Q45AD9F
Q45AD9F
    BANNER
    Q45 NAMUR: GLASS FIBER OPTIC
Q45AD9F 数据手册
Q45AD9 NAMUR Series Sensor Datasheet No revision without agency approval. To view or download the latest technical information about this product, including specifications, dimensions, accessories, and wiring, go to www.bannerengineering.com. • • • • • • Designed for use with approved amplifiers and intrinsically safe barriers in explosive environments NAMUR compliant sensor with the rugged design and exceptional optical performance of Q45 series sensors Output passes ≤ 1.2 mA in the “dark” condition and ≥ 2.1 mA in the “light” condition Internal multi-turn SENSITIVITY (Gain) control accessible beneath hinged, oring sealed top cover Models are available with an integral cable or a quick-disconnect connector Supply voltage: 5 to 15 V DC WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Standard 2 m (6.5 ft) cable models are listed. To order the 9 m (30 ft) cable model, add suffix "W/30" to the cabled model number (Q459E W/30). Models with a QD connector require a mating cable (see Accessories list). Opposed Models - Emitter (E) and Receiver (R) Models Cable Performance Q459E 2 m (6.5 ft) Q459EQ 4-Pin Euro QD 880 nm, infrared Q45AD9R 2 m (6.5 ft) Range: 6meters (20 feet) Q45AD9RQ 4-Pin Euro QD Output Type Constant current ≤ 1.2 mA dark ≥ 2.1 mA light Retroreflective Models Retroreflective range is specified using one model BRT-3 P retroreflector (3-inch diameter). Actual sensing range may be more or less than specified, depending upon the efficiency and reflective area of the retroreflector(s) in use. Non-Polarized Models Cable Q45AD9LV 2 m (6.5 ft) Q45AD9LVQ 4-pin Euro QD Polarized Models Cable Q45AD9LP 2 m (6.5 ft) Q45AD9LPQ 4-pin Euro QD Original Document 38343 Rev. L Performance 680 nm, visible red Range: 9 m (30 ft) Performance 680 nm, visible red Range: 6 m (20 ft) Output Type Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light Output Type Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light 6 November 2020 38343 Q45AD9 NAMUR Series Sensor Diffuse Models Performance curves are based on a 90% reflectance white test card. Short Range Models Cable Q45AD9D 2 m (6.5 ft) Performance 880 nm, infrared Q45AD9DQ 4-pin Euro QD Range: 300 mm (12 in) Long Range Models Cable Performance Q45AD9DL 2 m (6.5 ft) Q45AD9DLQ 4-pin Euro QD 880 nm, infrared Range: 1 m (40 in) Output Type Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light Output Type Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light Convergent Models Convergent mode models operate at 680 nm, visible red. Performance curves are based on a 90% reflectance white test card. Models Cable Q45AD9CV 2 m (6.5 ft) Q45AD9CVQ 4-pin Euro QD Q45AD9CV4 2 m (6.5 ft) Q45AD9CV4Q 4-pin Euro QD Focus 38 mm (1.5 in) Spot size at focus: 1.3 mm (0.05 in) 100 mm (4 in) Spot size at focus: 1.5 mm (0.06 in) Output Type Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light Constant Current ≤ 1.2 mA dark ≥ 2.1 mA light Plastic Fiber Optic Models Performance curves are based on a 90% reflectance white test card. Models Cable Performance Output Type Q45AD9FP 2 m (6.5 ft) 660 nm, visible red Constant Current 4-pin Euro QD Range: varies by sensing mode and fiber optics used ≤ 1.2 mA dark ≥ 2.1 mA light Q45AD9FPQ Glass Fiber Optic Models Performance curves are based on a 90% reflectance white test card. Models Cable Performance Output Type Q45AD9F 2 m (6.5 ft) 880 nm, infrared Constant Current Q45AD9FQ 4-pin Euro QD Range: varies by sensing mode and fiber optics used ≤ 1.2 mA dark ≥ 2.1 mA light Models Cable Performance Output Type Q45AD9FV 2 m (6.5 ft) 650 nm, visible red Constant Current 4-pin Euro QD Range: varies by sensing mode and fiber optics used ≤ 1.2 mA dark ≥ 2.1 mA light Q45AD9FVQ Overview The Q45AD9 Series NAMUR Sensor is a rugged, self-contained two-wire sensor designed for use with certified intrinsically safe switching amplifiers and barriers (Approved Apparatus) with intrinsically safe circuits. The Q45AD9 Series NAMUR sensor is designed in accordance with DIN 19234 (IEC/EN 60947-5-6) for operation via two-wire connection to an Approved Apparatus controlled by the variable internal resistance of the sensor. The sensor varies the impedance across the sensor output, which passes 1 mA or less in the "dark" condition and 2 mA or more in the "light" condition. A highly visible red LED indicator is located beneath a raised transparent dome on top of the sensor. • SIGNAL—LED lights red when the sensor sees its modulated light source • POWER (Emitters only)—LED lights red when 5 to 15 V dc power is applied Multi-turn sensitivity control on top of sensor, beneath a transparent cover, allows precise sensitivity setting (turn clockwise to increase gain). 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 38343 Rev. L Q45AD9 NAMUR Series Sensor Models are available with either a 2 m (6.5 ft) or 9 m (30 ft) long attached PVC-covered cable, or a 4-pin M12/Euro-style quick disconnect (QD) connector. Quick disconnect models (with Q in the model number suffix) use MQD9-4.. mating cable (either straight or right angle connector; see Accessories on p. 9). Contact Banner Engineering for the availability of sensor models with 9 m (30 ft) long attached cable. Installation Instructions Ex/HazLoc Applications WARNING: • Explosive Atmospheres/Hazardous Locations • It is the user's responsibility to ensure that all local, state, and national laws, rules, codes, or regulations relating to the installation and use of this device in any particular application are satisfied. This device must be installed by a Qualified Person1, in accordance with this document and applicable regulations. WARNING: • Explosion Hazard • Do not disconnect equipment unless the power has been switched off or the area is known to be nonhazardous. CAUTION: Electrostatic Discharge (ESD) Special Conditions for Safe Use. Parts of the enclosure are non-conducting and may generate an ignitioncapable level of ESD. Cleaning of the equipment shall be done only with a damp cloth. General Notes and Conditions for Safe Use: • See Specifications and Wiring Diagrams for important information concerning entity parameters, permissible locations, electrical connections and certifications. • In addition to the warning above concerning user responsibility, the installation must comply with the following: ◦ All installations must comply with all manufacturer's instructions. ◦ U.S. Installations: The relevant requirements of the National Electrical Code® (ANSI/NFPA-70 (NEC®) and when appropriate ANSI/ISA-RP12.06.01 Installation of Intrinsically Safe Systems for Hazardous (Classified) Locations. ◦ Canadian Installations: The relevant requirements of the Canadian Electrical Code (CSA C22.1). ◦ ATEX and IECEx Installations: The relevant requirements of EN 60079-14 and applicable National regulations. • Do not attempt any repairs to this device; it contains no field-replaceable parts or components. Tampering and/or replacement with non-factory components may adversely affect the safe use of the system. • Approved Apparatus entity parameters must meet the following requirements: ◦ Voc or Vt ≤ Vmax ◦ Ca ≥ Ci + Ccable ◦ Isc or It ≤ Imax ◦ La ≥ Li + Lcable • Sensor Entity Parameters: ◦ Vmax (Ui) ≤ 15 V dc ◦ Imax (li) ≤ 60 mA ◦ Pi ≤ 225 mW ◦ Ci = 0.3 μF ◦ Li = 0 mH • Cable Entity Parameters (if unknown): ◦ Ccable = 60 pF/ft ◦ Lcable = 0.2 µH/ft • The ambient operating temperature range of the Sensors is –40 °C to +70 °C (–40 °F to +158 °F). • For U.S. installations, Class II and III, Division 2 applies only to model numbers ending in a Q suffix. • For intrinsically safe installations, sensors must be used with certified intrinsically safe switching amplifiers and barriers (Approved Apparatus) with intrinsically safe circuits that limit supply voltage and current in the event of failures. • Associated Apparatus is not required for installation of the devices within a Division 2 hazardous (classified) location when installed per the National Electrical Code. The maximum voltage for Division 2 installation is 15V dc. In Division 2 installations (without Associated Apparatus), observe Explosion Hazard warning at the beginning of this section. • Associated Apparatus is not required for installation of the devices within a Division 2 hazardous (classified) location when installed in, or through the wall of a suitable enclosure with provision for connection of rigid metal conduit per the Canadian Electrical Code, as acceptable to the local inspection authority having jurisdiction. The maximum rating for Division 2 installation is 15V dc, 60 mA. In Division 2 installations (without Associated Apparatus), observe Explosion Hazard warning at the beginning of this section. 1 A Qualified Person is a person who, by possession of a recognized degree or certificate of professional training, or who, by extensive knowledge, training and experience, has successfully demonstrated the ability to solve problems relating to the subject matter and work. P/N 38343 Rev. L www.bannerengineering.com - Tel: + 1 888 373 6767 3 Q45AD9 NAMUR Series Sensor • • • Maximum non-hazardous area voltage that the Approved Apparatus (intrinsically safe circuit) is connected to must not exceed 250V. Intrinsic safety ground, if required for the Associated Apparatus, shall be less than 1 ohm. Maximum connector torque: 6 ft-lbs. Wiring Connections Q45AD9 Series NUMAR sensors are intrinsically safe ONLY when used with certified intrinsically safe switching amplifiers and barriers (Approved Apparatus) with intrinsically safe circuits. Banner does not manufacture such devices; however, our applications engineers can refer you to suppliers of certified devices that will interface with Banner sensors. The user is responsible for proper installation and maintenance of this equipment, and must conform with the certification requirements relating to barriers and to maximum allowable capacitance and inductance of the field wiring. If in doubt about these requirements, our applications engineers can refer you to the appropriate authority. NAMUR Sensors with Attached Cable Hazardous Area NAMUR Sensor NAMUR Sensors with Quick-Disconnect Non-hazardous Area Hazardous Area Approved Apparatus br bu Power + Sensor – Input Non-hazardous Area NAMUR Sensor + – ≤ 15 V dc Approved Apparatus 1 br 2 bu 3 + Sensor – Input + Power ≤ 15 V dc – 4 Output Output Specifications for Q45 NAMUR Sensors Supply Voltage and Current 5 to 15 V DC; Supply voltage is provided by the amplifier to which the sensor is connected. Adjustments Multi-turn sensitivity control on top of sensor, beneath a transparent o-ring sealed cover, allows precise sensitivity setting (turn clockwise to increase gain). Indicators Indicator LEDs are highly visible, located beneath a raised transparent dome on top of the sensor. POWER (red) LED (emitters only) lights whenever 5 to 15 V dc power is applied SIGNAL (red) LED lights whenever the sensor sees its modulated light source Output Constant current output: ≤ 1.2 mA in the “dark” condition and ≥ 2.1 mA in the “light” condition Connections PVC-jacketed 2 m (6.5 ft) or 9 m (30 ft) cables, or 4-pin Euro-style quickdisconnect (QD) fitting are available. QD cables are ordered separately. See Accessories. Output Response Time Opposed mode receiver: 2 milliseconds on/0.4 milliseconds off. All others 5 milliseconds on/off (does not include amplifier response) Operating Conditions Temperature: –40 °C to +70 °C (–40 °F to +158 °F) Maximum relative humidity: 90% at 50 °C (non-condensing) Construction Molded thermoplastic polyester housing, o-ring sealed transparent Lexan® top cover, molded acrylic lenses, and stainless steel hardware. Q45s are designed to withstand 1200 psi washdown. The base of cabled models has a 1/2-inch NPS integral internal conduit thread. 2 Certifications Environmental Rating Banner tested to NEMA 6P, IEC IP67 2809 Application Note Special Conditions for Safe Use: Parts of the enclosure are non-conducting and may generate an ignition-capable level of ESD. Cleaning of the equipment must be done only with a damp cloth. IEC IECEx FMG 14.0029X ATEX FM12ATEX0094X FM20US0068X CoC 0003046293 (US) FM20CA0032X CoC 0003046293C (CAN) CCC 2020012315326173 Design Standards ATEX (European) 2 4 EN 60079-0, EN 60079-11 Lexan® is a registered trademark of General Electric Co. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 38343 Rev. L Q45AD9 NAMUR Series Sensor Design Standards Canada CAN/CSA C22.2: No.0-M91, No.142-M1987, No.157-92, No.213-M1987, No.1010.1, E60079-0 and E60079-11 United States FM Class 3600, 3610, and 3810; ANSI/ISA 61010-1 (82.02.01), 60079-0 and 60079-11 IECEx IEC 60079-0, IEC 60079-11 Approvals Q45AD9(a)(b), Q459E(b) a = Sensing mode D, DL, F, FP, FV, LV, LP, CV, CV4 or R. b = Connection method Q or blank ATEX (European) II 1 G Ex ia IIC T5 Ga Ta = -40°C to 70°C - 38343; Entity Entity Parameters: U i = 15 V DC, I i = 60 mA, P i = 225 mW, C i = 0.3 μF, L i = 0 mH. Canadian IS / I,II,III / 1 / ABCDEFG / T5 Ta = -40°C to 70°C - 38343; Entity I / 0 / Ex ia / IIC / T5 Ta = -40°C to 70° C - 38343; Entity (Non-incendive) NI / I / 2 / ABCD / T5 Ta = -40°C to 70°C Entity Parameters: V Max = 15 V DC, I Max = 60 mA, P i = 225 mW, C i = 0.3 μF, L i = 0 mH United States IS / I,II,III / 1 / ABCDEFG / T5 Ta = -40°C to 70°C - 38343; Entity I / 0 / AEx ia / IIC / T5 / Ga Ta = -40°C to 70°C - 38343; Entity (Non-incendive) NI / I / 2 / ABCD / T5 Ta = -40°C to 70°C S / II,III / 2 / FG* / T5 Ta = -40°C to 70°C *Class II and III, Division 2 applies only to model numbers ending in a Q suffix. Entity Parameters: V Max = 15 V DC, I Max = 60 mA, P i = 225 mW, C i = 0.3 μF, L i = 0 mH IECEx Ex ia IIC T5 Ta= -40 °C to +70 °C - 35331; Entity Entity Parameters: U i = 15 V DC, I i = 60 mA, C i = 0.3 μF, L i = 0 mH. II 1 G Ex ia IIC T5 Ga Ta = -40ºC to +70ºC FM12ATEX0094X IECEx FMG 14.0029X 2809 FM20US0068X FM20CA0032X CL I/II/III Div 1 Groups ABCDEFG T5 CL I Zn 0 AEx ia IIC T5 Ga 15-GA4BO-0492X Ex ia IIC T5 Banner Engineering Corp. 9714 Tenth Ave. N. Mpls, MN 55441 USA Banner Eng. Europe Park Ln., Culliganlann 2F Diegem BE 1831 INSTALL PER CONTROL DRAWING # 38343 Performance Curves Opposed Excess Gain Beam Pattern 1000 E X C E S S G A I N Q45AD9 E/R Opposed Mode 100 100 mm 4 in 50 mm 2 in 1.0 m 3.3 ft 10 m 33 ft 0 50 mm 2 in 100 mm 4 in 150 mm 6 in 100 m 330 ft DISTANCE P/N 38343 Rev. L 6 in Opposed Mode 0 10 1 0.1 m 0.33 ft Q45AD9 E/R 150 mm 0 1.2 m 4 ft 2.4 m 8 ft 3.6 m 12 ft 4.8 m 16 ft 6m 20 ft DISTANCE www.bannerengineering.com - Tel: + 1 888 373 6767 5 Q45AD9 NAMUR Series Sensor Retroreflective Non-Polarized Excess Gain 1000 E X C E S S G A I N Beam Pattern Excess Gain 1000 Q45AD9LV Retroreflective Mode 100 Q45AD9LV 75 mm With BRT-3 Reflector .10 m .33 ft 1.0 m 3.3 ft 3.0 in Retroreflective Mode 50 mm 2.0 in 25 mm 1.0 in 0 10 1 .01 m .033 ft Retroreflective Polarized 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 10 m 33 ft 0 3m 10 ft 6m 20 ft DISTANCE 9m 30 ft 12 m 40 ft E X C E S S Q45AD9LP Retroreflective Mode 100 15 m 50 ft .10 m .33 ft 1.0 m 3.3 ft Beam Pattern 15 mm 0.6 in Q45AD9D Diffuse Mode 10 mm 0.4 in 5 mm 0.2 in 0 10 10 mm 0.4 in 100 mm 4.0 in 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 1000 mm 40 in 0 100 mm 4.0 in 200mm 8.0 in 300 mm 12.0 in E X C E S S G A I N 0 1.5 m 5 ft 3m 10 ft 4.5 m 15 ft 6m 20 ft 7.5 m 25 ft DISTANCE Beam Pattern Diffuse Mode 400 mm 500 mm 16.0 in 20.0 in Beam Pattern 0.2 in 2.5 mm 0.1 in 0 0.1 m 0.33 ft 1m 3.3 ft 0 2.5 mm 0.1 in 5.0 mm 0.2 in 7.5 mm 0.3 in 0 10 m 33 ft 0.3 m 1 ft 0.6 m 2 ft 0.9 m 3 ft 1.2 m 4 ft 1.5 m 5 ft DISTANCE Excess Gain Beam Pattern 1000 100 Q45AD9CV 3.8 mm 0.15 in Convergent Mode 2.5 mm 0.10 in 1.2 mm 10 0.05 in 0 DISTANCE 0.3 in Convergent (CV4 and CV4Q Models) Convergent Mode 100 mm 4 in Diffuse Mode 5.0 mm DISTANCE Q45AD9CV 10 mm .4 in Q45AD9DL 7.5 mm 10 1 0.01 m 0.033 ft 1000 6 10 m 33 ft 100 DISTANCE Excess Gain 1 1 mm .04 in 3.0 in Q45AD9DL Convergent (CV and CVQ Models) G A I N 2.0 in 75 mm Excess Gain Diffuse Mode 100 DISTANCE E X C E S S 1.0 in 50 mm 1000 Q45AD9D 1 1.0 mm 0.04 in 25 mm Diffuse Long Range 1000 G A I N 0 With BRT-3 Reflector DISTANCE Diffuse Short Range E X C E S S 2.0 in 1.0 in 0 10 1 .01 m .033 ft 3.0 in Retroreflective Mode 25 mm With BRT-3 Reflector G A I N Q45AD9LP 75 mm 50 mm DISTANCE Excess Gain Beam Pattern 1000 mm 40 in 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 38 mm 1.5 in 75 mm 3.0 in 113 mm 4.5 in DISTANCE 150 mm 190 mm 6.0 in 7.5 in E X C E S S G A I N Q45AD9CV4 Convergent Mode 100 Q45AD9CV4 3.8 mm 0.15 in Convergent Mode 2.5 mm 0.10 in 1.2 mm 1 1 mm .04 in 0.05 in 0 10 10 mm .4 in 100 mm 4 in DISTANCE www.bannerengineering.com - Tel: + 1 888 373 6767 1000 mm 40 in 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 38 mm 1.5 in 75 mm 3.0 in 113 mm 4.5 in 150 mm 190 mm 6.0 in 7.5 in DISTANCE P/N 38343 Rev. L Q45AD9 NAMUR Series Sensor Plastic Fiber Optic (Opposed Mode) Excess Gain Plastic Fiber Optic (Diffuse Mode) Beam Pattern Excess Gain 1000 1000 E X C E S S G A I N Q45AD9FP Opposed Mode 100 45 mm Q45AD9FP 30 mm Opposed Mode 1.8 in PIT46U Fibers 15 mm PIT46U Fibers 10 mm 0.4 in 100 mm 4.0 in 0 PIT26U Fibers 15 mm PIT26U Fibers 1.2 in 0.6 in 0 10 1 1 mm 0.04 in 0.6 in 30 mm 1.2 in 45 mm 1.8 in 1000 mm 40 in 0 25 mm 1.0 in 50 mm 2.0 in DISTANCE E X C E S S G A I N Q45AD9FP 100 10 PBT26U Fiber Beam Pattern 1 mm 0.04 in Opposed Mode 100 Opposed Mode 37.5 mm IT23S fibers IT13S fibers 10 mm 0.4 in 100 mm 4 in 1.5 in 1.0 in IT23S Fibers 0 10 Q45AD9F 25.0 mm 12.5 mm 0.5 in 0 IT13S Fibers 12.5 mm 0.5 in 25.0 mm 1.0 in 37.5 mm 1.5 in 1000 mm 40 in 0 125 mm 5 in 250 mm 10 in 375 mm 15 in E X C E S S G A I N 0.06 in 2.4 mm 0.09 in 100 mm 4 in 0 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 40 mm 1.6 in 50 mm 2.0 in DISTANCE Beam Pattern Q45AD9F Diffuse Mode 100 Diffuse Mode 1.0 mm 0.5 mm BT23S fiber 10 0.02 in 1.0 mm 0.04 in 1.5 mm 10 mm 0.4 in 100 mm 4 in 1000 mm 40 in 0.04 in 0 BT13S Fiber 0.5 mm BT13S fiber 0.06 in 0.02 in BT23S Fiber 0 0.06 in 0 12.5 mm 25.0 mm 37.5 mm 50.0 mm 62.5 mm 0.5 in 1.0 in 1.5 in 2.0 in 2.5 in DISTANCE DISTANCE Excess Gain Q45AD9F 1.5 mm 1 1.0 mm 0.04 in 500 mm 625 mm 20 in 25 in DISTANCE Glass Fiber Optic, Visible Red (Diffuse Mode) Beam Pattern Excess Gain 1000 Beam Pattern 1000 Q45AD9FV Opposed Mode 100 Q45AD9FV 30 mm Opposed Mode 20 mm IT23S Fibers IT23S Fibers 10 mm 10 mm 0.4 in 100 mm 4 in DISTANCE P/N 38343 Rev. L 1000 mm 40 in 0.8 in 0 10 mm IT13S Fibers 1.2 in 0.4 in 0 10 1 1.0 mm 0.04 in 0.03 in 1.6 mm Excess Gain Glass Fiber Optic, Visible Red (Opposed Mode) G A I N 10 mm 0.4 in 0 0.8 mm 1000 DISTANCE E X C E S S 0.03 in 0 Glass Fiber Optic, Infrared (Diffuse Mode) Q45AD9F 1 1.0 mm 0.04 in 0.06 in PBT46U Fiber DISTANCE 1000 G A I N 0.09 in 1.6 mm 0.8 mm DISTANCE Excess Gain Diffuse Mode 2.4 mm PBT46U Fiber 1 0.1 mm 0.004 in 100 mm 125 mm 4.0 in 5.0 in 75 mm 3.0 in Q45AD9FP Diffuse Mode Glass Fiber Optic, Infrared (Opposed Mode) E X C E S S Beam Pattern 0.4 in IT13S Fibers 20 mm 0.8 in 30 mm 1.2 in 0 100 mm 4 in 150 mm 6 in 200 mm 8 in DISTANCE 250 mm 300 mm 10 in 12 in E X C E S S G A I N Q45AD9FV Diffuse Mode Q45AD9FV 3.0 mm 100 Diffuse Mode 2.0 mm 1.0 mm 0 1.0 mm BT13S Fiber 0.04 in BT23S Fiber 2.0 mm BT23S Fiber 0.08 in 3.0 mm 1 1 mm 0.04 in 10 mm 0.4 in 100 mm 4.0 in DISTANCE www.bannerengineering.com - Tel: + 1 888 373 6767 1000 mm 40 in 0.08 in 0.04 in BT13S Fiber 0 10 0.12 in 0.12 in 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 20 mm 0.8 in 25 mm 1.0 in DISTANCE 7 Q45AD9 NAMUR Series Sensor Dimensions NAMUR Series Opposed, Retro, and Diffuse Sensing Modes (Model Suffix E, R, D, DL, LP, and LV) Cabled Models Quick-Disconnect 4-pin Euro-style Models 54.1 mm (2.13") 44.5 mm (1.75") Lens Centerline 50.8 mm (2.00") 69.0 mm (2.72") 6.4 mm (0.25") 87.6 mm (3.45") 4.5 mm (#10) Screw Clearance (2) 7.1 mm (0.28") 30.0 mm (1.18") Internal Thread (1/2–14NPSM) External thread (M30 x 1.5) hex nut supplied ø 6.1 (0.24") 2m (6.5') Cable Convergent Sensor Models (CV and CV4) 61.7 mm (2.43") 8 15 mm (0.6") Glass Fiber Optic Models (F and FV) 60.5 mm (2.38") www.bannerengineering.com - Tel: + 1 888 373 6767 Euro- or Micro-style QD Connector Plastic Fiber Optic Models (FP) 59.9 mm (2.36") P/N 38343 Rev. L Q45AD9 NAMUR Series Sensor Accessories Quick-Disconnect (QD) Cables 4-Pin Threaded M12/Euro-Style Cordsets (for use with NAMUR sensors)—Single Ended Model Length MQD9-406 2 m (6.56 ft) MQD9-415 5 m (16.4 ft) MQD9-430 9 m (29.5 ft) MQD9-406RA 2 m (6.56 ft) MQD9-415RA 5 m (16.4 ft) Style Dimensions Pinout (Female) 44 Typ. Straight M12 x 1 ø 14.5 3 4 30 Typ. [1.18"] Right-Angle MQD9-430RA 2 1 32 Typ. [1.26"] 1 = Brown 2 = Blue 9 m (29.5 ft) M12 x 1 ø 14.5 [0.57"] Replacement Lenses Replacement Lens Assemblies Models Description UC-45L Replacement lens for E, R, DL and LV models UC-45LP Replacement lens for LP UC-45D Replacement lens for D UC-45F Replacement lens for F and FV UC-45FP Replacement lens for FP UC-45C Replacement lens for CV UC-45C4 Replacement lens for CV4 Q45 Series lens assemblies are field-replaceable. Brackets Mounting Brackets SMB30C • • • 56 30 mm split clamp, black PBT bracket Stainless steel mounting hardware included A 66 B Mounting hole for 30 mm sensor SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 13 Hole center spacing: A=ø 45 Hole size: B=ø 27.2 P/N 38343 Rev. L 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 www.bannerengineering.com - Tel: + 1 888 373 6767 9 Q45AD9 NAMUR Series Sensor Mounting Brackets SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor 57 70 C 57 B A SMB30UR • 2-piece universal swivel bracket for limit-switch style sensors • 300 series stainless steel • Stainless steel swivel locking hardware included Hole center spacing: A to B=31.8, B to C=19.0, A to C=50.8, D=50.8 Hole size: C=6.9x32, D=73.0x6.9 Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 Repairs and Translations Obtain assistance with product repairs by contacting your local Banner Engineering Corp distributor or by calling Banner directly at (763) 544-3164. Access literature translated into your native language on the Banner website at www.bannerengineering.com or contact Banner directly at (763) 544-3164. Para reparaciones de productos, por favor contacte a su distribuidor local de Banner Engineering o llame a Banner directamente al (763) 544-3164. Vea la literatura traducida en su idioma en el sitio web Banner en www.bannerengineering.com o comuníquese con Banner directamente al (763) 544-3164. Pour vous aider lors de la réparation de produits, contactez votre distributeur Banner local our appelez directement Banner au (763) 544-3164. La documentation traduite dans votre langue est disponible sur le site internet de Banner www.bannerengineering.com ou contactez directement Banner au (763) 544-3164. Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
Q45AD9F 价格&库存
很抱歉,暂时无法提供与“Q45AD9F”相匹配的价格&库存,您可以联系我们找货
