+0.72500
- 50+0.65000
- 150+0.60000
- 300+0.56500
- 500+0.55000
