Plastic-Encapsulate Transistors
TRANSISTOR (PNP)
FEATURES
z
Compliment to 2N3904U
z
Low current
z
Low voltage
MARKING: 2A
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
VCBO
Collector-Base Voltage
-40
Units
V
VCEO
Collector-Emitter Voltage
-40
V
V
VEBO
Emitter-Base Voltage
-6
IC
Collector Current -Continuous
-0.2
A
PC
0.5
W
250
℃/W
TJ
Collector Power Dissipation
Thermal resistance from junction
to ambient
Junction Temperature
150
Tstg
Storage Temperature
-55-150
RθJA
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=-10μA,IE=0
-40
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=-1mA,IB=0
-40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=-10μA,IC=0
-6
V
Collector cut-off current
ICBO
VCB=-30V,IE=0
-0.05
μA
-0.05
μA
-0.05
μA
Emitter cut-off current
EBO
VEB=-6V,IC=0
Collector ut-off current
ICEX
VCB=-30V,VBE(off)=-3V
DC current gain
Collector-emitter saturation voltage
Base-emitter saturation voltage
Transition frequency
hFE(1)
VCE=-1V,IC=-0.1mA
60
hFE(2)
VCE=-1V,IC=-1mA
80
hFE(3)
VCE=-1V,IC=-10mA
100
hFE(4)
VCE=-1V,IC=-50mA
60
hFE(5)
VCE=-1V,IC=-100mA
30
VCE(sat)1
IC=-10mA,IB=-1mA
-0.25
V
VCE(sat)2
IC=-50mA,IB=-5mA
-0.4
V
VBE(sat)1
IC=-10mA,IB=-1mA
-0.85
V
VBE(sat)2
IC=-50mA,IB=-5mA
-0.95
V
fT
VCE=-20V,IC=-10mA,f=100MHz
-0.65
300
250
MHz
Collector capacitance
Cc
VCB=-5V,IE=0,f=1MHz
4.5
pF
Emitter capacitance
Ce
VEB=-0.5V,IC=0,f=1MHz
10
pF
Noise figure
NF
4
dB
VCE=-5V,Ic=-0.1mA,f=10Hz-15.7kHz,
RS=1KΩ
Delay time
td
35
nS
Rise time
tr
35
nS
Storage time
tS
225
nS
Fall time
tf
75
nS
IC=-10mA , IB1=-IB2= -1mA
1 of 3
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
Static Characteristic
-18
-72uA
-56uA
-48uA
-9
-40uA
-32uA
-6
IC
COMMON EMITTER
VCE=-1V
Ta=25℃
hFE
-64uA
-12
Ta=100℃
DC CURRENT GAIN
COLLECTOR CURRENT
IC
(mA)
-80uA
-15
hFE
300
COMMON
EMITTER
Ta=25℃
-24uA
200
100
-16uA
-3
IB=-8uA
-0
-0.0
-0.5
-1.0
-1.5
-2.0
COLLECTOR-EMITTER VOLTAGE
VCEsat
-1
-0.3
-10
-3
COLLECTOR CURRENT
(V)
IC
VBEsat
-1.2
-100
-30
IC
Ta=100℃
Ta=25℃
-100
-30
IC
Ta=25℃
-0.8
Ta=100℃
-0.4
β=10
β=10
-10
-10
-0.0
IC
-200
IC
-1
-10
-3
(mA)
COLLECTOR CURRENT
—— VBE
Cob/ Cib
9
-100
-30
IC
-200
(mA)
VCB/ VEB
COMMON EMITTER
VCE=-1V
-100
f=1MHz
IE=0/IC=0
Ta=25℃
Cob
(pF)
-30
IC
Ta=100℃
Cib
C
-10
CAPACITANCE
(mA)
-200
-100
-30
COLLECTOR CURRENT
COLLECTOR CURRENT
-200
(mA)
-300
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (mV)
-600
VCE
-2.5
-3
Ta=25℃
-1
3
-0.3
-0.1
-0.2
-0.6
-0.4
-0.8
-1.0
-1.2
1
-0.1
-1.4
fT
1000
—— IC
-1
-3
REVERSE VOLTAGE
V
-0.3
BASE-EMMITER VOLTAGE VBE (V)
Pc
600
-10
-20
(V)
Ta
VCE=-20V
TRANSITION FREQUENCY
fT
COLLECTOR POWER DISSIPATION
Pc (mW)
(MHz)
Ta=25℃
300
100
-1
-3
-30
-10
COLLECTOR CURRENT
IC
500
400
300
200
100
(mA)
25
50
75
AMBIENT TEMPERATURE
100
Ta
125
2 of 3
a
150
SOT-89 PACKAGE OUTLINE
3 of 3
很抱歉,暂时无法提供与“2N3906U”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.14880
- 50+0.13764
- 200+0.12834
- 600+0.11904
- 1500+0.11160
- 3000+0.10695
