Preliminary Datasheet
LPM9926
20V Dual N-Channel MOSFET
General Description
Features
The LPM9926 uses advanced trench technology to
100% EAS Guaranteed
provide excellent RDS(ON) , low gate charge and
Green Device Available
operation with gate voltages as low as 1.8V while
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench technology
retaining a 12V VGS(MAX) rating. This device is suitable
for use as a uni-directional or bi-directional load
switch.
Order Information
LPM9926
Pin Description
Pin Number
Pin Description
Package Type
1
S2
SO:SOP8
2
G2
3
S1
4
G1
F: Pb-Free
Applications
Driver for Relay, Solenoid, Motor, LED etc.
DC-DC converter circuit
Power Switch
Load Switch
Charging
5
D2
6
7
D1
8
Pin Configurations
S2
G2
1
2
Marking Information
8
D2
7
D2
SOP8
S1
3
6
D1
G1
4
5
D1
Part
Marking
Package
Shipping
LPM9926SOF
LPS
SOP8
4K/REEL
LPM9926
YWX
Marking indication:
Y:Production year W:Production week
LPM9926-00
Jan.-2018
Email: marketing@lowpowersemi.com
X:Production batch.
www.lowpowersemi.com
Page 1 of 7
LPM9926
Absolute Maximum Ratings
Parameter
Symbol
Maximum
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±12
Continuous Drain Current
TA=25℃
TA=70℃
Pulsed Drain Current
Power Dissipation
TA=70℃
Junction and Storage Temperature Range
V
7.6
ID
6.1
IDM
TA=25℃
Unit
A
38
2
PD
W
1.28
TJ, TSTG
-55 to 150
Thermal resistance ratings
Parameter
Symbol
Junction-to-Case Thermal Resistance
t ≤ 10s
Steady State
Maximum Junction-to-Lead
Steady State
LPM9926-00
Jan.-2018
RθJA
RθJL
TYP
Unit
48
℃/W
74
℃/W
32
℃/W
Page 2 of 7
LPM9926
Electrical Characteristics
Electrical Characteristics (TJ=25℃ unless otherwise noted)
Symbol
Parameter
Conditions
Min
BVDSS
Drain-Source Breakdown Voltage
ID=250μA, VGS=0V
IDSS
Zero Gate Voltage Drain Current
IGSS
Typ
Max
Units
STATIC PARAMETERS
V
VDS=20V, VGS=0V
1
TJ=55℃
5
Gate-Body leakage current
VDS=0V, VGS=12V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=250μA
0.4
1.1
V
ID(ON)
On state drain current
VGS=10V, VDS=5V
38
RDS(ON)
Static Drain-Source On-Resistance
0.75
A
VGS=10V, ID=7.6A
16.5
23
TJ=125℃
25
30
VGS=4.5V, ID=7A
18.5
28
VGS=2.5V, ID=6A
24
38
gFS
Forward Transconductance
VDS=5V, ID=7.6A
25
VSD
Diode Forward Voltage
IS=1A, VGS=0V
0.7
IS
μA
Maximum Body-Diode Continuous Current
mΩ
S
1
V
2.5
A
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VGS=0V, VDS=15V, f=1MHz
VGS=0V, VDS=0V, f=1MHz
525
pF
95
pF
75
pF
1.7
Ω
12.5
nC
6
nC
1
nC
SWITCHING PARAMETERS
Qg (10V)
Total Gate Charge
Qg(4.5V)
Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
2
nC
tD(on)
Turn-On DelayTime
3
ns
tr
Turn-On Rise Time
VGS=10V, VDS=20V, RL= 2Ω,
7.5
ns
tD(off)
Turn-Off DelayTime
RGEN=3Ω
ns
tf
Turn-Off Fall Time
6
ns
trr
Body Diode Reverse Recovery Time
IF=7.6A, dI/dt=100A/μs
14
ns
Qrr
Body Diode Reverse Recovery Charge
6
nC
VGS=10V, VDS=15V, ID=7.6A
Typical Characteristics
LPM9926-00
Jan.-2018
Page 3 of 7
LPM9926-00
Jan.-2018
LPM9926
Page 4 of 7
LPM9926-00
Jan.-2018
LPM9926
Page 5 of 7
LPM9926-00
Jan.-2018
LPM9926
Page 6 of 7
LPM9926
Packaging Information
SOP8
LPM9926-00
Jan.-2018
Page 7 of 7
很抱歉,暂时无法提供与“LPM9926SOF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52101
- 50+0.42761
- 150+0.38091
- 500+0.34588
- 2500+0.31787
- 4000+0.30386
