LM358XK
LM358XK
    RUNIC(润石)
    SOP8
    LM358XK
LM358XK 数据手册
LM321/LM358/LM324 Dual Operational Amplifier FEATURES DESCRIPTION • Unity-gain bandwidth:1.1MHZ • Low input offset voltage:2mV (Typical) • Supply Range: 3V to 36V • Quiescent current:350uA per amplifier • Low input bias current: 20nA (Typical) • Common-mode input voltage range includes ground • Output Swing:0V~Vcc-1.5V • SPECIFIED UP TO +85°C • Micro SIZE The LM358 include two high-voltage(36-V) operational amplifiers. These devices provide outstanding value for Cost sensitive applications, with features including low offset 2mV(Typical),Common-mode input range to ground. the LM358 simplify circuit design with enhanced features such as unity-gain stability, lower quiescent current of 350uA per amplifier (Typical). The LM358 amplifier are specified at the full temperature range of −40°C to +85°C under single or dual power supplies of 3V to 36V. PACKAGES: SOIC-8(SOP8) Device Information (1) APPLICATIONS PART NUMBER • SENSORS • PHOTODIODE AMPLIFICATION • ACTIVE FILTERS • TEST EQUIPMENT • DRIVING A/D CONVERTERS LM321 LM358 LM324 PACKAGE SOT23-5 SOIC-8 SOIC-14 TSSOP-14 BODY SIZE(NOM) 2.90mm x 1.60mm 4.90mm x 3.90mm 8.65mm x 3.90mm 5.00mm x 4.40mm (1) For all available packages, see the orderable addendum at the end of the data sheet. Typical applications Unity-Gain Amplifier REV A.2 DC Coupled Low-Pass RC Active Filter 1 www.run-ic.com LM321/LM358/LM324 Pin Configuration and Functions (Top View) LM321 1 V- 2 -IN 3 5 V+ + +IN 4 OUT SOT23-5 Pin Description NAME PIN LM321 SOT23-5 I/O DESCRIPTION +IN V-IN OUT V+ 1 2 3 4 5 I I O - Positive (noninverting) input Negative (lowest) power supply Negative (inverting) input Output Positive (highest) power supply 2 www.run-ic.com LM321/LM358/LM324 Pin Configuration and Functions (Top View) LM358 OUT A 1 -IN A 2 +IN A 3 V- 4 + A B+ 8 V+ 7 OUTB 6 -IN B 5 +IN B SO IC-8(SOP8) Pin Description -INA +INA PIN SOIC-8(SOP8) 2 3 -INB NAME I/O DESCRIPTION I I Inverting input, channel A Noninverting input, channel A 6 I Inverting input, channel B +INB OUTA OUTB 5 1 7 I O O V- 4 - V+ 8 - Noninverting input, channel B Output, channel A Output, channel B Negative (lowest) power supply or ground (for single supply operation) Positive (highest) power supply 3 www.run-ic.com LM321/LM358/LM324 Pin Configuration and Functions (Top View) LM324 OUT A 1 14 OUT D -IN A 2 13 -IN D +IN A 3 12 +IN D V+ 4 11 V- +IN B 5 10 +IN C 9 -IN C 8 OUT C -IN B 6 OUT B 7 A - + - + B D + - + C SOIC-14(SOP14),TSSOP-14 Pin Description NAME -INA +INA -INB +INB -INC +INC -IND +IND OUTA OUTB OUTC OUTD VV+ PIN SOIC-14(SOP14)/TSSOP-14 2 3 6 5 9 10 13 12 1 7 8 14 11 4 I/O DESCRIPTION I I I I I I I I O O O O - Inverting input, channel A Noninverting input, channel A Inverting input, channel B Noninverting input, channel B Inverting input, channel C Noninverting input, channel C Inverting input, channel D Noninverting input, channel D Output, channel A Output, channel B Output, channel C Output, channel D Negative (lowest) power supply Positive (highest) power supply 4 www.run-ic.com LM321/LM358/LM324 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) MIN Voltage Current Temperature MAX 40 (V-)-0.5 (V+) +0.5 (V-)-0.5 (V+) +0.5 -10 10 -55 55 Continuous -40 85 150 -55 150 Supply, Vs=(V+) - (V-) Signal input pin (2) Signal output pin (3) Signal input pin (2) Signal output pin (3) Output short-circuit (4) Operating range, TA Junction, TJ Storage, Tstg UNIT V mA mA °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be currentlimited to 10mA or less. (3) Output terminals are diode-clamped to the power-supply rails. Output signals that can swing more than 0.5V beyond the supply rails should be current-limited to ±55mA or less. (4) Short-circuit to ground, one amplifier per package. ESD Ratings V(ESD) Electrostatic discharge Human-body model (HBM) Machine Model (MM) VALUE UNIT 3000 200 V Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) Supply voltage,Vs= (V+) - (V-) MIN 3 ±1.5 Single-supply Dual-supply NOM MAX 36 ±18 UNIT V Thermal Information: THERMAL METRIC (1) LM321 5PINS SOT23-5 273.8 LM358 8PINS SOIC-8 124.7 LM324 14PINS SOIC-14 TSSOP-14 83.8 120.8 UNIT RϴJA Junction-to-ambient thermal resistance RϴJC(top) Junction-to-case(top) thermal resistance 126.8 66.9 70.7 34.3 °C/W RϴJB Junction-to-board thermal resistance 85.9 67.9 59.5 62.8 °C/W ѰJT ѰJB Junction-to-top characterization parameter Junction-to-board characterization parameter Junction-to-case(bottom) thermal resistance 10.9 84.9 19.2 67.2 11.6 37.7 1 56.5 °C/W °C/W N/A N/A N/A N/A °C/W RϴJC(bot) 5 °C/W www.run-ic.com LM321/LM358/LM324 PACKAGE/ORDERING INFORMATION Orderable Device Package Type Pin Channel Op Temp(°C) Device Marking Package Qty LM321BXF SOT23-5 5 1 -40℃~85℃ LM321B Tape and Reel,3000 LM358XK SOIC-8(SOP8) 8 1 -40℃~85℃ LM358 Tape and Reel,2500 LM324XP SOIC-14(SOP14) 14 4 -40℃~85℃ LM324 Tape and Reel,2500 LM324XQ TSSOP-14 14 4 -40℃~85℃ LM324 Tape and Reel,3000 6 www.run-ic.com LM321/LM358/LM324 ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5V, RL = 10kΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS TJ LM358 MIN TYP MAX UNITS POWER SUPPLY Vs Operating Voltage Range Quiescent Current/Amplifier 25C 3 Vs=5V, Io=0mA Vs=30V, Io=0mA -40C to 85C Power-Supply Rejection Ratio Vs=5V to 30V 25C -40C to 85C 70 60 Vos Input Offset Voltage VCM= VS/2 25C -40C to 85C -5 Vos Tc Input Offset Voltage Average Drift -40C to 85C IB Input Bias Current VCM=0V IOS Input Offset Current VCM=0V IQ PSRR 36 420 650 100 V uA dB INPUT VCM CMRR Common-Mode Voltage Range Common-Mode Rejection Ratio ±2 5 7 7 Vs= 30V Vs= 5V, VCM=0V to (Vcc-1.5)V uV/C 20 25C -40C to 85C 25C -40C to 85C mV 150 200 30 100 Vcc1.5 5 25C 0 25C -40C to 85C 60 60 80 25C -40C to 85C 25C -40C to 85C 25C -40C to 85C 25C -40C to 85C 25C -40C to 85C 25C -40C to 85C 25C -40C to 85C 85 80 83 78 26 26 27 27 100 nA nA V dB OUTPUT Vs=15V, RL=2KΩ, Vo=1V to 11V AOL Open-Loop Voltage Gain Vs=15V, RL=10KΩ, Vo= 1V to 11V Vs=30V, RL=2KΩ VOH Output Swing From Rail VOL Vs=5V, RL=10KΩ ISOURCE VS=15V, VIN+=1V, VIN-=0V, Vo=2V Output current VS=15V, VIN-=1V, VIN+=0V, Vo=2V Short-circuit current VS=15V, VIN-=1V, VIN+=0V, Vo=0.2V VS=15V, Vo=0V ISINK ISC Vs=30V, RL=10KΩ dB 96 V 28 0.5 20 20 10 5 10 20 40 mV mA 15 mA 25C 50 uA 25C 40 0.35 1.1 56 22 10 V/us MHz ° us us 60 mA FREQUENCY RESPONSE SR GBP PM ts tOR Slew Rate Gain-Bandwidth Product Phase Margin Setting Time,0.1% Overload Recovery Time G=+1, CL=100pF VS=5V, G=+1, CL=100pF,Step=2V VIN·Gain≥VS,G=-100 25C 25C 25C 25C 25C Input Voltage Noise Input Voltage Noise Density f = 0.1Hz to 10Hz, Vs=5V 25C 0.9 uVpp f = 1KHz 25C 40 nV/√Hz NOISE En en 7 www.run-ic.com LM321/LM358/LM324 TYPICAL CHARACTERISTICS At TA = +25C, Vs= 36 V (±18 V), RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. OPEN−LOOP GAIN AND PHASE vs FREQUENCY 120 120 100 100 80 80 60 60 40 40 20 CMRR(dB) Phase Phase Margin (°) Gain 100 Open-Loop Gain(dB) 120 COMMON−MODE REJECTION RATIO vs FREQUENCY -20 10 1K 20 0 10M 100K 60 40 20 0 80 1 10 POWER−SUPPLY REJECTION RATIO vs FREQUENCY 10K Maximum Output Voltage vs Frequency 14 12 PSRR(dB) Output Swing(V) 100 80 60 10 40 8 6 4 2 0 20 1 10 100 1K 1 10K 10 Output Sinking Characteristics 8 Output Voltage Referenced to Vcc(V) 10 15V 5V 1 0.1 0.01 0.001 100 1000 Frequency(KHz) Vs=15V Frequency(KHz) Vs=5V Output Voltage(V) 1K Frequency(KHz) Vs=5V Frequency(Hz) 120 100 Output Characteristics Current Sourcing 7 6 5 4 3 2 1 0 0.01 0.1 1 10 0.01 100 0.1 1 10 100 Output Source Current(mA) Output Sinking Current(mA) 8 www.run-ic.com LM321/LM358/LM324 TYPICAL CHARACTERISTICS At TA = +25C, Vs= 36 V (±18 V), RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. SUPPLY VOLTAGE vs SUPPLY CURRENT INPUT CURRENT vs TEMPERATURE 0.8 0.6 Input Current(nA) Supply Current(mA) 0.7 0.5 0.4 0.3 0.2 0.1 0 0 20 Supply Voltage(V) 30 -50 40 QUIESCENT CURRENT vs TEMPERATURE 0.44 0.67 Supply Current(mA) Supply Current(mA) 0.68 10 20 18 16 14 12 10 8 6 4 2 0 0.66 0.65 0.64 -25 25 50 75 100 125 QUIESCENT CURRENT vs TEMPERATURE 0.43 0.42 0.41 0.63 0.4 -40 -20 0 20 40 60 80 100 120 140 160 -40 -20 0 20 40 60 80 100 120 140 160 Temperature(℃) Vs=5V Temperature(℃) Vs=30V 60 0 Temperature(℃) SOURCE CURRENT vs TEMPERATURE 25 SINK CURRENT vs TEMPERATURE 50 Sink Current(mA) Source Current(mA) 55 45 40 35 30 20 15 10 25 20 5 -40 -20 0 20 40 60 80 100 120 140 -40 -20 Temperature(℃) 0 20 40 60 80 100 120 140 Temperature(℃) 9 www.run-ic.com LM321/LM358/LM324 TYPICAL CHARACTERISTICS At TA = +25C, Vs= 36 V (±18 V), RL = 10kΩ connected to VS/2, VOUT = VS/2, unless otherwise noted. SMALL-SIGNAL STEP RESPONSE LARGE-SIGNAL STEP RESPONSE G=1,RL=open Vs=30V 1V/div 10mV/div G=1,RL=open Vs=30V Time(4us/div) Time(10us/div) Voltage Follower Small Signal Response Voltage Follower Large Signal Response G=1 CL=100pF Vs=30V 50mV/div 500mV/div G=1 CL=100pF Vs=30V Time(4us/div) Time(10us/div) Source Current Limiting 0.1Hz to 10Hz Input Voltage Noise 50 40 0.2uV/div Output Current(mA) 60 30 20 10 0 -40 -20 0 20 40 60 80 Time(1s/div) 100 120 Temperature(℃) 10 www.run-ic.com LM321/LM358/LM324 LAYOUT Layout Guidelines Attention to good layout practices is always recommended. Keep traces short. When possible, use a PCB ground plane with surface-mount components placed as close to the device pins as possible. Place a 0.1uF capacitor closely across the supply pins. These guidelines should be applied throughout the analog circuit to improve performance and provide benefits such as reducing the EMI susceptibility. Layout Example + VIN A + VIN B VOUT A RG VOUT B RG RF RF Figure 1. Schematic Representation Place compon ents close to device and to each other to reduce parasitic e rro rs. OUT A VS+ OUT A V+ -IN A OUT B +IN A -IN B Use low-ESR, ceramic bypass capacitor. Pla ce as close to the d evice as possible. GND RF OUT B GND RG VIN A RF GND RG V- Use low-ESR, ceramic bypass capacitor. Pla ce as close to the d evice as possible. +IN B Ground (GND) plane on another layer GND VS- VIN B Keep input traces short and run the input tra ces as far aw ay from the supply lines as possible. Figure 2. Layout Example 11 www.run-ic.com LM321/LM358/LM324 PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 12 www.run-ic.com LM321/LM358/LM324 SOIC-8(SOP8) b e 5.2 E1 E 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 13 www.run-ic.com LM321/LM358/LM324 SOIC-14(SOP14) e b 5.2 1.27 E E1 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 A c θ L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.310 0.510 0.012 0.020 c 0.100 0.250 0.004 0.010 D 8.450 8.850 0.333 0.348 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 14 www.run-ic.com LM321/LM358/LM324 TSSOP-14 e b 5.6 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 A A1 Symbol H C θ L Dimensions In Millimeters Min Max A Dimensions In Inches Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 15 1° 7° www.run-ic.com
LM358XK 价格&库存
很抱歉,暂时无法提供与“LM358XK”相匹配的价格&库存,您可以联系我们找货
LM358XK
    • 5+0.66150
    • 50+0.51030
    • 150+0.43470
    • 500+0.37800
    LM358XK
      • 1+1.00650
