TSCR420CX6 / TSCR421CX6
Taiwan Semiconductor
Linear Constant Current Regulated LED Driver
DESCRIPTION
FEATURES
The TSCR420 & TSCR421 are Low-Side Constant
● LED drive current preset to 10mA
Current Regulator (CCR) for linear LED driving. The
● Continuous output current up to 300mA with an
device regulates with a preset 10mA nominal that can
external resistor
be adjusted with an external resistor up to 300mA. It is
● Very low enable current
designed for driving LEDs in strings and will reduce
● Easy paralleling of drivers to increase current
current at increasing temperatures to self-protect.
● Supply voltage up to 40V
Operating as a series linear CCR for LED string
● Digital PWM input up to 10kHz (TSCR421)
current control, it can be used in multiple applications,
● Good temperature coefficient vs. output current
as long as the maximum supply voltage to the device
● Compliant to RoHS Directive 2011/65/EU and in
is 2.0V, VEN=24V
REXT=5.1Ω
TSCR421
VOUT>2.0V, VEN=3.3V
Output Current
MIN
IEN
IRINT=10mA
Internal Resistor
SYMBOL
IOUT
mA
Voltage Drop (VREXT)
IOUT=10mA
VDROP
0.85
0.95
1.05
V
Minimum Output Voltage
IOUT>18mA
VOUT(MIN)
1.4
V
-0.07
-0.07
0.33
0.33
Output Current
vs. Temperature
TSCR420
VOUT>2.0V, VEN=24V
TSCR421
VOUT>2.0V, VEN=3.3V
Output Current
vs. Supply Voltage
TSCR420
VOUT>2.0V, VEN=24V
TSCR421
VOUT>2.0V, VEN=3.3V
2
ΔIOUT/IOUT
ΔIOUT/IOUT
%/°C
%/V
Version: B1708
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
TSCR420CX6 RFG
SOT-26
3,000pcs / 7”Reel
TSCR421CX6 RFG
SOT-26
3,000pcs / 7”Reel
FUNCTION BLOCK
OUT
EN
Regulator
Vref
Vref
REXT
RINT
GND
TSCR420/TSCR421
PIN DESCRIPTION
PIN NO.
NAME
FUNCTION
1
EN
2
OUT
Regulated output current
3
OUT
4
GND
Power ground
5
OUT
6
REXT
External resistor for adjusting output current
Enable for biasing transistor
3
Version: B1708
TSCR420CX6 CHARACTERISTICS CURVES
Figure 2. VOUT vs. IOUT (REXT=20Ω)
Figure 1. VOUT vs. IOUT (REXT=open)
Figure 3. VOUT vs IOUT (REXT=8.2Ω)
Figure 4. VEN vs IOUT (REXT=open)
Figure 5. VEN vs. IOUT (REXT=20Ω)
Figure 6. VEN vs. IOUT (REXT=8.2Ω)
4
Version: B1708
Figure 7. VEN vs. IEN (REXT=open)
Figure 8. VEN vs. IEN (A5)
Figure 9. VEN vs. IEN (REXT=8.2Ω)
5
Version: B1708
TSCR421CX6 CHARACTERISTICS CURVES
Figure 10. VOUT vs. IOUT (REXT=open)
Figure 11. VOUT vs. IOUT (REXT=20Ω)
Figure 12. VOUT vs. IOUT (REXT=8.2Ω)
Figure 13. VEN vs. IOUT (REXT=open)
Figure 14. VEN vs. IOUT (REXT=20Ω)
Figure 15. VEN vs. IOUT (REXT=8.2Ω)
6
Version: B1708
Figure 16. VEN vs. IEN (REXT=open)
Figure 17. VEN vs. IEN (REXT=20Ω)
Figure 18. VEN vs. IEN (REXT=8.2Ω)
Figure 19. PD vs. Ambient Temperature
7
Version: B1708
APPLICATION INFORMATION
The TSCR420 & TSCR421 are designed for driving low current LEDs with typical LED currents of 10mA to 300mA.
They provide a cost-effective way for driving low current LEDs compared with more complex switching regulator
solutions. Furthermore, they reduce the PCB board area of the solution as there is no need for external
components like inductors, capacitors and switching diodes
Figure 20 shows a typical application circuit diagram for driving an LED or string of LEDs. The device comes with
an internal resistor (RINT) of typically 95Ω, which in the absence of an external resistor, sets an LED current of
10mA (typical) from a VEN = 3.3V and VOUT = 1.4V for TSCR421; or VEN = 24V and VOUT = 1.4V for TSCR420. LED
current can be increased to a desired value by choosing an appropriate external resistor, R EXT.
The REXT vs IOUT graphs should be used to select the appropriate resistor. Choosing a low tolerance R EXT will
improve the overall accuracy of the current sense formed by the parallel connection of R INT and REXT.
REXT = VDROP / (IOUT – (VDROP/RINT))
Two or more TSCR420 & TSCR421 can be connected in parallel to construct higher current LED strings as shown
in Figure 21. Consideration of the expected linear mode power dissipation must be factored into the design, with
respect to the TSCR420 & TSCR421’s thermal resistance. The maximum voltage across the device can be
calculated by taking the maximum supply voltage and subtracting the voltage across the LED string.
VOUT = VS – VLED
PD = (VOUT × ILED) + (VEN × IEN)
As the output current of TSCR420 & TSCR421 increases, it is necessary to provide appropriate thermal relief to the
device. The power dissipation supported by the device is dependent upon the PCB board material, the copper area
and the ambient temperature. The maximum dissipation the device can handle is given by:
PD = (TJ(MAX) - TA) / RθJA
Refer to the thermal characteristic graphs on Page 4 for selecting the appropriate PCB copper area.
Vs Supply
Vs Supply
LED
String
Vref
Vref
OUT
Regulator
Vref
Vref
OUT
Regulator
Vref
Vref
REXT
RINT
EN
REXT
(Optional)
RINT
GND
TSCR420
TSCR421
Regulator
EN
TSCR420
TSCR421
OUT
TSCR420
TSCR421
EN
LED
String
REXT
(Optional)
GND
RINT
(Optional)
GND
Figure 20: Typical Application Circuit for Linear
Figure 21: Application Circuit for Increasing LED
Mode Current Sink LED Driver
Current
8
Version: B1708
APPLICATION INFORMATION (CONTINUE)
PWM dimming can be achieved by driving the EN pin. Dimming is achieved by turning the LEDs ON and OFF for a
portion of a single cycle. The PWM signal can be provided by a micro-controller or analog circuitry; typical circuit is
shown in Figure 22.
Vs Supply
Vs Supply
LED
String
LED
String
µC
EN
OUT
EN
OUT
Regulator
Vref
Regulator
Vref
Vref
Vref
REXT
RINT
REXT
(Optional)
RINT
GND
(Optional)
GND
TSCR421
TSCR420
Figure 22: Application Circuit for LED Driver with
PWM Dimming Functionality
Figure 23: Application Circuit for LED Driver with
High voltage EN Pin
9
Version: B1708
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOT-26
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
Nx = Device Code
N1 =TSCR420CX6
N2 =TSCR421CX6
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
10
Version: B1708
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular
purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
11
Version: B1708
很抱歉,暂时无法提供与“TSCR421CX6 RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.089711+0.49572
- 10+3.4762610+0.42136
- 25+3.2485225+0.39376
- 100+2.59811100+0.31492
- 250+2.41223250+0.29239
- 500+2.04118500+0.24742
- 1000+1.577211000+0.19118
