LM358AM/TR
LM358AM/TR
    HGSEMI(华冠)
    SOP8_150MIL
    LM358AM/TR
LM358AM/TR 数据手册
LM358A DUAL OPERATIONAL AMPLIFIERS GENERAL DESCRIPTION The LM358A consists of two independent, high-gain, internally frequency-compensated operational amplifiers, which were designed specifically to operate from a single power supply over a wide range of voltages. The device operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Its application areas include transducer amplifiers, dc gain blocks and all the conventional operational amplifier circuits. PIN1 SOP8 PIN1 DIP8 FEATURES         Wide range of supply voltages Low supply current drain independent of the supply voltage Low input biasing current Low input offset voltage and offset current Input common-mode voltage range including the Ground Differential input voltage range equal to the power supply voltage DC voltage gain 100 V/mV (typ.) Internal frequency compensation APPLICATIONS    Transducer amplifiers Dc gain blocks Conventional op-amp circuits in single power supply systems ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty LM358AN DIP8 LM358A TUBE 2000/box LM358AM/TR SOP8 LM358A REEL 2500/reel PIN CONFIGURATION http://www.hgsemi.com.cn 1 2019 OCT V1.0 LM358A ABSOLUTE MAXIMUM RATINGS Parameter Supply voltage Input voltage Input current Maximum output current Maximum Operating Junction Temperature Storage Temperature Range Lead Temperature (soldering, 10 seconds) ESD protection (HBM) Symbol VСС VIN IIN IOUT TJ TSTG - Ratings 40V -0.3V to +45V 50mA at VIN = -0.3V 100mA -40C to 125C -65C to 150C 260C 700V Symbol VIN TJ Ratings 36V -40C to +85C RECOMMENDED OPERATING CONDITIONS Parameter Input Voltage Junction Temperature ELECTRICAL CHARACTERISTICS (At specified free-air temperature, VCC = 5V, unless otherwise specified) Parameter Input Offset Voltage Average Temperature Coefficient of Input Offset Voltage Input Offset Current Symbol VIO VIO lIO Conditions VCC = 5V to MAX, VIC = VICR(min), VO =1.4V VO = 1.4V Average Temperature Coefficient of Input Offset Current Input Bias Current lIO IIB VO = 1.4V Common-mode Input Voltage Range VICR VCC = 5V to MAX High-level Output Voltage VOH Low-level Output Voltage Large-signal Differential Voltage Amplification VOL AVD Common-mode Rejection Ratio Supply Voltage Rejection Ratio (Vcc/VIO) Crosstalk Attenuation Output Current CMRR VCC = MAX, RL = 2k VCC = MAX, RL  10k RL  10k VCC = 15V, VOUT = 1V to 11V, RL  2k VCC = 5V to MAX, VIC = VICR(min) Short-circuit Output Current http://www.hgsemi.com.cn Min 25C Typ 3 Full range Full range 7 25C Full range Full range 2 25C Full range 25C Full range Full range Full range Full range 25C -20 Max 7 9 µV/C 50 150 10 0 to Vcc-1.5 0 to Vcc-2.0 26 27 Unit mV nA pA/C -250 -500 nA V V 28 5 100 20 mV V/mV Full range 25С 25 15 65 80 dB 100 dB 120 -50 dB mA kSVR VCC = 5V to MAX 25С 65 VO1/VO2 lOUT f =1 kHz to 20 kHz VCC = 15V, VID = 1V, VO = 0 VCC = 15V, VID = -1V, VO = 15V VCC = 15V, VID = -1V, VO = 2V VID = - 1V, VO = 200mV VID = - 1V, VO = 15V 25С 25С Full range 25С Full range 25С -30 -20 15 7 15 35 28 mA 25С 12 50 A lOS 2 25С 50 70 mA 2019 OCT V1.0 LM358A VO = 2.5V, No load Full range 0.7 1.2 mA VCC = MAX, Full range 1 2 VO = 0.5VCC, No load SR 25С 0.7 V/µs Slew Rate VCC = 15V, VIN = 0.5 to 3V, RL = 2k, CL = 100pF, unity gain 25С 700 kHz GBW Gain Bandwidth VCC = 30V, f = 100kHz, VIN = 10mV, RL = 2k, CL = 100pF 25С 0.04 % THD Total Harmonic Distortion f = 1kHz, AV = 20dB, RL = 2k, VO = 2Vpp, CL = 100pF, *All characteristics are measured under the open-loop conditions with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 36V, Vcc(max) = 40V. Full range is -40С to +125С. Supply Current (two amplifiers) http://www.hgsemi.com.cn ICC 3 2019 OCT V1.0 LM358A BLOCK DIAGRAM http://www.hgsemi.com.cn 4 2019 OCT V1.0 LM358A http://www.hgsemi.com.cn 5 2019 OCT V1.0 LM358A “BI-QUAD” RC Active Bandpass Filter fo = 1 kHz Q =50 Av =100 (40 dB) http://www.hgsemi.com.cn 6 2019 OCT V1.0 LM358A Fixed Current Sources Lamp Driver Squarewave Oscillator http://www.hgsemi.com.cn Pulse Generator 7 2019 OCT V1.0 LM358A PACKAGE SOP8 Q B C C1 A D A1 a 0.25 b UNIT:mm DIM. A A1 B C C1 D MIN 4.520 0.100 4.800 5.800 3.800 0.400 TYP 4.570 4.920 6.100 3.900 - MAX 4.620 0.250 5.100 6.250 4.000 0.950 DIM. a b Q MIN 0.400 1.260 0° MAX 6.680 9.500 9.000 7.82 3.550 DIM. a b c d L L1 TYP 0.420 1.270 - MAX 0.440 1.280 8° DIP8 D1 L1 L E B d D A c a http://www.hgsemi.com.cn UNIT:mm DIM. A B D D1 E b 8 MIN 6.100 9.000 8.400 7.42 3.100 TYP 6.300 9.200 8.700 7.62 3.300 MIN 1.504 0.437 2.530 0.500 3.000 TYP 1.524 0.889 0.457 2.540 3.200 MAX 1.544 0.477 2.550 0.700 3.600 2019 OCT V1.0 LM358A Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 9 2019 OCT V1.0
LM358AM/TR 价格&库存
很抱歉,暂时无法提供与“LM358AM/TR”相匹配的价格&库存,您可以联系我们找货
LM358AM/TR
    • 1+0.97040
