SS32A~SS320A
Schottky rectifier
Features
Low profile package
Ideal for automated placement
Ultrafast reverse recovery time
Low power losses, high efficiency
Low forward voltage drop
High surge capability
High temperature soldering:
260℃/10 seconds at terminals
Component in accordance to
RoHS 2002/95/1 and WEEE 2002/96/EC
Major Ratings and Characteristics
Mechanical Date
Case: JEDEC DO-214AC molded plastic
IF(AV)
3.0A
Terminals: Solder plated, solderable per
VRRM
20 V to 200 V
J-STD-002B and JESD22-B102D
IFSM
100A
VF
0.50V, 0.55V, 0.70V, 0.85V,0.95V
Tj max.
125 °C
Polarity: Laser band denotes cathode end
Maximum Ratings & Thermal Characteristics
(TA = 25 °C unless otherwise noted)
Items
Symbol SS32A SS33A SS34ASS35A SS36ASS38ASS310ASS315A SS320A UNIT
Maximum repetitive peak
reverse voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS voltage
VRMS
14
21
28
35
42
56
70
105
140
V
Maximum DC blocking voltage
VDC
40
50
60
80
100
150
200
V
Maximum average forward
rectified current
IF(AV)
3
A
Peak forward surge current 8.3
ms single half sine-wave
superimposed on rated load
IFSM
100
A
Voltage rate of change
(rated VR)
dv/dt
10000
V/µs
Thermal resistance from
junction to lead (1)
RθJL
35
℃/W
TJ,TSTG
–65 to +125
Operating junction and storage
temperature range
Note 1: Mounted on P.C.B. with 0.28 x 0.28” (7.0 x 7.0mm) copper pad areas.
Electrical Characteristics
Items
Instantaneous forward
voltage
Reverse current
Test conditions
IF=3.0A(2)
VR=VDC
Tj=25℃
Tj=100℃
Symbol SS32ASS33~34A SS35~36ASS38~310ASS315~320A UNIT
VF
0.50
0.55
0.70
0.5
IR
5.0
0.85
0.95
V
mA
Note 2: Pulse test:300μs pulse width,1% duty cycle.
Rev : 01.06.2016
1/3
www.leiditech.com
SS32A~SS320A
Characteristic Curves (TA=25 ℃ unless otherwise noted)
Rev : 01.06.2016
2/3
www.leiditech.com
SS32A~SS320A
Package Outline
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2016
3/3
www.leiditech.com
很抱歉,暂时无法提供与“SS34A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.44494
- 50+0.36131
- 150+0.31949
- 500+0.28813
- 2500+0.23418
- 5000+0.22164
