RP17-PC-212
RP17-PC-212
    HRS(广濑)
RP17-PC-212 数据手册
Small-sized, plastic type, push-pull lock connectors RP17 Series ■Features 1. Superior mating operability ・ Secure mating and easy unmating is achieved by a push-pull locking mechanism. ・ White index markings are provided on the mating positions of the plug for easy mating alignment. ・Our proprietary guide key allows for blind mating conditions to be accomplished easily. Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Light weight and robust design The strong outer shell is made of glass-reinforced polycarbonate resin, and produces a light but highly durable connectors. 3. Anti-static electricity type The metal plates in the receptacle protect the signal lines from static electricity. ■Product Specifications Ratings Operating Rated Contact numbers 1, 3 to 10 : 2 A (when using a wire of at least 26 AWG) −10 to +60℃ current Contact numbers 2, 11, 12 : 5 A (when using a wire of at least 22 AWG) temperature range Rated Storage −10 to +60℃ AC100V, DC140V voltage temperature range Items Specifications 15mø max. 1. Contact resistance DIP Type : 20mø max. 2. Insulation 1,000Mø min. resistance 3. Withstanding No flashover or dielectric breakdown. voltage 4. Vibration No electrical discontinuity for 10µs or resistance greater. No electrical discontinuity for 10µs or 5. Shock resistance greater. Contact resistance : 20mø max. 6. Mating cycles Dip type : 25mø max. 7. Temperature cycle Insulation resistance : 1,000Mø min. 8. Moisture resistance Insulation resistance : 10Mø min. (at high humidities) 100Mø min. (when dry) Conditions Measured at DC 1A Measured at DC 500V AC 1000V for 1 minute 10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions, 2 hours each direction 2 Acceleration : 490m/s , duration : 11ms, 3 axis directions, 3 times each direction 1,000 times −55℃ : 30 minutes ➝ Normal temperature : 10 to 15 minutes ➝ 85℃ : 30 minutes ➝ Normal Temperature : 10 to 15 minutes, left for 5 cycles Temperature : 40℃ , relative humidity : 90 to 95%, left for 96 hours ■Materials / Finish Items Plug Material Finish Remarks Shell, insulator Polycarbonate resin ----------- UL94V-0 Clamp Brass ----------- ----------- Bushing Receptacle Shell, insulator Female contact Vinyl chloride resin ----------- ----------- Poly carbonate resin ----------- UL94V-0 Steel Nickel plating ----------- Phosphor bronze Silver plating ----------- Crimped female contact Female contact Phosphor bronze Silver plating ----------- Crimped male contact Male contact Phosphor bronze Silver plating ----------- In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2022.3 1 RP17 Series●Small-sized, plastic type, push-pull lock connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Plug RP17 A - 13 P A - 12 S C (01) ❶ ❷ ❸ ❹ ❺ ❻ ❼ Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ Model name : RP17 Series ❷ Type identification No marking : Standard type A : Anti-static electricity type ❸ Shell size : The shell size is measured at the outer diameter of the mating interface of the plug. ❹ Shell type P : Straight plug R : Receptacle J : Jack ❺ Shell variation : Connectors are distinguished by A, B, or C if another variation is applied in the same form. ❽ ❾ ❻ Number of contacts ❼ Contact form S : Female contact P : Male contact ❽ Contact termination method: C : Contact termination by crimping D : Straight PCB dipping method ❾ Other specifications : A two-digit character is added to indicate other specifications when needed. ● Crimp contact RP17 - SC - 2 1 2 ❶ ❾ ❶ Model name : RP17 ❾ Contact type : SC : Crimped female contact PC : Crimped male contact Contact form 1 : Loose piece contacts 2 : Reel contacts 2 Applicable wire gauge 1 : For 18 to 22 AWG 2 : For 24 to 30 AWG Type of plating 2 : Silver plating RP17 Series●Small-sized, plastic type, push-pull lock connectors ■Plug (standard type) B Ø15 ØA 36 (Representative example.) RP17-13P-12PC(71) HRS No. ØA B RP17-13P-12PC(71) 113-0501-0 71 5.3 46 RP17-13PA-12PC(71) 113-0512-7 71 6.1 51 Note : Cable clamping force, cable rotation force, and other aspects may differ depending on the cable construction. We recommend that you verify the suitability of the cable assembly before use or production. ■Plug (anti-static electricity type) 46 Ø15 Ø5.3 36 RP17A-13P-12PC(71) Part No. HRS No. RP17A-13P-12PC(71) 113-0551-9 71 Note : Cable clamping force, cable rotation force, and others aspects may differ depending on the cable construction. We recommend that you verify the suitability of the cable assembly before use or production. ■Receptacle (standard type) (Crimping type) 45° Ø1 9 5.5 2.5 Ø1 2-M2.6×0.45 2 1 5 12 7 25 20 7.5 5 3.2 Ø1 16.7 □9.7 Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. RP17-13R-12SC(71) Part No. HRS No. RP17-13R-12SC(71) 113-0502-3 71 3 RP17 Series●Small-sized, plastic type, push-pull lock connectors ■Receptacle (standard type) (PCB dip type) 45° 5 5.5 2.5 Ø1 Ø1 Ø1 2-M2.6×0.45 9 0.5×0.3 (Dip post diameter) 1 5 2 7 20 12 25 7.5 3.2 12 3.5 Part No. HRS No. RP17-13RA-12SD(71) 113-0511-4 71 Remarks : See page 5 for details on dip post assignment and layout. ■Receptacle (anti-static electricity type) (PCB dip type) 3.5 12 3.2 7.5 25 45° 20 RP17A-13RA-12SD(71) Part No. Ø1 9 5.5 0.5×0.3 (Dip post for signal contact) 1×0.4 (Dip post for ground contact) 2.5 Ø15 2-M2.6×0.45 Ø1 Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. RP17-13RA-12SD(71) 5 HRS No. RP17A-13RA-12SD(71) 113-0553-4 71 Remarks : See page 5 for details on dip post assignment and layout. ■Jack (standard type) (Representative example.) RP17-13J-12SC(71) HRS No. A ØB RP17-13J-12SC(71) 113-0515-5 71 44 5.3 RP17-13JA-12SC(71) 113-0516-8 71 49 6.1 Part No. Note : Cable clamping force, cable rotation force, and others aspects may differ depending on the cable construction. We recommend that you verify the suitability of the cable assembly before use or production. 4 RP17 Series●Small-sized, plastic type, push-pull lock connectors Dip post assignment and layout for receptacles (Figures show as when viewed from the receptacle mating side.) ● (Standard type) ● (Anti-static electricity type) d 12 un × Ø0 ro 12 × Ø0 2.4 1 7 10 7 1.2 3 3 1.6 11 3.8 3 10 12 12 1.2 3 4.6 2 6 1.2 1- 0.4 2.6 2.4 0.4 1 3 1.6 2.6 2 1 6 11 1.2 3 Remarks : The machining tolerance of ±0.05 is recommended for the PCB layout dimensions. ■Contact Male contact B 1.2 C A Applicable wire size RP17-PC-112 113-0503-6 1.6 2.1 18 to 22 AWG Loose piece contacts RP17-PC-122 113-0504-9 1.2 1.35 24 to 30 AWG Type A-A A Reel contacts 15 Female contact A-A A Part No. A B C RP17-PC-222 113-0508-0 1.2 1.35 24 to 30 AWG Applicable wire size Loose piece RP17-SC-112 113-0505-1 1.6 2.1 18 to 22 AWG contacts RP17-SC-122 113-0506-4 1.2 1.35 24 to 30 AWG Reel contacts 15 HRS No. RP17-PC-212 113-0507-7 1.6 2.1 18 to 22 AWG Type C B 1.2 Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 1 1 . Ø1 .7 G 1( 3.8 .7 t) ac nt co Part No. HRS No. B C RP17-SC-212 113-0509-2 1.6 2.1 18 to 22 AWG RP17-SC-222 113-0510-1 1.2 1.35 24 to 30 AWG Applicable tools Type Manual Auto Items Part No. RP17-TC-11 Manual crimping tools RP17-TC-12 Automatic CM-105C crimping press AP105-RP17-1 Applicator AP105-RP17-2 HRS No. Applicable contact Applicable wire size 150-0043-8 RP17-PC SC-112 18 to 22 AWG 150-0044-0 RP17-PC SC-122 24 to 30 AWG 901-0001-0 ---------------------- ---------------------- 901-2036-9 RP17-PC SC-212 18 to 22 AWG 24 to 30 AWG 901-2026-5 RP17-PC SC-222 Cable crimping tool RP17-TC-01 150-0042-5 ---------------------- ---------------------- Extraction tool RP6-SC-TP 150-0039-0 ---------------------- ---------------------- Extraction tool Cable crimping tool (The handle shape shown is a representative example.) Manual crimping tools Automatic crimping press (Type CM-105C) 5 RP17 Series●Small-sized, plastic type, push-pull lock connectors Termination procedure ● Plug Operation procedure Cable Cord tube 1. First, pass the terminated cable in the following order through the: cord tube, spring, connection sleeve, and cord bushing. Then crimp and terminate the contacts. 2. Assemble the crimped and terminated contacts to the contact holes of the P-insulation P case. At this time, please make sure that the crimped contacts are securely engaged onto the contact holes of the P-insulation P case by slightly pulling on the cable. 3. Attach the metal fitting by clamping to it the cord bushing and assemble these into the P-insulation P case. Then crimp the metal fitting by clamping it with the applicable tool (RP17-TC-01). 4. Next, attach in the following order to the P-insulation P case: connection sleeve, spring, and cord. Then align the screw hole of the cord tube and that of the metal fitting for clamping, and tighten the round flat screw to the specified torque of 0.15 to 0.2N·m. In addition, in order to prevent loosening of the screw, please apply Locktight 243 manufactured by Henkel Japan Ltd., Tokyo or equivalent. 5. After the assembly procedure described above has been completed, please make sure that the connection sleeve moves correctly. Round flat screw Spring Arrow view A Connection sleeve A Cord bushing 2 or more Metal fitting for clamping +3 20 − 2 3.2±0.3 Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P-insulation P case Contact arrangement 2 1 3 6 Contact arrangement 7 10 12 11 Remarks : 1. The figure shows the receptacle when viewed from the mating end (plug connection end). Precautions This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may cause tarnishing.  ・Dusty environments  ・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on. Example; In close proximity to factory exhaust, automotive emissions, etc.  ・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.  ・Close to rubber products includes rubber adhesives. The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins. Storage Packing state; Packed in original packing or equivalent container Temperature -10 to +60ç Humidity 85% Max (It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any temperature fluctuation) Please use this products within 6 months of delivery. (After 6 month, please check the solderbility before use) “Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB. Please note that the white label on the connector may come off due to solvents such as alcohol. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 6 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 03/2022. Contents are subject to change without notice for the purpose of improvements.
RP17-PC-212 价格&库存
很抱歉,暂时无法提供与“RP17-PC-212”相匹配的价格&库存,您可以联系我们找货
