74AVCH1T45
Dual-supply voltage level translator/transceiver; 3-state
Rev. 5 — 6 January 2016
Product data sheet
1. General description
The 74AVCH1T45 is a single bit, dual supply transceiver that enables bidirectional level
translation. It features two 1-bit input-output ports (A and B), a direction control input (DIR)
and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any
voltage between 0.8 V and 3.6 V making the device suitable for translating between any of
the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins A and DIR are
referenced to VCC(A) and pin B is referenced to VCC(B). A HIGH on DIR allows
transmission from A to B and a LOW on DIR allows transmission from B to A.
The device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing any damaging backflow current through the
device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at
GND level, both A and B are in the high-impedance OFF-state.
The 74AVCH1T45 has active bus hold circuitry which is provided to hold unused or
floating data inputs at a valid logic level. This feature eliminates the need for external
pull-up or pull-down resistors.
2. Features and benefits
Wide supply voltage range:
VCC(A): 0.8 V to 3.6 V
VCC(B): 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114E Class 3B exceeds 8000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101C exceeds 1000 V
Maximum data rates:
500 Mbit/s (1.8 V to 3.3 V translation)
320 Mbit/s (< 1.8 V to 3.3 V translation)
320 Mbit/s (translate to 2.5 V or 1.8 V)
280 Mbit/s (translate to 1.5 V)
74AVCH1T45
Nexperia
240 Mbit/s (translate to 1.2 V)
Suspend mode
Bus hold on data inputs
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AVCH1T45GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AVCH1T45GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AVCH1T45GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AVCH1T45GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AVCH1T45GW
K5
74AVCH1T45GM
K5
74AVCH1T45GN
K5
74AVCH1T45GS
K5
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AVCH1T45
Product data sheet
All information provided in this document is subject to legal disclaimers.
2 of 24
Nexperia B.V. 2017. All rights reserved
74AVCH1T45
Nexperia
5. Functional diagram
',5
',5
9&&$
9&&%
9&&$
9&&%
DDJ
Fig 1.
DDJ
Logic symbol
Fig 2.
Logic diagram
6. Pinning information
6.1 Pinning
74AVCH1T45
74AVCH1T45
74AVCH1T45
VCC(A)
1
6
GND
2
5
DIR
A
3
4
B
VCC(A)
1
6
VCC(B)
GND
2
5
DIR
A
3
4
B
VCC(B)
Pin configuration SOT363
1
6
VCC(B)
GND
2
5
DIR
A
3
4
B
001aag888
aaa-000877
Transparent top view
001aag887
Fig 3.
VCC(A)
Fig 4.
Pin configuration SOT886
Fig 5.
Pin configuration SOT1115
and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
VCC(A)
1
supply voltage port A and DIR
GND
2
ground (0 V)
A
3
data input or output
B
4
DIR
5
direction control
VCC(B)
6
supply voltage port B
74AVCH1T45
Product data sheet
3 of 24
74AVCH1T45
Nexperia
7. Functional description
Table 4.
Function table[1]
Supply voltage
Input
Input/output[2]
VCC(A), VCC(B)
DIR[3]
A
B
0.8 V to 3.6 V
L
A=B
input
0.8 V to 3.6 V
H
input
B=A
GND[4]
X
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
[2]
The input circuit of the data I/O is always active.
[3]
The DIR input circuit is referenced to VCC(A).
[4]
If at least one of VCC(A) or VCC(B) is at GND level, the device goes into Suspend mode.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC(A)
Min
Max
Unit
supply voltage A
0.5
+4.6
V
VCC(B)
supply voltage B
0.5
+4.6
V
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
VO < 0 V
Active mode
50
0.5
+4.6
50
[1][2][3]
0.5
[1]
mA
V
mA
VCCO + 0.5 V
0.5
+4.6
V
IO
output current
VO = 0 V to VCCO
50
mA
ICC
supply current
ICC(A) or ICC(B)
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
Suspend or 3-state mode
[1]
Tamb = 40 C to +125 C
[4]
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
VCCO is the supply voltage associated with the output port.
[3]
VCCO + 0.5 V should not exceed 4.6 V.
[4]
For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC(A)
VCC(B)
VI
input voltage
Min
Max
Unit
supply voltage A
0.8
3.6
V
supply voltage B
0.8
3.6
V
V
74AVCH1T45
Product data sheet
Conditions
4 of 24
74AVCH1T45
Nexperia
Table 6.
Symbol
VO
Recommended operating conditions …continued
Parameter
Conditions
output voltage
Active mode
Min
Max
Unit
VCCO
V
V
40
+125
C
5
[1]
Tamb
ambient temperature
t/V
input transition rise and fall rate
VCCI = 0.8 V to 3.6 V
[1]
[2]
VCCI is the supply voltage associated with the input port.
[2]
ns/V
10. Static characteristics
Table 7.
Typical static characteristics at Tamb = 25 C[1][2]
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VOH
HIGH-level output voltage
Conditions
Min
Typ
Max
Unit
0.69
V
0.07
V
VI = VIH or VIL
IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V
VOL
LOW-level output voltage
VI = VIH or VIL
II
input leakage current
DIR input; VI = 0 V or 3.6 V;
VCC(A) = VCC(B) = 0.8 V to 3.6 V
IBHL
bus hold LOW current
VI = 0.42 V; VCC(A) = VCC(B) = 1.2 V
[3]
26
0.025 0.25 A
A
IBHH
bus hold HIGH current
VI = 0.78 V; VCC(A) = VCC(B) = 1.2 V
[4]
24
A
IBHLO
bus hold LOW overdrive
current
VI = GND to VCCI; VCC(A) = VCC(B) = 1.2 V
[5]
28
A
IBHHO
bus hold HIGH overdrive
current
[6]
26
A
IOZ
OFF-state output current
A or B port; VO = 0 V or VCCO;
[7]
0.5
2.5
A
IOFF
power-off leakage current
A port; VI or VO = 0 V to 3.6 V;
VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V
0.1
1
A
B port; VI or VO = 0 V to 3.6 V;
VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V
0.1
1
A
CI
input capacitance
DIR input; VI = 0 V or 3.3 V;
VCC(A) = VCC(B) = 3.3 V
1.0
pF
CI/O
input/output capacitance
A and B port; Suspend mode;
VO = VCCO or GND; VCC(A) = VCC(B) = 3.3 V
4.0
pF
[1]
[2]
VCCI is the supply voltage associated with the data input port.
[3]
The bus hold circuit can sink at least the minimum low sustaining current at VIL max. IBHL should be measured after lowering VI to GND
and then raising it to VIL max.
[4]
The bus hold circuit can source at least the minimum high sustaining current at VIH min. IBHH should be measured after raising VI to VCC
and then lowering it to VIH min.
[5]
An external driver must source at least IBHLO to switch this node from LOW to HIGH.
[6]
An external driver must sink at least IBHHO to switch this node from HIGH to LOW.
[7]
For I/O ports, the parameter IOZ includes the input leakage current.
74AVCH1T45
Product data sheet
5 of 24
74AVCH1T45
Nexperia
Table 8.
Static characteristics [1][2]
Symbol Parameter
VIH
HIGH-level
input voltage
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
VCCI = 0.8 V
0.70VCCI
0.70VCCI
V
VCCI = 1.1 V to 1.95 V
0.65VCCI
0.65VCCI
V
VCCI = 2.3 V to 2.7 V
1.6
1.6
V
VCCI = 3.0 V to 3.6 V
2
2
V
VCC(A) = 0.8 V
0.70VCC(A)
0.70VCC(A)
V
VCC(A) = 1.1 V to 1.95 V
0.65VCC(A)
0.65VCC(A)
V
VCC(A) = 2.3 V to 2.7 V
1.6
1.6
V
VCC(A) = 3.0 V to 3.6 V
2
2
V
VCCI = 0.8 V
0.30VCCI
0.30VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
0.9
0.9
V
VCC(A) = 0.8 V
0.30VCC(A)
0.30VCC(A) V
0.35VCC(A)
0.35VCC(A) V
0.7
0.7
V
0.9
0.9
V
VCCO 0.1
VCCO 0.1
V
IO = 3 mA;
VCC(A) = VCC(B) = 1.1 V
0.85
0.85
V
IO = 6 mA;
VCC(A) = VCC(B) = 1.4 V
1.05
1.05
V
IO = 8 mA;
VCC(A) = VCC(B) = 1.65 V
1.2
1.2
V
IO = 9 mA;
VCC(A) = VCC(B) = 2.3 V
1.75
1.75
V
IO = 12 mA;
VCC(A) = VCC(B) = 3.0 V
2.3
2.3
V
data input
DIR input
VIL
LOW-level
input voltage
data input
DIR input
VOH
HIGH-level
VI = VIH or VIL
output voltage
IO = 100 A;
74AVCH1T45
Product data sheet
6 of 24
74AVCH1T45
Nexperia
Table 8.
Static characteristics …continued[1][2]
Symbol Parameter
VOL
40 C to +85 C
Conditions
Max
Min
Max
0.1
0.1
V
IO = 3 mA; VCC(A) = VCC(B) = 1.1 V
0.25
0.25
V
IO = 6 mA; VCC(A) = VCC(B) = 1.4 V
0.35
0.35
V
IO = 8 mA;
0.45
0.45
V
IO = 9 mA; VCC(A) = VCC(B) = 2.3 V
0.55
0.55
V
IO = 12 mA;
0.7
0.7
V
1
1.5
A
15
15
A
VI = 0.58 V;
25
25
A
VI = 0.70 V;
45
45
A
VI = 0.80 V;
100
90
A
15
15
A
VI = 1.07 V;
25
25
A
VI = 1.60 V;
45
45
A
VI = 2.00 V;
100
100
A
125
125
A
200
200
A
300
300
A
500
500
A
125
125
A
200
200
A
300
300
A
500
500
A
5
7.5
A
LOW-level
VI = VIH or VIL
output voltage
IO = 100 A;
input leakage
current
IBHL
bus hold LOW A or B port
current
VI = 0.49 V;
IBHLO
bus hold HIGH A or B port
current
VI = 0.91 V;
overdrive
VCC(A) = VCC(B) = 1.6 V
current
VCC(A) = VCC(B) = 1.95 V
[3]
[4]
[5]
VCC(A) = VCC(B) = 2.7 V
VCC(A) = VCC(B) = 3.6 V
IBHHO
overdrive
current
[6]
IOZ
OFF-state
output current
74AVCH1T45
Product data sheet
Unit
Min
II
IBHH
40 C to +125 C
[7]
7 of 24
74AVCH1T45
Nexperia
Table 8.
Symbol Parameter
IOFF
power-off
leakage
current
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
5
35
A
5
35
A
VCC(A) = 0.8 V to 3.6 V;
8
12
A
VCC(A) = 3.6 V; VCC(B) = 0 V
8
12
A
VCC(A) = 0 V; VCC(B) = 3.6 V
2
8
A
8
12
A
supply current A port; VI = 0 V or VCCI; IO = 0 A
ICC
B port; VI = 0 V or VCCI; IO = 0 A
2
8
A
8
12
A
16
24
A
A plus B port (ICC(A) + ICC(B));
IO = 0 A; VI = 0 V or VCCI;
[1]
[2]
[3]
[4]
[5]
[6]
[7]
74AVCH1T45
Product data sheet
8 of 24
74AVCH1T45
Nexperia
11. Dynamic characteristics
Table 9.
Typical dynamic characteristics at VCC(A) = 0.8 V and Tamb = 25 C [1]
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8; for wave forms see Figure 6 and Figure 7
Symbol Parameter
tpd
VCC(B)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
propagation delay A to B
15.8
8.4
8.0
8.0
8.7
9.5
ns
B to A
15.8
12.7
12.4
12.2
12.0
11.8
ns
DIR to A
12.2
12.2
12.2
12.2
12.2
12.2
ns
tdis
disable time
ten
enable time
[1]
Conditions
DIR to B
11.7
7.9
7.6
8.2
8.7
10.2
ns
DIR to A
27.5
20.6
20.0
20.4
20.7
22.0
ns
DIR to B
28.0
20.6
20.2
20.2
20.9
21.7
ns
tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH.
ten is a calculated value using the formula shown in Section 13.4 “Enable times”
Table 10. Typical dynamic characteristics at VCC(B) = 0.8 V and Tamb = 25 C [1]
Symbol Parameter
Conditions
tpd
tdis
disable time
enable time
ten
[1]
VCC(A)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
15.8
12.7
12.4
12.2
12.0
11.8
ns
B to A
15.8
8.4
8.0
8.0
8.7
9.5
ns
DIR to A
12.2
4.9
3.8
3.7
2.8
3.4
ns
DIR to B
11.7
9.2
9.0
8.8
8.7
8.6
ns
DIR to A
27.5
17.6
17.0
16.8
17.4
18.1
ns
DIR to B
28.0
17.6
16.2
15.9
14.8
15.2
ns
Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 C [1][2]
Symbol Parameter
power dissipation
capacitance
CPD
[1]
Conditions
VCC(A) and VCC(B)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
A port: (direction A to B);
B port: (direction B to A)
1
2
2
2
2
2
pF
A port: (direction B to A);
B port: (direction A to B)
9
11
11
12
14
17
pF
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
[2]
fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = .
74AVCH1T45
Product data sheet
9 of 24
74AVCH1T45
Nexperia
Table 12. Dynamic characteristics for temperature range 40 C to +85 C [1]
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8; for wave forms see Figure 6 and Figure 7.
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V 0.1 V
1.5 V 0.1 V 1.8 V 0.15 V 2.5 V 0.2 V
3.3 V 0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
VCC(A) = 1.1 V to 1.3 V
tpd
tdis
propagation
delay
A to B
1.0
9.0
0.7
6.8
0.6
6.1
0.5
5.7
0.5
6.1
ns
B to A
1.0
9.0
0.8
8.0
0.7
7.7
0.6
7.2
0.5
7.1
ns
disable time
DIR to A
2.2
8.8
2.2
8.8
2.2
8.8
2.2
8.8
2.2
8.8
ns
DIR to B
2.2
8.4
1.8
6.7
2.0
6.9
1.7
6.2
2.4
7.2
ns
enable time
ten
DIR to A
17.4
14.7
14.6
13.4
14.3
ns
DIR to B
17.8
15.6
14.9
14.5
14.9
ns
4.6
0.5
3.7
0.5
3.5
ns
VCC(A) = 1.4 V to 1.6 V
tpd
propagation
delay
A to B
1.0
8.0
0.7
5.4
0.6
B to A
1.0
6.8
0.8
5.4
0.7
5.1
0.6
4.7
0.5
4.5
ns
tdis
disable time
DIR to A
1.6
6.3
1.6
6.3
1.6
6.3
1.6
6.3
1.6
6.3
ns
DIR to B
2.0
7.6
1.8
5.9
1.6
6.0
1.2
4.8
1.7
5.5
ns
DIR to A
14.4
11.3
11.1
9.5
10.0
ns
DIR to B
14.3
11.7
10.9
10.0
9.8
ns
A to B
1.0
7.7
0.6
5.1
0.5
4.3
0.5
3.4
0.5
3.1
ns
B to A
1.0
6.1
0.7
4.6
0.5
4.4
0.5
3.9
0.5
3.7
ns
enable time
ten
VCC(A) = 1.65 V to 1.95 V
propagation
delay
tpd
disable time
tdis
enable time
ten
DIR to A
1.6
5.5
1.6
5.5
1.6
5.5
1.6
5.5
1.6
5.5
ns
DIR to B
1.8
7.8
1.8
5.7
1.4
5.8
1.0
4.5
1.5
5.2
ns
DIR to A
13.9
10.3
10.2
8.4
8.9
ns
DIR to B
13.2
10.6
9.8
8.9
8.6
ns
propagation
delay
A to B
1.0
7.2
0.5
4.7
0.5
3.9
0.5
3.0
0.5
2.6
ns
B to A
1.0
5.7
0.6
3.8
0.5
3.4
0.5
3.0
0.5
2.8
ns
tdis
disable time
DIR to A
1.5
4.2
1.5
4.2
1.5
4.2
1.5
4.2
1.5
4.2
ns
DIR to B
1.7
7.3
2.0
5.2
1.5
5.1
0.6
4.2
1.1
4.8
ns
ten
enable time
DIR to A
13.0
9.0
8.5
7.2
7.6
ns
DIR to B
11.4
8.9
8.1
7.2
6.8
ns
tpd
tpd
tdis
A to B
1.0
7.1
0.5
4.5
0.5
3.7
0.5
2.8
0.5
2.4
ns
B to A
1.0
6.1
0.6
3.6
0.5
3.1
0.5
2.6
0.5
2.4
ns
disable time
DIR to A
1.5
4.7
1.5
4.7
1.5
4.7
1.5
4.7
1.5
4.7
ns
DIR to B
1.7
7.2
0.7
5.5
0.6
5.5
0.7
4.1
1.7
4.7
ns
DIR to A
13.3
9.1
8.6
6.7
7.1
ns
DIR to B
11.8
9.2
8.4
7.5
7.1
ns
enable time
ten
[1]
propagation
delay
74AVCH1T45
Product data sheet
10 of 24
74AVCH1T45
Nexperia
Table 13. Dynamic characteristics for temperature range 40 C to +125 C [1]
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V 0.1 V
3.3 V 0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tpd
tdis
propagation
delay
A to B
1.0
9.9
0.7
7.5
0.6
6.8
0.5
6.3
0.5
6.8
ns
B to A
1.0
9.9
0.8
8.8
0.7
8.5
0.6
8.0
0.5
7.9
ns
disable time
DIR to A
2.2
9.7
2.2
9.7
2.2
9.7
2.2
9.7
2.2
9.7
ns
DIR to B
2.2
9.2
1.8
7.4
2.0
7.6
1.7
6.9
2.4
8.0
ns
enable time
ten
DIR to A
19.1
16.2
16.1
14.9
15.9
ns
DIR to B
19.6
17.2
16.5
16.0
16.5
ns
tpd
propagation
delay
A to B
1.0
8.8
0.7
6.0
0.6
5.1
0.5
4.1
0.5
3.9
ns
B to A
1.0
7.5
0.8
6.0
0.7
5.7
0.6
5.2
0.5
5.0
ns
tdis
disable time
DIR to A
1.6
7.0
1.6
7.0
1.6
7.0
1.6
7.0
1.6
7.0
ns
DIR to B
2.0
8.3
1.8
6.5
1.6
6.6
1.2
5.3
1.7
6.1
ns
DIR to A
15.8
12.5
12.3
10.5
11.1
ns
DIR to B
15.8
13.0
12.7
11.1
10.9
ns
A to B
1.0
8.5
0.6
5.7
0.5
4.8
0.5
3.8
0.5
3.5
ns
B to A
1.0
6.8
0.7
5.1
0.5
4.9
0.5
4.3
0.5
4.1
ns
enable time
ten
propagation
delay
tpd
disable time
tdis
enable time
ten
DIR to A
1.6
6.1
1.6
6.1
1.6
6.1
1.6
6.1
1.6
6.1
ns
DIR to B
1.8
8.6
1.8
6.3
1.4
6.4
1.0
5.0
1.5
5.8
ns
DIR to A
15.4
11.4
11.3
9.3
9.9
ns
DIR to B
14.6
11.8
10.9
9.9
9.6
ns
propagation
delay
A to B
1.0
8.0
0.5
5.2
0.5
4.3
0.5
3.3
0.5
2.9
ns
B to A
1.0
6.3
0.6
4.2
0.5
3.8
0.5
3.3
0.5
3.1
ns
tdis
disable time
DIR to A
1.5
4.7
1.5
4.7
1.5
4.7
1.5
4.7
1.5
4.7
ns
DIR to B
1.7
8.0
2.0
5.8
1.5
5.7
0.6
4.7
1.1
5.3
ns
ten
enable time
DIR to A
14.3
10.0
9.5
8.0
8.4
ns
DIR to B
12.7
9.9
9.0
8.0
7.6
ns
tpd
tpd
tdis
A to B
1.0
7.9
0.5
5.0
0.5
4.1
0.5
3.1
0.5
2.7
ns
B to A
1.0
6.8
0.6
4.0
0.5
3.5
0.5
2.9
0.5
2.7
ns
disable time
DIR to A
1.5
5.2
1.5
5.2
1.5
5.2
1.5
5.2
1.5
5.2
ns
DIR to B
1.7
7.9
0.7
6.0
0.6
6.1
0.7
4.6
1.7
5.2
ns
DIR to A
14.7
10.1
9.6
7.5
7.9
ns
DIR to B
13.1
10.2
9.3
8.3
7.9
ns
enable time
ten
[1]
propagation
delay
74AVCH1T45
Product data sheet
11 of 24
74AVCH1T45
Nexperia
12. Waveforms
9,
90
$%LQSXW
*1'
W3+/
W3/+
92+
%$RXWSXW
90
DDH
92/
Measurement points are given in Table 14.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 6.
The data input (A, B) to output (B, A) propagation delay times
9,
',5LQSXW
90
*1'
W 3/=
RXWSXW
/2:WR2))
2))WR/2:
W 3=/
9&&2
90
9;
92/
W 3+=
92+
W 3=+
9<
RXWSXW
+,*+WR2))
2))WR+,*+
90
*1'
RXWSXWV
HQDEOHG
RXWSXWV
GLVDEOHG
RXWSXWV
HQDEOHG
DDH
Fig 7.
Table 14.
Enable and disable times
Measurement points
Supply voltage
Input[1]
Output[2]
VCC(A), VCC(B)
VM
VM
VX
VY
1.1 V to 1.6 V
0.5VCCI
0.5VCCO
VOL + 0.1 V
VOH 0.1 V
1.65 V to 2.7 V
0.5VCCI
0.5VCCO
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5VCCI
0.5VCCO
VOL + 0.3 V
VOH 0.3 V
[1]
[2]
74AVCH1T45
Product data sheet
12 of 24
74AVCH1T45
Nexperia
W:
9,
QHJDWLYH
SXOVH
90
90
9
WI
WU
WU
WI
9,
SRVLWLYH
SXOVH
90
90
9
W:
9(;7
9&&
9,
5/
92
'87
57
5/
DDH
Test data is given in Table 15.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance.
VEXT = External voltage for measuring switching times.
Fig 8.
Table 15.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VCC(A), VCC(B)
VI[1]
Load
t/V
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ[2]
1.1 V to 1.6 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
1.65 V to 2.7 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
3.0 V to 3.6 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
[1]
[2]
74AVCH1T45
Product data sheet
VEXT
13 of 24
74AVCH1T45
Nexperia
13. Application information
13.1 Unidirectional logic level-shifting application
The circuit given in Figure 9 is an example of the 74AVCH1T45 being used in a
unidirectional logic level-shifting application.
74AVCH1T45
VCC1
VCC(A)
GND
VCC1
A
1
6
2
5
3
4
system-1
VCC(B)
VCC2
DIR
VCC2
B
system-2
001aag889
Fig 9.
Table 16.
74AVCH1T45
Product data sheet
Description unidirectional logic level-shifting application
Pin
Name
Function
Description
1
VCC(A)
VCC1
supply voltage of system-1 (0.8 V to 3.6 V)
2
GND
GND
device GND
3
A
OUT
output level depends on VCC1 voltage
4
B
IN
input threshold value depends on VCC2 voltage
5
DIR
DIR
the GND (LOW level) determines B port to A port direction
6
VCC(B)
VCC2
supply voltage of system-2 (0.8 V to 3.6 V)
14 of 24
74AVCH1T45
Nexperia
13.2 Bidirectional logic level-shifting application
Figure 10 shows the 74AVCH1T45 being used in a bidirectional logic level-shifting
application. Since the device does not have an output enable pin, the system designer
should take precautions to avoid bus contention between system-1 and system-2 when
changing directions.
74AVCH1T45
VCC1
VCC1
VCC(A)
GND
I/O-1
A
1
6
2
5
3
4
VCC(B)
VCC2
DIR
VCC2
I/O-2
B
DIR CTRL
system-1
system-2
001aag890
Fig 10. Bidirectional logic level-shifting application
Table 17 gives a sequence that will illustrate data transmission from system-1 to system-2
and then from system-2 to system-1.
Table 17.
Description bidirectional logic level-shifting application[1]
State DIR CTRL I/O-1
I/O-2
Description
1
H
output
input
system-1 data to system-2
2
H
Z
Z
system-2 is getting ready to send data to system-1.
I/O-1 and I/O-2 are disabled. The bus-line state
depends on bus hold.
3
L
Z
Z
DIR bit is set LOW. I/O-1 and I/O-2 still are disabled.
The bus-line state depends on bus hold.
4
L
input
output
system-2 data to system-1
[1]
74AVCH1T45
Product data sheet
15 of 24
74AVCH1T45
Nexperia
13.3 Power-up considerations
The device is designed such that no special power-up sequence is required other than
GND being applied first.
Table 18.
Typical total supply current (ICC(A) + ICC(B))
VCC(A)
VCC(B)
Unit
0V
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
0V
0.1
0.1
0.1
0.1
0.1
A
0.8 V
0.1
0.1
0.1
0.1
0.1
0.7
2.3
A
1.2 V
0.1
0.1
0.1
0.1
0.1
0.3
1.4
A
1.5 V
0.1
0.1
0.1
0.1
0.1
0.1
0.9
A
1.8 V
0.1
0.1
0.1
0.1
0.1
0.1
0.5
A
2.5 V
0.1
0.7
0.3
0.1
0.1
0.1
0.1
A
3.3 V
0.1
2.3
1.4
0.9
0.5
0.1
0.1
A
13.4 Enable times
The enable times for the 74AVCH1T45 are calculate from the following formulas:
• ten (DIR to A) = tdis (DIR to B) + tpd (B to A)
• ten (DIR to B) = tdis (DIR to A) + tpd (A to B)
In a bidirectional application, these enable times provide the maximum delay from the
time the DIR bit is switched until an output is expected. For example, if the 74AVCH1T45
initially is transmitting from A to B, then the DIR bit is switched, the B port of the device
must be disabled before presenting it with an input. After the B port has been disabled, an
input signal applied to it appears on the corresponding A port after the specified
propagation delay.
74AVCH1T45
Product data sheet
16 of 24
74AVCH1T45
Nexperia
14. Package outline
3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV
627
Y 0 $
4
SLQ
LQGH[
H
ES
F
/S
Z 0 %
H
GHWDLO;
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
-(,7$
6&
627
Fig 11.
(8523($1
352-(&7,21
,668('$7(
Package outline SOT363 (SC-88)
74AVCH1T45
Product data sheet
17 of 24
74AVCH1T45
Nexperia
627
;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP
E
H
H
H
WHUPLQDO
LQGH[DUHD
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PP
PD[
QRP
PLQ
E
H
H
1RWHV
,QFOXGLQJSODWLQJWKLFNQHVV
&DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV
2XWOLQH
YHUVLRQ
627
VRWBSR
5HIHUHQFHV
-(,7$
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 12. Package outline SOT886 (XSON6)
74AVCH1T45
Product data sheet
18 of 24
74AVCH1T45
Nexperia
;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
'LPHQVLRQV
8QLW
PP
PP
VFDOH
E
H
H
PD[
QRP
PLQ
1RWH
9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 13. Package outline SOT1115 (XSON6)
74AVCH1T45
Product data sheet
19 of 24
74AVCH1T45
Nexperia
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
'LPHQVLRQV
8QLW
PP
PP
VFDOH
E
H
H
PD[
QRP
PLQ
1RWH
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 14. Package outline SOT1202 (XSON6)
74AVCH1T45
Product data sheet
20 of 24
74AVCH1T45
Nexperia
15. Abbreviations
Table 19.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
16. Revision history
Table 20.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AVCH1T45 v.5
20160106
Product data sheet
74AVCH1T45 v.4
74AVCH1T45 v.3
Modifications:
74AVCH1T45 v.4
Modifications:
74AVCH1T45 v.3
Modifications:
Table 16: Labels for pins 4 and 5 corrected.
20120803
Package outline drawing of SOT886 (Figure 12) modified.
20111027
Product data sheet
Product data sheet
74AVCH1T45 v.2
Added type number 74AVCH1T45GN (SOT1115/XSON6 package).
Added type number 74AVCH1T45GS (SOT1202/XSON6 package).
74AVCH1T45 v.2
20090505
Product data sheet
74AVCH1T45 v.1
74AVCH1T45 v.1
20071025
Product data sheet
74AVCH1T45
Product data sheet
21 of 24
74AVCH1T45
Nexperia
17. Legal information
17.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
17.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
17.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia's aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AVCH1T45
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
22 of 24
74AVCH1T45
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia's warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia's specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
17.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
18. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AVCH1T45
Product data sheet
23 of 24
74AVCH1T45
Nexperia
19. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
16
17
17.1
17.2
17.3
17.4
18
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 9
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Application information. . . . . . . . . . . . . . . . . . 14
Unidirectional logic level-shifting application . 14
Bidirectional logic level-shifting application. . . 15
Power-up considerations . . . . . . . . . . . . . . . . 16
Enable times . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 17
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 21
Legal information. . . . . . . . . . . . . . . . . . . . . . . 22
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 22
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 23
Contact information. . . . . . . . . . . . . . . . . . . . . 23
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
Date of release: 06 January 2016
