OPERATION MANUAL
FOR
YC tools
The Quality Connection
(HAND CRIMP TOOL FOR LOOSE PIECE OPEN BARREL TERMINALS)
t t 't'l,'l/t/t+++t+l:H-'Ht t tlc+++l tlllll/t'lt
t-tl--H--l+--H--t-l+H+~~'l1/t/t/t/tl.i
1. General
The YC series hand crimp tools are used to crimp loose piece open barrel terminals to wire in the
recommended wire range for each terminal. Each tool has two crimping sections (A & B). Please refer
to tho chart to find which section should be used. Some tools come equipped with a locator spring to
aid in positioning of the terminal.
2. Crimp Operation
(1) Squeeze handles until the ratchet releases and handles open.
(2) Position a teminal in A or B section as shown in Fig. 1.
(3) If the tool is the locator-equipped type, place the terminal as shown in Fig. 3, so that the locator comes
between the wire barrel and the insulation barrel.
(4) Squeeze handles gently until the terminal is held by the dies per Fig. 2. Do not deform the terminal at
this stage.
(5) Now insert a wire, which is stripped per Fig. 4 into the barrels of the terminal.
(6) Squeeze handles completely until the ratchet releases, holding the wire by hand in the proper position.
(7) Open handles, remove the crimped terminal and inspect it. (See Fig. 5. )
r ···-1~_.--
_.------_ ..
__. _ - - - - - - - ,
I
I
wire barrel side
. insulation side
Fig. 1
Fig. 2
I
I
locator
terminal
wire barrel
insulatio~ barrel
~-lB
f~
wire
I
I
n
l+(O.5to 10mm)
shall not
have cracks
dmlff
shall not
have cracks
~-~J
Fig.3
Fig_ 4
Fig.5
Note: Refer to catalog for dimension l of barrel length.
3. Suggestions
a. Do not use tool if broken or damaged in any
way. Return to JST or the nearest representa
tive. Do not attempt to repair or adjust dies or
ratchet.
J. There are no adjustments for crimp heights in
this tool. For improved crimping, please consid
er the purchase or lease of one of JST's crimp
machine.
b. Periodically oil all parts of the tool and store in
paper or plastic bag when not in use.
k. The YC-2A, locator-equipped type of YC-2, is to
be applied to a-marked terminals only.
c. To check if a wire is crimped correctly. measure
wire tensile strength. Consult JST jf wire tensile
strength specifications are needed.
I. The prefix '8' or 'L' in the terminal part no.
denotes the terminal barrel configuration as
shown below.
The chain
terminals can be
terminated with the YC type crimping tool if they
are first cut into individual contacts (as in the case
of end to end terminals)or cut off their carrier strip
(as in the case of side terminals) _ In that case,
the barrel condition is as descrived with the suffix
d. Make sure correct tool and section are used for
each terminal.
e. Do not abuse tooi or use in a manner not
intended.
'B' .
f. The ratchet mechanism does not allow handles
to open until crimping is completed. Do not
open handles by force.
g. Do not use the tool with rust, damage or foreign
particles on the dies.
h. When hand crimping board-in terminals (**
marked ones). care should be taken not to con
taminate their solder tails, as with greasy or oily
fingers. If a solder problem arises, some cleaning
of the tips of the terminal may be advisable.
terminal
barrels
Type
Type
'l'
'B'
Fig. 0
m. I ne crimp height is not abjustable, therefore,
applicable wires are limited. Check the appear
ance and the tensile strength for every kind of
wire.
i. Before operation, make sure:
n. For any questions, please contact JST.
• Dies are clean without damage. rust or dirt.
• Ratchet mechanism functions well.
• Terminals are properly crimped. (Try a couple
of samples and check the appearance, etc.)
In line with a policy of continual product development,
JST reserves the right to change the specifications of the
goods at any time and without prior notice.
很抱歉,暂时无法提供与“YC-520”相匹配的价格&库存,您可以联系我们找货
