IS6605A
4V to 16V Input, 6A Sync Step-Down Converter W/ Light Load
Mode, Programmable Switching Frequency and Over Current Limit
Rev2.0 6/2020
Part Number
IS6605A
Input Voltage
4V~16V
Description
IS6606 uses proprietary Turbo Constant-OnTime
(TCOTTM) control with
internal
compensation to provide fast transient
response and simplified loop stability.
The switching frequency can be easily set to
600kHz, 1.1MHz, 1.5MHz or 2MHz. The
switching frequency of IS6605A remains
constant regardless of input and output
voltages.
The soft start process is controlled by an
internal 1.5msec timer, which can be
increased by adding a capacitor from TRK /
REF to GND. The open-drain power good
(PGOOD) signal indicates whether the output
is within its nominal voltage range. When the
input power fails to power the IS6605A,
PGOOD is clamped at about 0.7V by an
external pull-up voltage.
The IS6605A is equipped with full suites of
protection functions which includes overcurrent protection
(OCP), over-voltage
protection (OVP), under-voltage protection
(UVP), and over-temperature protection (OTP).
The IS6605A is available in a 14-pin QFN
(2mmx3mm) package.
Production Datasheet
Current Rating
6A
Features
The IS6605A is a fully integrated, highfrequency, synchronous, step-down converter.
It provides a very compact solution that
achieves up to 6A output current with excellent
load and line regulation over wide input
voltage range. IS6605A has high working
efficiency over its output current load range.
Moisture Sensitivity Leve 3.
Output Voltage
0.6V~5.5V
Turbo Constant-On-Time (TCOTTM) Control
with Fast Transient Response.
• VIN Input Voltage Range: 2.7 V to 16V with
External Bias VCC voltage, or 4V to 16V
with Internal Bias VCC.
• Output Voltage Range: 0.6V to 5.5V, and
90% max duty cycle.
• 6A Continuous Output Current.
Excellent Load and Line Regulations with
0.5% Voltage Accuracy.
Up to 90% Efficiency at VIN=12V,
VOUT=1.8V
Mode Selection between Pulse Skip and
CCM at Light Load
• PGOOD Active Clamp at Low Level during
a Power Outage
Programmable Soft-Start time
• 1.0µA Current into VIN Pin during
Shutdown
• Programmable Switch Valley Current Limit
Adjustable Switching Frequency: 600kHz,
1.1MHz, 1.5MHz and 2MHz
• OCP, NOCP, OVP, UVLO and OTP
• QFN 2mm x 3mm Package with 14-Pin
Applications
Telecom/Datacom
Computing and Servers
Point of Load Module
Innovision Semiconductor
1
IS6605A
Rev2.0 6/2020
Typical Application Circuit
R6
C4
BS T
L1
VI N
C1
VO
PHAS E
VI N
R4
C2
C8
VCC
R1
C3
C7
C5
PG D
PGOOD
IS6605A
R7
FB
ON
EN
OFF
R5
C6
MODE
PGND
AGND
CS
R2
REF
R3
2
IS6605A
Rev2.0 6/2020
Order Information TOP MARKING (IS6605A)
Part Number
Package
Shipping Method
Package Marking
IS6605A
QFN-14(2mm x 3mm)
5000u Tape & Reel
6605A
6605A
8A653
YYWW
6605A: First five digits of the part number
8A653: Lot ID
YY: Year code
W:W Week code
Package Reference
PGND VCC
14
13
PGND 1
12 MODE
PHASE 2
11 PHASE
VIN 3
10 BST
CS 4
9 PGOOD
EN 5
8 REF
6
7
FB AGND
Top View
3
IS6605A
Rev2.0 6/2020
Absolute Maximum Ratings
Thermal Ratings
Supply Voltage (Vin)……………………...-0.3V to 18V
Vcc Voltage (Vcc)………………………….-0.3V to 5.5V
Switch Node Voltage (VPH) DC……….-0.3V to 18.3V
Switch Node Voltage (VPH) 25ns ……….-5V to 20V
BST Pin (Vbst-sw) 25ns………………….-0.3V to 5.5V
All other pins……………………………..-0.3V to 5.5V
Junction Temperature (Tj)………………………150°C
Storage Temperature…………………-65°C to 150°C
ΘJC Max………………………………………17.5°C/W
Θ JBTyp (Still Air, No Heatsink)……………7°C/W
Recommended Operating Conditions
Supply Voltage (Vin)………………………2.7V to 16V
Vcc Voltage (Vcc)………………………3.15V to 3.6V
Output Voltage (Vo)………………………0.6V to 5.5V
Max Output Current (Io_max)…………………………6A
Junction Temperature (Tj)……………-40°C to 125°C
Note 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only; functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the
specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
ESD Ratings
Electrostatic Discharge
Standard
Value
Human Body Mode (HBM)
Charge Device Mode (CDM)
JEDEC EIA/JESD22-A114
JEDEC EIA/JESD22-C101F
1500V
2000V
1). JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process.
2). JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
4
IS6605A
Rev2.0 6/2020
Pin Out and Package
IS6605A(QFN-14)
Pin Number
Name
Description
1,14
PGND
System Ground. Power ground of the power stage.
2,11
PHASE
Switch Output. Switch node of power stage.
3
VIN
Supply voltage. Input to the power stage and internal LDO.
4
CS
Current limit and inductor current report. Connect a resistor to AGND to set the
valley current limit trip point. A voltage indicating the inductor current during
operating.
5
EN
Enable pin. An input signal turns the regulator on or off. Connect EN to VIN
through a pull-up resistor. Do not float this pin.
6
FB
An external resistor divider from output to AGND is tapped to FB to set the
output voltage. It is recommended to place the resistor divider as close as
possible to FB. Avoid vias on FB traces.
7
AGND
8
REF
External tracking voltage input. The output voltage tracks this input signal. REF
is decoupled as close as possible to the ceramic capacitor
9
PGOOD
Power good output with open drain. If the output voltage is within the regulation
range, a pull-up resistor connected to the DC voltage is required to indicate a
logic high signal.
10
BST
Bootstrap connection. A capacitor connected between PHASE and BST is
required to form a floating supply across the high-side switch driver.
12
MODE
13
VCC
Signal logic ground. A Kelvin connection to PGND is required.
Operation mode selection. Connect a resistor to AGND to set switching
frequency and select PLUSE SKIP/FCCM Mode.
Internal 3.3V LDO output. The driver and control circuit are powered by VCC.
Decouple VCC with a minimum 1uF ceramic capacitor as close as possible.
5
IS6605A
Rev2.0 6/2020
FUNCTIONAL BLOCK DIAGRAM
VIN
MODE
VCC
MODE
Select
LDO
BST
REG
BST
Off
Timer
EN
Reference
System
Monitor
HS
Driver
xS
OV_TH UV_TH
REF
-Error
Amplifier
FB
Q
HSG
LSG
xR
PWM
Comparator
On
Timer
PHASE
Logic
Control
HSG
Ramp
LSG
LS
Driver
OV_TH
PGOOD
PGOOD
Comparator
UV_TH
OV Detect
Comparator
ZCD
UV Detect
Comparator
xLIM
Valley
Current
Limit&
ZCD
PGND
FAULT
CS
AGND
6
IS6605A
Rev2.0 6/2020
ELECTRICAL CHARACTERISTICS
Vin = 12V, T = −40°C to 125°C, unless otherwise noted.
Definition/Datasheet
Parameters
Min
Typ
Units
Max
Supply Voltage & Current
VIN Supply Voltage (with internal LDO)
4.0
16
V
VIN Supply Voltage (with external bias)
2.85
16
V
VIN Supply Current (Quiescent)
EN=2V, VFB = 0.62V
VIN Shutdown Current
EN="Lo"
1500
µA
µA
3.3
3.42
V
VCC Supply
VCC Output Voltage (6V
8
2
where
COUT(min) is the minimum output
capacitance needed to meet the
stability requirement of the design
tON is the on-time information based
on the switching frequency and duty
cycle (in this design, 100 ns)
τ is the ramp compensation time
constant of the design based on the
switching frequency and duty cycle
(in this design, 1 sec)
LOUT is the output inductance (in the
design, 0.39 µH)
• VREF is the reference voltage level (in
this design, 0.6 V)
VOUT is the output voltage (1 V)
The stability is ensured when the amount of the
output capacitance is greater than the minimum
required value. And when all MLCCs (multi-layer
ceramic capacitors) are used, both DC and AC
derating effects must be considered to ensure
that
the
minimum
output
capacitance
requirement is met with sufficient margin.
For Constant on time topology, the minimum
capacitance required by the stability is much
smaller than that is required by the load
transient.
Response to a Load Transient
In general applications where the overall output
voltage tolerance is +/-5%, the allowed transient
voltage deviation during the worst case load
release can be set at around 3% depending on
how much output voltage setpoint accuracy (1%
in this design) and the ripple voltage requirement
(1% in this design). The minimum output
capacitance to meet the overshoot requirement
can be calculated using the above equation.
This example uses a combination of POSCAP
and MLCC capacitors to meet the overshoot
requirement.
• POSCAP bank #1: 1 x 330 µF, 2.5 V, 6
mΩ per capacitor
• MLCC bank #2: 1 × 10 µF, 2.5 V, 1 mΩ
per capacitor (7)
with DC+AC derating
factor of 50%
Recalculating the worst case overshoot using
the described capacitor bank design, the
overshoot needs to be 30 mV or less which
meets the 3% overshoot transient specification
requirement.
Output Voltage Ripple
The output voltage ripple is another important
design consideration. The following equation
calculates the minimum output capacitance
required to meet the output voltage ripple
specification. This criterion is the requirement
17
IS6605A
Rev2.0 6/2020
when the impedance of the output capacitance 9.4 mΩ. For this example, four 22 μF, 25 V lowESR polymer capacitors in parallel were
is dominated by ESR.
selected for the power stage.
_
8×
Bootstrap Capacitor Selection
_
In this example, the maximum output voltage
ripple is 9 mV. Because this capacitance value
is significantly lower compared to that of
transient load release, determining the output
capacitance bank using the worst case load
release requirement is generally adequate.
Because the output capacitor bank consists of
both POSCAP and MLCC type capacitors, it is
important to consider the ripple effect at the
switching frequency due to effective ESR.
A ceramic capacitor with a value of 0.1 μF must
be connected between the BOOT and SW pins
for proper operation. It is recommended to use a
ceramic capacitor with X5R or better grade
dielectric. Use a capacitor with a voltage rating
of 25 V or higher.
5.
R-C Snubber and VIN Pin
High-Frequency Bypass
Though it is possible to operate the IS6605A
within absolute maximum ratings without ringing
For detailed calculations, please contact the
reduction techniques, some designs may require
factory to obtain a user-friendly Excel based
external components to further reduce ringing
design tool.
levels. This example uses two approaches: a
high frequency power stage bypass capacitor on
4. Input Capacitor Selection
the VIN pins, and an R-C snubber between the
The IS6605A devices require a high-quality, PHASE area and GND.
ceramic, type X5R or X7R, input decoupling
capacitor with a value of at least 1 μF of The high-frequency VIN bypass capacitor is a
effective capacitance on the VCC pin, relative to lossless ringing reduction technique which helps
AGND. The power stage input decoupling minimizes the outboard parasitic inductances in
capacitance (effective capacitance at the VIN
and PGND pins) must be sufficient to supply the the power stage, which store energy during the
high switching currents demanded when the low-side MOSFET on-time, and discharge once
high-side MOSFET switches on, while providing the high-side MOSFET is turned on. For this
minimal input voltage ripple as a result. This design twin 2.2 nF, 25 V, 0603 sized higheffective capacitance includes any DC bias frequency capacitors are used. The placement
effects. The voltage rating of the input capacitor of these capacitors is critical to its effectiveness.
must be greater than the maximum input It’s ideal placement is shown in PCB layout
voltage. The capacitor must also have a ripple guidelines.
current rating greater than the maximum input
current ripple to the device during full load. The
input ripple current can be calculated using the
equation below.
The value of a ceramic capacitor varies
significantly over temperature and the amount of
DC bias applied to the capacitor. The
capacitance variations due to temperature can
be minimized by selecting a dielectric material
that is stable over temperature. X5R and X7R
ceramic dielectrics are usually selected for
power regulator capacitors because they have a
high capacitance to volume ratio and are fairly
stable over temperature. The input capacitor
must also be selected with the DC bias taken
into consideration. For this design example, a
ceramic capacitor with at least a 25 V voltage
rating is required to support the maximum input
voltage. For this design, allow 0.1 V input ripple
for VRIPPLE(cap), and 0.3 V input ripple for
VRIPPLE(esr). the minimum input capacitance for
this design is 38.5 µF, and the maximum ESR is
18
IS6605A
Rev2.0 6/2020
4. VCC capacitor should be placed as close to
the IS6605A as possible. Connecting AGND
Efficient PCB layout is crucial to the stable
and PGND at VCC capacitor's grounding point
is strongly recommended.
operation of the circuit. For best
PCB Layout Guidelines
performance, follow the
recommendations below.
PCB
layout
1.The input MLCC capacitors shall be placed as
close as possible to the VIN and PGND pins
of IS6605A. The MLCC capacitor shall be
placed on the same side as that of IS6605A.
The copper plane of VIN and PGND shall be
maximized
to minimize the parasitic
impedance.
3. Place as many PGND vias as possible
nearest to the PGND pin to minimize parasitic
impedance and thermal resistance.
5. Place the BST capacitor as close as possible
to BST and PH pins. Routing width should be
greater than 20mil. It is recommended to use
a 0.1 µF to 1 µF bootstrap capacitance value
Place BST resistance between the IC and the
BST capacitor to achieve damping effect by
limiting the speed of the FET being turned on.
It is recommended to use a 3.3 Ω resistor for
bootstrapping purpose.
6. Place the REF capacitor close to AGND pin.
It is recommended to use a 22 nF to 220 nF
capacitor.
19
IS6605A
Rev2.0 6/2020
Typical Application Circuits
IS6605A
Rev2.0 6/2020
PCB Layout
TOP Layer
21
IS6605A
Rev2.0 6/2020
Layer 2
Layer 3
22
IS6605A
Rev2.0 6/2020
Bottom Layer
23
IS6605A
Rev2.0 6/2020
Package Dimension
24
IS6605A
Rev2.0 6/2020
Reflow Specification
Qualification Reflow: The IS6606 was qualified in accordance with IPC/JEDEC J-STD-020D.01.
This standard classifies proper packaging, storage, and handling in order to avoid subsequent
thermal and mechanical damage during the solder reflow attachment phase of PCB assembly.
The qualification preconditioning process specifies a sequence consisting of a bake cycle, moisture
soak cycle (in a temperature humidity oven), and three consecutive solder reflow cycles, followed by
functional device testing.
SUPPLIER TP≥TC
USER TP≤TC
TC
TC -5℃
SUPPLIER tp
USER tp
TP
tp
MAXIMUM RAMP UP RATE = 3℃/s
MAXIMUM RAMP DOWM RATE = 6℃/s
TL
TSMAX
PREHEAT AREA
TC -5℃
tL
TMEPERATURE[℃]
TSMIN
ts
25
TIME 25℃ TO PEAK
TIME
Production Reflow:
PROFILE FEATURE
SN - PB EUTECTIC ASSEMBLY
PB-FREE ASSEMBLY
Peak package body
temperature (TP)
For users, TP must not exceed
TC(235℃).For suppliers, TP must TC(260℃).For suppliers, TP must
equal or exceed TC(235℃).
equal or exceed TC(260℃).
Storage Specifications
The storage specification of the IS6606 conforms to IPC/JEDEC J-STD-020D.01 Moisture
Sensitivity Level (MSL) 3.
After opening moisture-sealed bag
168 hours -- Storage conditions: ambient ≤30°C at 60%RH
25
IS6605A
Rev2.0 6/2020
TAPE AND REEL INFORMATION
REEL DIMENSIONS
TAPE DIMENSIONS
E
Discharging direction
P1
P0
D0
P2
W
F
B0
T
K0
Pin1
A0
Reel Width
NOTE:
1、CARRIER TAPE COLOR:BLACK.
KEY PARAMETER LIST OF TAPE AND REEL
2、COVER TAPE WIDTH : 5.5±0.10.
3、COVER TAPE COLOR : TRANSPARENT.
Package Type
Reel
Diameter
(inch)
Reel Width
(mm)
13″
9.5 13..00
QFN-14(2 x 3)
4、10 SPROCKET HOLE PITCH CUMULATIVE TOLERANCE ± 0.20MAX.
5、CAMBER NOT TO EXCEED 1MM IN 100MM.
6、MOLD#2X3X0.75/0.85.
7、BAN TO USE THE LEVEL 1 ENVIRONMENT-RELATED SUBSTANCES
OF JCET PRESCRIBING.
Unit(mm)
ITEM
DIM
W
A0
B0
K0
P0
P1
P2
F
S
E
D0
T
8.00
3.30
±0.10
2.30
±0.10
1.1
±0.10
4.00
±0.10
4.00
±0.10
2.00
±0.05
3.50
±0.05
0.00
±0.10
1.75
±0.10
1.50
0.20
±0.02
+0.30
- 0.10
+0.10
- 0.00
26
