D6605I
D6605I
    US-LASERSINC.
    Through Hole
    LASER DIODE 660NM 5.6MM
D6605I 数据手册
US-Lasers: 660nm-5mW - Red Laser Diode and Red Diode Laser Module Page 1 of 1 US-Lasers: 660nm-5mW - Red Laser Diode Back to Laser Diodes RED LASER DIODE DATA SHEETS ABSOLUTE MAXIMUM RATINGS - (Tc=25 °C) TECHNICAL DATA Visible laser diode light 660nm output Optical power output 5mW CW Package Type 5.6mm Built-in photo diode for monitoring laser output Pin Out Diagram - Style A Items Symbols Values Unit Optical output power Po 5 mW Laser diode reverse voltage V 2 V Photo diode reverse voltage V 30 V Operating temperature Topr -10 ~ +60 °C Storage temperature Tstg -40 ~ +85 °C OPTICAL and ELECTRICAL CHARACTERISTICS - (Tc=25 ºC) Typ. Max. Unit Test Condition Items Symbols Min. Optical output power Po 5 mW Threshold current Ith 20 40 mA Operating current Iop 40 60 mA Po=5mW Operating voltage Vop 2.7 V Po=5mW Lasing wavelength 655 660 665 nm Po=5mW 5 11 deg Po=5mW Beam divergence Beam divergence 25 37 deg Po=5mW Monitor current Is 10 20 uA Po=5mW Astigmatism As 11 um Po=5mW 10000 hrs MTTF Po=5mW Emitter Size 10 x 60 Microns - Emitter Distance to Cap Lens = 0.3mm Structure Index Guided http://www.us-lasers.com/d660nm5m.htm 3/21/2012
D6605I 价格&库存
很抱歉,暂时无法提供与“D6605I”相匹配的价格&库存,您可以联系我们找货
