SL3906
PNP Switching Transistor
■MAXIMUM RATINGS
Characteristic
Symbol
Rating
Unit
Collector-Emitter Voltage
VCEO
-40
Vdc
Collector-Base Voltage
VCBO
-40
Vdc
Emitter-Base Voltage
VEBO
-6.0
Vdc
Ic
-200
mAdc
Collector Current-Continuous
■THERMAL CHARACTERISTICS
Characteristic
Total Device Dissipation
FR-5 Board(1)
TA=25℃
Derate above25℃
Alumina Substrate,
TA=25℃
Derate above25℃
Symbol
Max
PD
225
mW
1.8
mW/℃
300
mW
2.4
mW/℃
417
℃/W
PD
Thermal Resistance Junction to Ambient
RΘJA
Junction and Storage Temperature
TJ,Tstg
www.slkormicro.com
1
Unit
150℃, -55to+150℃
SL3906
■ELECTRICAL CHARACTERISTICS
(TA=25
25℃ unless otherwise noted )
■OFF CHARACTERISTICS
Characteristic
Symbol
Min
Max
Unit
Collector-Emitter Breakdown Voltage(3)
(Ic=-1.0mAdc,IB=0)
V(BR)CEO
-40
Vdc
Collector-Base Breakdown Voltage
(Ic=-10μAdc,IE=0)
V(BR)CBO
-40
Vdc
Emitter-Base Breakdown Voltage
(IE=-10μAdc,Ic=0)
Base Cutoff Current
(VCE=-30Vdc, VEB =-3.0 Vdc)
V(BR)EBO
-6.0
Vdc
IBEX
-50
nAdc
ICEX
-50
nAdc
Symbol
Min
Max
Unit
Collector Cutoff Current
(VCE=-30Vdc, VEB =-3.0Vdc)
■ON CHARCTERISTICS(2)
Characteristic
hPE
DC Current Gain
(Ic=-0.1mAdc,VCE=-1.0Vdc)
(Ic=-1.0mAdc,VCE=-1.0Vdc)
(Ic=-10mAdc,VCE=-1.0Vdc)
(Ic=-50mAdc,VCE=-1.0Vdc)
(Ic=-100mAdc,VCE=-1.0Vdc)
Collector-Emitter Saturation Voltage
(Ic=-10mAdc, IB=-1.0mAdc)
(Ic=-50mAdc, IB=-5.0mAdc)
VCE(sat)
Base-Emitter Saturation Voltage
VBE(sat)
www.slkormicro.com
2
40
70
100
60
30
300
-0.25
-0.4
-0.65
-0.85
-0.95
Vdc
Vdc
SL3906
■SMALL-SIGNAL CHARACTERISTICS
Symbol
Min
Max
Unit
fT
300
MHz
Output Capacitance
(VCB=-5.0Vdc, IE=0, f=1.0MHz)
Cobo
4.0
pF
Input Capacitance
(VEB=-0.5Vdc, IC=0, f=1.0MHz)
Input Impedance
(VCE=-10Vdc, IC=-1.0mAdc, f=1.0KHz)
Cibo
8.0
pF
hie
1.0
10
kΩ
Voltage Feedback Ratio
Small-Signal Current Gain
Output Admittance
hre
0.5
8.0
×10-4
hfe
100
400
hoe
1.0
40
μmhos
NF
5.0
dB
Symbol
Min
Max
Unit
td
35
Characteristic
Current-Gain-Bandwidth Product
(Ic=-10mAdc,VCE=-20Vdc,f=100MHz)
Noise Figure
(VCE=-5.0Vdc, IC=-100μAdc,Rs=1.0 kΩf=1.0KHz)
■SWITCHING CHARACTERISTICS
Characteristic
Delay Time
Rise Time
(VCC=-3.0Vdc,VBE=-0.5Vdc,
IC=-10mAdc, IB1=-1.0mAdc)
ns
Storage Time
Fall Time
(VCC=-3.0Vdc,IC=-10mAdc,
IB1=IB2=-1.0mAdc)
tr
35
ts
225
ns
tf
1. FR-5=1.0×0.75×0.062in.
2. Alumina=0.4×0.3×0.024in.99.5%alumina.
3. Pulse Width
很抱歉,暂时无法提供与“SL3906”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.03600
- 100+0.03360
- 300+0.03120
- 500+0.02880
- 2000+0.02760
- 5000+0.02688
