PHOTONIC
Silicon Photodiode, U.V.
DETECTORS INC.
Enhanced Photovoltaic
Type PDU-V113
PACKAGE DIMENSIONS INCH (mm)
RED DOT INDICATES ANODE
0.140 [3.56] MAX
0.070 [1.78]
0.224 [5.69]
1.50 [38.1] MIN
WIRE
BONDS
ANODE
PHOTODIODE
CL
120°
VIEWING
ANGLE
Ø0.265 [6.73]
0.200 [5.08]
CL
Ø0.020 [0.51]
OPTICAL EPOXY
CATHODE
CERAMIC
0.125 [3.18]
SQUARE
CERAMIC PACKAGE
0.113 [2.87] SQ
ACTIVE AREA
ACTIVE AREA = 7.95 mm2
+90
O
TS
Soldering Temperature*
+240
O
IL
Light Current
C
C
mA
0.3
0.2
0.1
WAVELENGTH (nm)
*1/16 inch from case for 3 secs max
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
ISC
Short Circuit Current
H = 100 fc, 2850 K
ID
Dark Current
H = 0, VR = 10 V
Shunt Resistance
H = 0, V R = 10 mV
TC RSH
RSH Temp. Coefficient
H = 0, V R = 10 mV
CJ
Junction Capacitance
H = 0, V R = 0 V**
RSH
λrange
λp
V BR
NEP
tr
1200
-40
1100
Operating Temperature Range
900
TO
500
C
1000
O
800
+100
700
-40
0.4
600
Storage Temperature
00
=1
E
Q
0.5
500
V
400
75
0.6
300
TSTG
Reverse Voltage
SPECTRAL RESPONSE
0.7
190
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
V BR
APPLICATIONS
U.V. exposure meter
Water purification
Fluorescence
U.V. A & B meters
DESCRIPTION
The PDU-V113 is a silicon, PIN planar
diffused, U.V. enhanced photodiode. Ideal
for low noise photovoltaic applications.
Packaged on a two lead ceramic substrate
with a clear U.V. epoxy glob top.
RESPONSIVITY (A/W)
FEATURES
Low noise
U.V. enhanced
High shunt resistance
High response
Spectral Application Range Spot Scan
Spectral Response - Peak
Spot Scan
Breakdown Voltage
I = 10 m A
Noise Equivalent Power
VR = 10 mV @ Peak
Response Time
RL = 1 KΩ VR = 0 V
60
500
pA
200
MΩ
-8
% / oC
800
pF
250
30
UNITS
mA
80
300
100
MAX
1100
nm
850
nm
50
V
-14
6x10
750
W/
Hz
nS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. **f = 1 MHz
[FORM NO. 100-PDU-V113 REV A]
很抱歉,暂时无法提供与“PDU-V113”相匹配的价格&库存,您可以联系我们找货
