RP17-SC-212
RP17-SC-212
    HRS(广濑)
    RP17-SC-212
RP17-SC-212 数据手册
APPLICABLE STANDARD RATING -25 Operating temperature range C TO C +85 C TO -10 Storage temperature Range +60 C Voltage Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. Current 2 A Applicable cable AWG#18 TO 22 (Jacket diameter φ1.7 Max.) SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X X - X - X - X - X - CONSTRUCTION General examination Visually and by measuring instrument. Marking Confirmed visually. According to drawing. ELECTRIC CHARACTERISTICS Contact resistance Contact shall be measured AT DC 1 15 A m MAX. MECHANICAL CHARACTERISTICS Contact insertion and φ0.57 0 -0.003 By steel gauge. Insertion and withdrawal forces : 0.15 N MIN. withdrawal forces Mechanical operation 1000 Contact resistance: times insertions and extractions. 20 m MAX. Tensile strebgth Crimped only connector of the applicable wire and AWG #22(16/φ0.16) : 54 N MIN. (crimped connection) pulling the applicable wire AWG #20(27/φ0.16) : 60 N MIN. AWG #18(42/φ0.16) : 90 N MIN. ENVIRONMENTAL CHARACTERISTICS Corrosion salt mist COUNT Exposed in 5  salt water spray for 48 h. No heavy corrosion ruin the function. DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE △ 0 REMARK Unless otherwise specified, refer to IEC 60512 (JIS C 5402). Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test APPROVED EJ.KUNII 16.02.25 CHECKED EJ.KUNII 16.02.25 DESIGNED MM.ISHII 16.02.24 DRAWN MM.ISHII 16.02.24 DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. ELC-010243-00-00 RP17-SC-212 CL113-0509-2-00 0 △ 1/1
RP17-SC-212 价格&库存
很抱歉,暂时无法提供与“RP17-SC-212”相匹配的价格&库存,您可以联系我们找货
