SS5P6B
SS5P6B
    PINGWEI(平伟)
    SMB
    SS5P6B
SS5P6B 数据手册
SS5P6B 规格书 SS5P6B 5.0AMP S. SCHOTTKY BARRIER RECTIFIERS FEATURE SMB(DO-214AA) .For surface mounted application .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge current capability .High temperature soldering guaranteed: 260℃/10 seconds at terminals. .083(2.11) .075(1.91) .155(3.94) .130(3.30) .185(4.70) .160(4.06) .012(0.305) .006(0.152) .103(2.60) .078(1.98) MECHANICAL DATA .060((1.52) .032(0.80) .Terminal: Solder plated .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Packaging:12mm tape per EIA STD RS-481 .008(0.203) .002(0.051) .217(5.50) .193(4.9) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number SYMBOL Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TL=90°C SS5P6B units VRRM VRMS VDC 60 V 42 V 60 V IF(AV) 5.0 A IFSM 120.0 A VF Max VF Type 0.50 V Peak Forward Surge Current 8.3ms single half sine- wave superimposed on rated load (JEDEC method) Forward Voltage at 5.0A DC at 1.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C @TA =100°C Typical Junction Capacitance (Note1) Typical Thermal Resistance (Note 2) Storage Temperature Operation Junction Temperature 0.33 0.2 IR 10.0 CJ R(JA) R(JL) TSTG TJ 260 80 22 Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas. 1 mA pF °C/W -55 to +150 °C -55 to +150 °C SS5P6B 规格书 RATING AND CHARACTERISTIC CURVES (SS5P6B) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 5.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 2.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 10 TJ=25℃ Pulse Width=300μs 1% Duty Cycle 1 .1 200 .5 .3 .1 .7 0.9 INSTANEOUS FORWARD VOLTAGE,(V) LEAD TEMPERTURE,(℃) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 200 8.3ms Single Half Sine-Wave (JEDEC Method) 150 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 100 50 0 1 10 1.0 TJ=25℃ .1 .01 100 NUMBER OF CYCLES AT 60Hz 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) 2
SS5P6B 价格&库存
很抱歉,暂时无法提供与“SS5P6B”相匹配的价格&库存,您可以联系我们找货
