SI2328DS
www.VBsemi.tw
N-Channel 100 V (D-S) MOSFET
FEATURES
MOSFET PRODUCT SUMMARY
RDS(on) ()
ID (A)a
0.240 at VGS = 10 V
2.0
0.250 at VGS = 6 V
1.8
0.260 at VGS = 4.5 V
1.7
VDS (V)
100
Qg (Typ.)
2.9 nC
TrenchFET® Power MOSFET
100 % Rg Tested
100 % UIS Tested
Material categorization:
APPLICATIONS
• DC/DC Converters
• Load Switch
• LED Backlighting in LCD TVs
G
1
3
S
D
2
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Limit
100
± 20
2
1.8
1.6b, c
1.3b, c
7
2.1
1.0b, c
5
1.25
2.5
1.6
1.25b, c
0.8b, c
- 55 to 150
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
ID
IDM
Pulsed Drain Current (t = 300 µs)
Continuous Source-Drain Diode Current
TC = 25 °C
TA = 25 °C
IS
Single Pulse Avalanche Current
Single Pulse Avalanche Energy
L = 0.1 mH
IAS
EAS
Maximum Power Dissipation
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
PD
TJ, Tstg
Operating Junction and Storage Temperature Range
Unit
V
A
mJ
W
°C
THERMAL RESISTANCE RATINGS
Parameter
5 s
Maximum Junction-to-Ambientb, d
Steady State
Maximum Junction-to-Foot (Drain)
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
c. t = 5 s.
d. Maximum under steady state conditions is 166 °C/W.
E-mail:China@VBsemi TEL:86-755-83251052
Symbol
RthJA
RthJF
Typical
75
40
Maximum
100
50
Unit
°C/W
SI2328DS
www.VBsemi.tw
MOSFET SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VDS = 0 V, ID = 250 µA
100
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS/TJ
VDS Temperature Coefficient
VGS(th) Temperature Coefficient
VGS(th)/TJ
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250 µA
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State
Resistancea
Forward Transconductancea
RDS(on)
gfs
105
ID = 250 µA
Gate-Source Leakage
V
mV/°C
- 5.2
1.2
2.8
V
± 100
nA
VDS = 100 V, VGS = 0 V
-1
VDS = 100 V, VGS = 0 V, TJ = 55 °C
- 10
VDS 5 V, VGS = 4.5 V
5
µA
A
VGS = 10 V, ID = 1.5 A
0.240
VGS = 6 V, ID = 1 A
0.250
VGS = 4.5 V, ID = 0.5 A
0.260
VDS = 20 V, ID = 1.5 A
2.0
S
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
190
VDS = 50 V, VGS = 0 V, f = 1 MHz
22
VDS = 50 V, VGS = 10 V, ID = 1.6 A
5.2
10.4
2.9
5.8
13
VDS = 50 V, VGS = 4.5 V, ID = 1.6 A
td(off)
0.75
VDD = 50 V, RL = 39
ID = 1.3 A, VGEN = 4.5 V, Rg = 1
0.3
1.4
2.8
30
45
26
39
17
26
tf
12
td(on)
6
12
10
tr
td(off)
nC
1.4
f = 1 MHz
td(on)
tr
pF
VDD = 50 V, RL = 39
ID = 1.3 A, VGEN = 10 V, Rg = 1
tf
10
12
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Currenta
ISM
Body Diode Voltage
VSD
TC = 25 °C
- 2.1
- 20
IS = 1.3 A
- 0.8
- 1.2
A
V
Body Diode Reverse Recovery Time
trr
22
33
ns
Body Diode Reverse Recovery Charge
Qrr
21
32
nC
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
IF = 1.3 A, dI/dt = 100 A/µs, TJ = 25 °C
16
6
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
SI2328DS
www.VBsemi.tw
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
5
3
VGS = 10 V thru 5 V
VGS = 4.5V
2.4
ID - Drain Current (A)
4
3
2
VGS = 3 V
1
1.8
TC = 25 °C
1.2
0.6
TC = 125 °C
TC = - 55 °C
1
1.5
2
2
3
4
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
300
240
VGS = 4.5 V
0.300
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
0.350
VGS = 6 V
0.250
0.200
VGS = 10 V
Ciss
180
120
60
0.150
Coss
Crss
2
3
4
5
80
100
Capacitance
On-Resistance vs. Drain Current and Gate Voltage
10
2.2
ID = 1.6 A
ID = 1.5 A
8
VDS = 25 V
(Normalized)
60
6
VDS = 50 V
4
VDS = 80 V
1.75
VGS = 6 V
1.3
0.85
2
VGS = 10 V
3
4.5
Qg - Total Gate Charge (nC)
Gate Charge
6
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
SI2328DS
www.VBsemi.tw
10
0.4
0.3
IS - Source Current (A)
ID = 1.5 A
TJ = 150 °C
1
TJ = 125 °C
0.2
T = 25 °C
0.15
TJ = 25 °C
0.1
0.0
0.6
0.9
2
1.2
6
8
10
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
2.8
10
8
Power (W)
2.5
VGS(th) (V)
4
ID = 250 μA
2.2
6
4
1.9
2
1.6
- 50
- 25
50
75
100
125
TA = 25 °C
150
0.1
1
Single Pulse Power
Threshold Voltage
10
Limited by R DS(on)*
100 μs
1
1 ms
10 ms
0.1
100 ms
1 s, 10 s
0.01
DC
TA = 25 °C
Single Pulse
0.001
0.1
1
BVDSS Limited
10
100
1000
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
10
Time (s)
TJ - Temperature (°C)
100
1000
SI2328DS
www.VBsemi.tw
2.8
2.1
1.4
0.7
0.0
50
75
100
125
150
TC - Case Temperature (°C)
3
1.0
2.4
0.8
1.8
0.6
Power (W)
Power (W)
Current Derating*
1.2
0.6
0.4
0.2
50
75
100
125
150
50
75
100
125
TA - Ambient Temperature (°C)
Power, Junction-to-Foot
Power, Junction-to-Ambient
150
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
SI2328DS
www.VBsemi.tw
A=
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
0.02
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 166 °C/W
3. TJM - TA = PDMZthJA(t)
4. Surface Mounted
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
100
10
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
Note
• The characteristics shown in the two graphs
- Normalized Transient Thermal Impedance Junction-to-Ambient (25 °C)
- Normalized Transient Thermal Impedance Junction-to-Foot (25 °C )
are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single
pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part
mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities
can widely vary depending on actual application parameters and operating conditions.
SI2328DS
www.VBsemi.tw
SOT-23 (TO-236): 3-LEAD
b
3
E1
1
E
2
e
S
e1
D
0.10 mm
C
0.004"
A2
A
C
q
Gauge Plane
Seating Plane
Seating Plane
C
A1
Dim
0.25 mm
L
L1
MILLIMETERS
INCHES
Min
Max
Min
Max
A
0.89
1.12
0.035
0.044
A1
0.01
0.10
0.0004
0.004
A2
0.88
1.02
0.0346
0.040
b
0.35
0.50
0.014
0.020
c
0.085
0.18
0.003
0.007
D
2.80
3.04
0.110
0.120
E
2.10
2.64
0.083
0.104
E1
1.20
1.40
0.047
e
0.95 BSC
e1
L
1.90 BSC
0.40
L1
q
ECN: S-03946-Rev. K, 09-Jul-01
DWG: 5479
0.0748 Ref
0.60
0.016
0.64 Ref
S
0.024
0.025 Ref
0.50 Ref
3°
0.055
0.0374 Ref
0.020 Ref
8°
3°
8°
SI2328DS
www.VBsemi.tw
0.053
(1.341)
0.097
(2.459)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
0.049
(1.245)
0.029
0.022
(0.559)
(0.724)
0.037
(0.950)
(2.692)
0.106
RECOMMENDED MINIMUM PADS FOR SOT-23
SI2328DS
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
