www.hammondmfg.com
Plug-In Isolation Transformers (115VAC to 115VAC)
171A
Hammond Plug-In Isolation Transformers
Hammond isolation transformers provide complete circuit
isolation to protect your sensitive electronics. 171A features an
electrostatic shield between the primary and secondary which
greatly attenuates surges and noise caused by power problems
on the same circuit or by supply disruptions from utilities. Isolation transformers are an essential for laboratory test benches
where line voltage is used.
For safety concerns, every 171A has been hi-pot tested to 2KV
(115
RMS, and features a 1 amp circuit breaker on the primary. The
primary features a 5’ cord with a standard NEMA 5-15P plug.
The secondary is connected to a 1’ cord with a standard NEMA
5-15R receptacle. All units carry the North American mark of
safety C UL & UL listed (File # E211544).
Features
Primary 115VAC, 50/60 Hz., Secondary 115VAC
Provides complete circuit isolation.
Faraday electrostatic shield between primary & secondary to greatly attenuate surges and noise.
Hi-pot tested to 2 KV RMS.
Circuit breaker in primary.
Standard 3-wire, grounded plug & receptacle.
Input (primary) connected to 5 foot long cord & standard North American plug (NEMA 5-15P).
Output (secondary) connected to 1 foot long “pig tail” cord, 3-wire, standard North American grounded receptacle (NEMA 5-15R).
North American Mark of Safety - C UL & UL listed (File #E211544)
Indoor use only
Remember - These units do NOT convert line frequency
www.hammondmfg.com
171A
Electrical Specifications:
Primary Voltage
Secondary Voltage
Frequency
Capacity VA
Leakage Current
Full Load Efficiency
Full Load Total Harmonic Distortion
115VAC
115VAC
50 / 60 Hz
100
< 100 µA
89% (typical)
0.21% (typical)
Surge/ Noise Suppression
-37.7 dB (typical)
Capacitance Between Windings @ 1 kHz 15 pF (typical)
Circuit Breaker (Amps)
1A on primary
Dimensions
A
B
C
D
E
Weight
Cord Length (Primary)
Cord Length (Secondary)
Plug on Primary
3.8” / 97 mm
5.06” / 129 mm
4.68” / 119 mm
3” / 76 mm
3.38” / 86 mm
6.5 lbs / 2.95 kg
5ft / 1.52m
1ft/ 0.30m
NEMA 5-15P
Receptable on Secondary
NEMA 5-15R
1A Breaker
115V
50 / 60 Hz
115V
0.87A
很抱歉,暂时无法提供与“171A”相匹配的价格&库存,您可以联系我们找货
