MBRD1045 THRU MBRD10200
10 AMP SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
45 to 100 Volts
CURRENT
10 Ampere
FEATURES
* Low forward voltage drop
* High current capability
* High reliability
* High surge current capability
* Epitaxial construction
TO-252
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Lead: Lead solderable per MIL-STD-202,
method 208 guranteed
* Polarity: As Marked
* Mounting position: Any
* Weight: 2.24 grams
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
MBRD
MBRD
MBRD
MBRD
1045
1060
10100
10150
10200
45
60
100
150
200
32
45
42
60
70
100
105
150
140
200
.375"(9.5mm) Lead Length at Tc=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 10A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
Ta=125 C
MBRD
150
0.70
0.85
0.90
0.05
0.2
400
8
-55 +150
-55 +150
V
V
V
A
10
0.55
UNITS
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Ambient Vertical PC Board Mounting 0.5"(12.7mm) Lead Length.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (MBRD1045 THRU MBRD10200)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
2
60
80
100
120
140
160
180
200
CASE TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
BR
D1
10
10
01
MB
50
-M
RD
45
10
10
RD
RD
5.0
MB
RD
1
4
10
MB
6
MB
8
10
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
12
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
150
.01
120
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
90
8.3ms Single Half
Tj=25 C
Sine Wave
60
JEDEC method
30
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
1400
1200
1000
800
600
400
10
Tj=75 C
1.0
Tj=25 C
.1
200
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“MBRD10100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.59220
- 100+0.55020
- 300+0.50820
- 500+0.46620
- 2000+0.44520
- 5000+0.43260
- 国内价格
- 5+0.70088
- 50+0.60999
- 150+0.57111
- 500+0.52255
- 2500+0.50086
- 5000+0.48790
