AO3401
P-Channel 30-V(D-S) MOSFET
V(BR)DSS
-30 V
RDS(on)MAX
60mΩ@-10V
70mΩ@-4.5V
100mΩ@-2.5V
ID
- 4.1A
FEATURE
APPLICATION
※ TrenchFET Power MOSFET
※ Load Switch for Portable Devices
※ Exceptional on-resistance and maximum DC current capability ※ DC/DC Converter
※ High dense cell design for extremely low RDS(ON)
MARKING
Equivalent Circuit
1.GATE
2.SOURCE
3.DRAIN
Maximum ratings ( Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
-30
Gate-Source Voltage
VGS
±12
ID
-4.1
IDM
-27
Continuous Source-Drain Current(Diode Conduction)
IS
-2
Power Dissipation
PD
1.4
W
RθJA
125
℃/W
TJ
150
TSTG
-55~+150
Continuous Drain Current
Pulsed Diode Curren
Thermal Resistance from Junction to Ambient (t≤5s)
Operating Junction
Storage Temperature
www.cj-elec.com
1/4
Unit
V
A
AO3401
MOSFET ELECTRICAL CHARACTERISTICS
Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted)
Parameter
Symbol
Test Condition
Min
V(BR)DSS
VGS = 0V, ID = -250µA
-30
VGS(th)
VDS =VGS, ID = -250µA
-0.6
Gate-source leakage
IGSS
Zero gate voltage drain current
IDSS
Typ
Max
Unit
Static
Drain-source breakdown voltage
Gate-source threshold voltage
Drain-source on-state resistancea
RDS(on)
V
-1.2
V
VDS =0V, VGS = ±12V
±100
nA
VDS = -30V, VGS =0V
1
µA
VGS = -10V, ID = -2.8A
50
60
mΩ
VGS = -4.5V, ID = -2.8A
55
70
mΩ
VGS = -2.5V, ID = -2A
71
100
mΩ
Forward transconductancea
gfs
VDS = -4.5V, ID = -4.1A
Diode forward voltage
VSD
IS=1A,VGS=0V
7
S
-0.7
-1.3
V
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitanceb
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Gate resistance
VDS = -15V,VGS =0V,
f=1MHz
VDS = -15V,VGS = -10V,
ID =-4.1A
Rg
f=1MHz
645
pF
80
pF
55
pF
14
nC
1.5
nC
2.5
nC
8
Ω
6.3
ns
3.2
ns
41
ns
9
ns
Switchingb
Turn-on delay time
Rise time
Turn-off delay time
Fall time
td(on)
tr
td(off)
VDD= -15V
RL=4Ω, ID ≈ -1A,
VGEN=- 10V,Rg=3Ω
tf
Drain-source body diode characteristics
Continuous Source-Drain Diode Current
Pulsed Diode forward Curren
IS
Tc=25 ℃
ISM
Note :
1. Repetitive Rating : Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t < 5 sec.
3. Pulse Test : Pulse Width≤300µs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production testing.
www.cj-elec.com
2/4
-1.3
A
-20
A
AO3401
Typical Characteristics:
www.cj-elec.com
3/4
AO3401
www.cj-elec.com
4/4
很抱歉,暂时无法提供与“AO3401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18732
- 200+0.16538
- 600+0.15320
- 3000+0.12214
- 9000+0.11580
- 21000+0.11239
- 国内价格
- 20+0.14754
- 200+0.13802
- 500+0.12850
- 1000+0.11898
- 3000+0.11422
- 6000+0.10756
