MBR1035 – MBR10200
Taiwan Semiconductor
10A, 35V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
35 - 200
V
IFSM
150
A
TJ MAX
150
°C
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
Package
TO-220AC
Configuration
Single die
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.88g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current
8.3ms single half sine
wave superimposed on
rated load
Peak repetitive forward
current
(Rated VR, Square Wave,
20KHz)
Peak repetitive reverse
(1)
surge current
Voltage rate of change
(Rated VR)
MBR
1035
MBR
1035
MBR
1045
MBR
1045
MBR
1050
MBR
1050
MBR
1060
MBR
1060
VRRM
35
45
50
60
90
100
150
200
V
VR(RMS)
24
31
35
42
63
70
105
140
V
SYMBOL
MBR MBR MBR
1090 10100 10150
MBR MBR MBR
1090 10100 10150
MBR
UNIT
10200
MBR
10200
IF
10
A
IFSM
150
A
IFRM
A
IRRM
1
0.5
dV/dt
10,000
1
A
V/µs
Version: M2103
MBR1035 – MBR10200
PARAMETER
SYMBOL
MBR
1035
MBR
1045
MBR
1050
MBR
1060
MBR MBR MBR MBR
UNIT
1090 10100 10150 10200
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +175
°C
Notes:
1. tp = 2.0μs, 1.0KHz
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
MBR1035
MBR1045
MBR1050
MBR1060
MBR1090
MBR10100
MBR10150
MBR10200
MBR1035
MBR1045
MBR1050
MBR1060
MBR1090
MBR10100
MBR10150
MBR10200
MBR1035
MBR1045
MBR1050
MBR1060
MBR1090
MBR10100
MBR10150
MBR1035
MBR1045
MBR1050
MBR1060
MBR1090
MBR10100
MBR10150
MBR10200
SYMBOL
TYP
MAX
UNIT
0.70
V
0.80
V
0.85
V
1.05
V
0.57
V
0.70
V
0.71
V
V
100
µA
15
mA
10
mA
6
mA
IF = 10A, TJ = 25°C
VF
IF = 10A, TJ = 125°C
TJ = 25°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: M2103
MBR1035 – MBR10200
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR10x
TO-220AC
50 / Tube
MBR10xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBR1035) to 200V(MBR10200)
2. “H” means AEC-Q101 qualified
3
Version: M2103
MBR1035 – MBR10200
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
MBR1050-MBR10200
10
CAPACITANCE (pF)
8
6
MBR1035-MBR1045
4
1000
2
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=75°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10
1000
MBR1035-MBR1045
MBR1050-MBR1060
UF1DLW
1 MBR1090-MBR10100
100
MBR10150-MBR10200
TJ=125°C
0.1
10
TJ=25°C
TJ=125°C
0.01
1
TJ=25°C
Pulse width
300μs
Pulse
width
1% duty cycle
0.001
0.1
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1.2
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
MBR1035-MBR1060
MBR1090-MBR10200
10
(A)
AVERAGE FORWARD CURRENT (A)
12
150
120
90
60
30
1
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: M2103
1.2
MBR1035 – MBR10200
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: M2103
MBR1035 – MBR10200
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: M2103
MBR1035 – MBR10200
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: M2103
很抱歉,暂时无法提供与“MBR1090HC0G”相匹配的价格&库存,您可以联系我们找货
