APPLICABLE STANDARD
RATING
-25
Operating
temperature range
C TO
C
+85
C TO
-10
Storage temperature
Range
+60
C
Voltage
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
Current
2
A
Applicable cable
AWG#18 TO 22
(Jacket diameter φ1.7 Max.)
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
X
X
X
X
X
X
X
X
X
CONSTRUCTION
General examination
Visually and by measuring instrument.
Marking
Confirmed visually.
According to drawing.
ELECTRIC CHARACTERISTICS
Contact resistance
Contact shall be measured AT DC
1
15
A
m MAX.
MECHANICAL CHARACTERISTICS
Contact insertion and
φ0.57
By steel gauge.
Insertion and withdrawal forces :
0.15 N MIN.
withdrawal forces
Mechanical operation
1000
Contact resistance:
times insertions and extractions.
m MAX.
Tensile strebgth
Crimped only connector of the applicable wire and
AWG #22(16/φ0.16) :
54
N
MIN.
(crimped connection)
pulling the applicable wire
AWG #20(27/φ0.16) :
60
N
MIN.
AWG #18(42/φ0.16) :
90
N
MIN.
ENVIRONMENTAL CHARACTERISTICS
Corrosion salt mist
COUNT
Exposed in
5 salt water spray for 48 h.
No heavy corrosion ruin the function.
DESCRIPTION OF REVISIONS
DESIGNED
CHECKED
DATE
REMARK
Unless otherwise specified, refer to IEC 60512 (JIS C 5402).
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
APPROVED
EJ.KUNII
16.02.25
CHECKED
EJ.KUNII
16.02.25
DESIGNED
MM.ISHII
16.02.24
DRAWN
MM.ISHII
16.02.24
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-010243-00-00
RP17-SC-212
CL113-0509-2-00
很抱歉,暂时无法提供与“RP17-SC-212”相匹配的价格&库存,您可以联系我们找货
