WSD4050DN
N-Ch MOSFET
General Description
Product Summery
The WSD4050DN is the highest
performance trench N-ch MOSFETs
with extreme high cell density , which
provide excellent RDSON and gate
charge for most of the synchronous buck
converter applications .
BVDSS
RDSON
ID
40V
7.4mΩ
50A
Applications
The WSD4050DN meet the RoHS
and Green Product requirement ,
100% EAS guaranteed with full
function reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
z Load Switch
Features
DFN3.3X3.3-EP Pin Configuration
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=100℃
IDM@TC=25℃
EAS
Units
Drain-Source Voltage
40
V
Gate-Source Voltage
±20
V
G
50
A
G
30
A
105
A
60
mJ
A
Total Power Dissipation
A
5.0
W
A
3.2
W
-55 to 150
Continuous Drain Current, VGS @ 10V
C
Pulsed Drain Current
Avalanche Energy ,Single Pulse (L=0.3mH)
Avalanche Current
IAS
PD@TA=25℃
PD@TA=70℃
TJ
Rating
TSTG
Storage and Junction Temperature Range
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
A
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
A
Typ.
Max.
Unit
60
℃/W
4.6
℃/W
Rev1.Apr.2019
WSD4050DN
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
RDS(ON)
RDS(ON)
VGS(th)
Parameter
Drain-Source Breakdown Voltage
Static Drain-Source On-Resistance
2
Gate Threshold Voltage
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
orward Transconductance
Rg
Gate Resistance
Qg
Total Gate Charge (10V)
Qgs
Qgd
Td(on)
Tr
Td(off)
Tf
VGS=0V , ID=250uA
2
△VGS(th)
gf
gfs
Conditions
Gate-Source Charge
VGS=10V , ID=7A
VGS=4.5V , ID=5A
Rise Time
Turn-Off Delay Time
Fall Time
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
40
Max.
Unit
V
7.4
9.5
mΩ
10
12
mΩ
1.5
2.0
V
-6.
mV/℃
VDS=32V , VGS=0V , TJ=25℃
2
VDS=32V , VGS=0V , TJ=55℃
10
VGS=±20V , VDS=0V
±100
nA
VDS=5V , ID=20A
70
S
VDS=0V , VGS=0V , f=1MHz
1.8
2.7
Ω
22
45
5.5
7.5
3.0
5.1
7.5
2.0
23
3.0
1284
145
55
VDS=20V, VGS=10V, IDS=20A
VDS=20V,
RL=1Ω ,
VGS=10V,
RG=3Ω.
VDS=20V , VGS=0V , f=1MHz
1.0
Typ.
VGS=VDS , ID =250uA
Gate-Drain Charge
Turn-On Delay Time
Min.
uA
nC
ns
pF
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The Power
dissipation PDSM is based on R θJA t≤ 10s and the maximum allowed junction temperature of 150°C. The value in any given application depends on
the user's specific board design.
B. The power dissipation PD is based on TJ(MAX)=150°C, using junction-to-case thermal resistance, and is more useful in setting the upper
dissipation limit for cases where additional heatsinking is used.
C. Single pulse width limited by junction temperature TJ(MAX)=150°C.
D. The RθJA is the sum of the thermal impedance from junction to case RθJC and case to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using or equal to 4.5V
Figure 9: Maximum Forward Biased Safe
Operating Area (Note F)
100
0.001
0.01
0.1
1
10
100
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junction-toCase (Note F)
ZθJC Normalized Transient
Thermal Resistance
10
D=Ton/T
TJ,PK=TC+PDM.ZθJC.RθJC
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
RθJC=4.6°C/W
1
0.1
PDM
Single Pulse
Ton
T
0.01
1E-05
0.0001
0.001
0.01
0.1
1
10
100
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance (Note F)
www.winsok.tw
Page 4
Rev1.Apr.2019
WSD4050DN
N-Ch MOSFET
Typical Operating Characteristics (Cont.)
50
40
30
Current rating ID (A)
Power Dissipation (W)
40
30
50
75
100
125
150
TCASE (°C)
Figure 12: Power De-rating (Note F)
50
75
100
125
150
TCASE (°C)
Figure 13: Current De-rating (Note F)
10000
1
TA=25°C
Power (W)
Eoss(uJ)
1000
100
0.5
10
40
1
1E-05
0.1
10
1000
Pulse Width (s)
Figure 15: Single Pulse Power Rating Junctionto-Ambient (Note H)
VDS (Volts)
Figure 14: Coss stored Energy
ZθJA Normalized Transient
Thermal Resistance
0.001
10
1
In descending order
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
RθJA=55°C/W
0.1
0.01
PDM
Single Pulse
Ton
0.001
0.0001
0.001
0.01
0.1
1
10
T
100
1000
Pulse Width (s)
Figure 16: Normalized Maximum Transient Thermal Impedance (Note H)
www.winsok.tw
Page 5
Rev1.Apr.2019
Attention
1,AnyandallWinsokpowerproductsdescribedorcontainedhereindonothavespecificationsthatcanhandle
applicationsthatrequireextremelyhighlevelsofreliability,suchaslifeͲsupportsystems,aircraft'scontrolsystems,or
otherapplicationswhosefailurecanbereasonablyexpectedtoresultinseriousphysicaland/ormaterialdamage.
ConsultwithyourWinsokpowerrepresentativenearestyoubeforeusinganyWinsokpowerproductsdescribedor
containedhereininsuchapplications.
2,Winsokpowerassumesnoresponsibilityforequipmentfailuresthatresultfromusingproductsatvaluesthatexceed,
evenmomentarily,ratedvalues(suchasmaximumratings,operatingconditionranges,orotherparameters)listedin
productsspecificationsofanyandallWinsokpowerproductsdescribedorcontainedherein.
3,SpecificationsofanyandallWinsokpowerproductsdescribedorcontainedhereinstipulatetheperformance,
characteristics,andfunctionsofthedescribedproductsintheindependentstate,andarenotguaranteesofthe
performance,characteristics,andfunctionsofthedescribedproductsasmountedinthecustomer’sproductsor
equipment.Toverifysymptomsandstatesthatcannotbeevaluatedinanindependentdevice,thecustomershouldalways
evaluateandtestdevicesmountedinthecustomer’sproductsorequipment.
4,WinsokpowerSemiconductorCO.,LTD.strivestosupplyhighͲqualityhighͲreliabilityproducts.However,anyandall
semiconductorproductsfailwithsomeprobability.Itispossiblethattheseprobabilisticfailurescouldgiverisetoaccidents
oreventsthatcouldendangerhumanlivesthatcouldgiverisetosmokeorfire,orthatcouldcausedamagetoother
property.Whendesigningequipment,adoptsafetymeasuressothatthesekindsofaccidentsoreventscannotoccur.Such
measuresincludebutarenotlimitedtoprotectivecircuitsanderrorpreventioncircuitsforsafedesign,redundantdesign,
andstructuraldesign.
5,IntheeventthatanyorallWinsokpowerproducts(includingtechnicaldata,services)describedorcontainedhereinare
controlledunderanyofapplicablelocalexportcontrollawsandregulations,suchproductsmustnotbeexportedwithout
obtainingtheexportlicensefromtheauthoritiesconcernedinaccordancewiththeabovelaw.
6,Nopartofthispublicationmaybereproducedortransmittedinanyformorbyanymeans,electronicormechanical,
includingphotocopyingandrecording,oranyinformationstorageorretrievalsystem,orotherwise,withouttheprior
writtenpermissionofWinsokpowerSemiconductorCO.,LTD.
7,Information(includingcircuitdiagramsandcircuitparameters)hereinisforexampleonly;itisnotguaranteedfor
volumeproduction. Winsokpowerbelievesinformationhereinisaccurateandreliable,butnoguaranteesaremadeor
impliedregardingitsuseoranyinfringementsofintellectualpropertyrightsorotherrightsofthirdparties.
8,Anyandallinformationdescribedorcontainedhereinaresubjecttochangewithoutnoticeduetoproduct/technology
improvement,etc.Whendesigningequipment,refertothe"DeliverySpecification"fortheWinsokpowerproductthatyou
Intendtouse.
9,thiscatalogprovidesinformationasofSep.2014. Specificationsandinformationhereinaresubjecttochangewithout
notice.
