MBRF16H45
Taiwan Semiconductor
16A, 45V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Guard ring for over-voltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
45
V
IFSM
275
A
TJ MAX
150
°C
Package
ITO-220AC
Configuration
Single die
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak revers voltage
Reverse voltage total
rms value
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
(1)
Peak repetitive reverse surge current
Junction temperature
In DC forward mode
Storage temperature
MBRF16H45
UNIT
MBRF16H45
VRRM
45
V
VR(RMS)
31
V
IF
16
A
IFSM
275
A
IRRM
1
-55 to +150
-55 to +200
-55 to +150
A
TJ
TSTG
°C
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: G2105
MBRF16H45
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3.2
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 16A, TJ = 25°C
(2)
TJ = 25°C
TJ = 125°C
SYMBOL
TYP
MAX
UNIT
VF
0.63
V
500
µA
50
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
MBRF16H45
ITO-220AC
50 / Tube
2
Version: G2105
MBRF16H45
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
16
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
8
1000
100
4
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
100
10
1
10
UF1DLW
TJ=125°C
TJ=25°C
0.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
0.1
100
Fig.4 Typical Forward Characteristics
100
1
0.01
Pulse width 300μs
Pulse width
1% duty cycle
0.001
0.1
0.10.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.4
0.2
0.5
0.3
0.60.4 0.7 0.50.8
0.9
0.6
10.7 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
300
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
275
250
225
200
175
150
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2105
1.2
MBRF16H45
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2105
MBRF16H45
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: G2105
很抱歉,暂时无法提供与“MBRF16H45 C0G”相匹配的价格&库存,您可以联系我们找货
