TSM12
12-Channel Self Calibration Capacitive Touch Sensor
SPECIFICATION V1.3
深圳市腾轩科技发展有限公司
科利科技(香港)有限公司
地址:福田区景田东路怡枫园C座1401
电话:0755-82814428 传真:0755-83041668
技术支持与意见反馈:
herit wy@163.com
herit @axmicro.cn
免费服务热线:400-008-7848
November 2006
ADSemiconductor Confidential
Revision History
Rev.
1.0
1.1
1.2
1.3
Description of change
Initial Release
Revision Flow chart , Appending 'Wait 100ms'
Revision Unused CS pin -> Connect with GND
Appending MLF package
Appending MLF package Dimension
Appending MLF package marking spec
Date
Originator
06.11.15
09.06.04
10.02.10
BM KIM
SB CHEONG
KD PARK
10.02.10
KDPARK
ADSemiconductor®
TSM12 (12-CH Auto Sensitivity Calibration Capacitive Touch Sensor)
1 Specification
1.1 General Feature
12-Channel capacitive sensor with auto sensitivity calibration
Selectable output operation (single mode / multi-mode)
Independently adjustable in 8 step sensitivity
Sync function for multi chip application
Touch intensity can be detectable within 3 steps (Low, Middle and High)
Adjustable internal frequency with external resister
Adjustable response time and interrupt level by the control registers
I2C serial interface
Embedded high frequency noise elimination circuit
IDLE mode to save the consumption
Embedded power key function on channel 1 for mobile phone application
RoHS compliant 32QFN, 32MLF packages
1.2
Application
Mobile application (mobile phone / PDA / PMP etc)
Membrane switch replacement
Sealed control panels, keypads
Door key-lock matrix application
Touch screen replacement application
1.3 Package (32QFN, 32MLF)
TSM12-32QFN
TSM12-32MLF
Drawings not to scale
1/36
ADSemiconductor®
2 Pin Description (32QFN, 32MLF)
PIN No.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Name
RBIAS
SRBIAS
CS5
CS6
CS7
CS8
CS9
N.C.
CS10
VDD
CS11
CS12
VSS
NC
IRBIAS
RST
OUT1
SCL
19
SDA
22
23
24
25
26
INT
I2C_EN
ID_SEL
P_CDEG0
P_CDEG1
P_CDEG2
VSS
27
28
29
30
31
32
Note 1
I/O
Analog Input
Analog Input
Analog Input
Analog Input
Analog Input
Analog Input
Analog Input
Analog Input
Digital Input
Analog Input
Analog Input
Ground
Analog Input
Digital Input
Digital Output
Digital Input
Digital
Input/Output
Digital Output
Digital Input
Digital Input
Digital Input
Digital Input
Digital Input
Digital Input
Description
Internal bias adjust input
IDLE Mode Internal bias adjust input
CH5 capacitive sensor input
CH6 capacitive sensor input
CH7 capacitive sensor input
CH8 capacitive sensor input
CH9 capacitive sensor input
No Connection
CH10 capacitive sensor input
CH11 capacitive sensor input
CH12 capacitive sensor input
Supply ground
No Connection
Internal I2C clk frequency adjust input
System reset (High reset)
CH1 output (Open drain)
I2C clock input
Protection
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD
VDD/GND
VDD/GND
VDD/GND
VDD/GND
I2C data (Open drain)
VDD/GND
Interrupt output (Open drain)
I2C enable(Low enable)
I2C address selection
Ch1 sensitivity selection bit0
Ch1 sensitivity selection bit1
Ch1 sensitivity selection bit2
Output mode selection
Digital
SYNC/OPT
(Single Output / Multi Output Note 1)
Input/Output
Sync pulse input /output
VDD
Power
Power (2.5V~5.0V)
CS1
Analog Input
CH1 capacitive sensor input
CS2
Analog Input
CH2 capacitive sensor input
CS3
Analog Input
CH3 capacitive sensor input
CS4
Analog Input
CH4 capacitive sensor input
Refer to 6.3 SYNC/OPT implementation
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
GND
VDD/GND
VDD/GND
VDD/GND
VDD/GND
2/36
ADSemiconductor®
3 Absolute Maximum Rating
Battery supply voltage
5.0V
Maximum voltage on any pin VDD+0.3
Maximum current on any PAD 100mA
Power Dissipation
800mW
Storage Temperature
-50 ~ 150℃
Operating Temperature
-20 ~ 75℃
Junction Temperature
150℃
Note Unless any other command is noted, all above are operated in normal temperature.
4 ESD & Latch-up Characteristics
4.1 ESD Characteristics
Mode
H.B.M
M.M
Polarity
Pos / Neg
Pos / Neg
Max
Reference
2000V
VDD
2000V
VSS
2000V
P to P
200V
VDD
200V
VSS
200V
P to P
500V
C.D.M
Pos / Neg
DIRECT
800V
4.2 Latch-up Characteristics
Mode
Polarity
Max
Positive
200mA
Negative
-200mA
Positive
8.0V
I Test
V supply over 5.0V
Test Step
25mA
1.0V
3/36
ADSemiconductor®
5 Electrical Characteristics
▪ VDD=3.3V, Rb=510k, Sync Mode (Rsync = 2MΩ) (Unless otherwise noted), TA = 25℃
Characteristics
Symbol
Test Condition
Min
Typ
Max
Units
Operating supply voltage
VDD
3.3
80
200
7
15
1.5
2.3
5.0
130
315
1
V
VDD= 3.3V RB=510k
VDD= 5.0V RB=510k
VDD= 3.3V RB=510k
VDD= 5.0V RB=510k
VDD= 3.3V RB=510k
VDD= 5.0V RB=510k
IDD_I2C Disable
2.5
4.0
CS
10
100
RS
200
1000
Ω
0.2
12
30M
100
80
VDD = 3.3V
200
510
820
VDD = 5.0V
330
620
1200
IDD
Current consumption
Note1
IDD_I2C
Output maximum sink
current
Sense input
capacitance range
IOUT
R_SB=0
R_SB=0
R_SB=3M
R_SB=3M
RI2C =20k
RI2C =30k
TA = 25℃
mA
Note2
Sense input
resistance range
Minimum detective
capacitance difference
Output impedance
(open drain)
Self calibration time after
system reset
Recommended bias
resistance range
Note3
ΔC
Zo
TCAL
RB
Cs = 10pF, CDEG = 200pF
(I2C default sensitivity select)
ΔC > 0.2pF, Cs = 10pF,
ΔC < 0.2pF, Cs = 10pF,
VDD = 3.3V RB = 510k
VDD = 5.0V RB = 510k
Ω
ms
kΩ
Maximum bias
CB_MAX
820
1000
pF
capacitance
Recommended sync
RSYNC
1
2
MΩ
resistance range
Note 1 : In case of SCL frequency is 500kHz.
Note 2 : The sensitivity can be increased with lower CS value.
The recommended value of CS is 10pF when using 3T PC(Poly Carbonate) cover and
10 ㎜ x 7 ㎜ touch pattern.
Note 3 : The lower RB is recommended in noisy condition.
4/36
ADSemiconductor®
6 Implementation of TSM12
6.1 RBIAS & SRBIAS implementation
VDD
CB
RBIAS
很抱歉,暂时无法提供与“TSM12M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.82760
- 10+4.16880
- 30+3.70440
- 100+3.31560
- 500+3.19680
- 1000+3.12120
