Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 4
MODEL: CEM-1205-IC | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• internally driven
• 5.0 Vdc rating
• 2400 Hz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
3.0
at rated voltage
rated frequency
sound pressure level
at 10 cm (A-weight), rated voltage
tone
continuous
dimensions
Ø12.0 x 9.5
2,250
2,400
87
92
Vdc
6.0
Vdc
30
mA
2,550
Hz
dBA
1.75
material
PBT (black)
terminal
pins (gold plating)
operating temperature
storage temperature
washable
units
mm
weight
g
-40
80
°C
-40
80
°C
max
units
380
°C
250
°C
yes
RoHS
Notes:
max
5.0
operating voltage
current consumption
typ
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
for maximum 2 seconds
330
wave soldering
Wave Solder Profile
3 Sec Max
250
2~5 °C/Sec
Temperature (°C)
130 °C/Sec
2~5 °C/Sec
110
25
40 Sec
60 Sec
Preheating
1.5
Sec Max
Melting
Time (sec)
cuidevices.com
100 Sec
Cooling
typ
Product Page
3D Model
CUI DEVICES | MODEL: CEM-1205-IC | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
CEM1205IC
01
Recommended PCB Layout
Top View
PERFORMANCE CURVES
Voltage vs. Current Consumption
at 10 cm, 25°C
Current Consumption (mA)
Sound Pressure Level (dB)
Voltage vs. Sound Pressure Level
at 10 cm, 25°C
95
90
85
80
75
3
4
5
6
7
8
30
25
10
3
Voltage (Vdc)
4
5
6
7
Voltage (Vdc)
cuidevices.com
8
Product Page
3D Model
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Tray Size: 184 x 180 x 23 mm
Tray QTY: 100 pcs per tray
Carton Size: 440 x 400 x 310 mm
Carton QTY: 6,000 pcs per carton
7UD\
/RW1R
3DUW1R
4XDQWLW\
;;;;3FV
'DWH
SFV7UD\
很抱歉,暂时无法提供与“CEM-1205-IC”相匹配的价格&库存,您可以联系我们找货
