Data Sheet
Bench LCR Meter
Model 891
The 891 is a compact, precise, and versatile LCR
meter capable of measuring inductors, capacitors,
and resistors at DC or from 20 Hz to 300 kHz.
The instrument’s 2U half-rack form factor is
suitable for the bench or rack mount installation.
A large color display with all important parameters
and measurements visible on one screen makes
this meter easy to operate.
The instrument’s convenient bin sorting function
enables quick sorting of components in different
bins defined by the user. A linear and logarithmic
sweep function is also provided to characterize
components over any range of frequencies from
20 Hz to 300 kHz.
Standard USB, GPIB, and LAN interfaces
enhance your productivity by providing remote
control capabilities to perform daily operations
in production, quality control, and laboratory
environments.
Features & Benefits
Compact 2U half-rack form factor with 4.3”
color display
0.05% best impedance accuracy
Measurement parameters include:
C/L/R/G/B/Y/D/Q/θ/DCR
Fully adjustable test frequency from 20 Hz to
300 kHz with 4-digit resolution
0.5 Vrms and 1 Vrms selectable test levels
300-point frequency sweep function
Bin sorting function - 9 primary bins with a
secondary and out-of-spec bin
Model
891
Best accuracy
0.05%
readout or better accuracy
Test frequency
Test levels
Technical data subject to change
© B&K Precision Corp. 2021
20 Hz - 300 kHz
www.bkprecision.com
Adjustable measurement speed for fast
for remote control
Save/recall up to 100 setups including 1000
measurements and screenshots
Bench LCR Meter
Model 891
Front panel
USB host port
Connect your USB flash drive to
conveniently store and recall
configurations, measurements,
and sweep test results.
4.3” color display
USB host port
Softkeys Local key
Numeric keypad
Arrow keys
Save/Recall
keys
Measurement
terminal
Power switch
Flexible test accessories
Menu keys
Each unit comes standard with Kelvin clip test leads for 4-wire measurements. The
optional test fixture allows users to conveniently measure axial and radial lead type
components.
Intuitive user interface
Easily change test parameters using the menu-driven front panel keypad and
easy-to-read color LCD. Convenient function keys let users quickly save/recall
up to 100 measurement setups.
Included Kelvin clips (TL89K1)
Optional Test Fixture (TL89F1)
Rear panel
LAN interface
GPIB interface
Chassis ground
SCPI-compliant
programming
The LCR meter can be
programmed remotely via the
USB (virtual COM), GPIB, and
LAN interface using SCPI
commands.
USB interface
2
AC line
Fuse capsule
selection switch
AC input
www.bkprecision.com
Bench LCR Meter
Model 891
Flexible operation
Bin comparator sorting function
Quickly sort components with the instrument’s
9 primary BINs, 1 secondary BIN, and 1
out-of-spec BIN. The results can be displayed
on a table or histogram and saved to a USB flash
drive. High and low limits for each bin can be set
up in absolute or tolerance mode with Pass/Fail
beep.
Histogram display, Table display, and Bin display
Linear and logarithmic sweep function
Characterize components up to 300 kHz using a
300-point linear or logarithmic sweep. Measured
values for each frequency point can be read
directly on the display. Sweep results can be
displayed on a graph or table and then saved to
a USB flash drive or read out through the remote
interface.
Linear sweep function, Logarithmic sweep function, and Linear & Logarithmic sweep function table
Built-in web server and LAN interface
Configure and control basic instrument settings
and take measurements from a remote computer
using a web browser. The 891 can also be
controlled with SCPI commands using a socket
or Telnet connection via the LAN interface.
Built-in web server interface
3
Display options
Users have the option to display up to 4 digits
resolution on primary and secondary
measurements in decimal or scientific notation.
Large display mode is also available for easy
viewing from a distance.
Large display mode
Remote PC control
Integrate your LCR meter into an automated test
system and control it from a PC using SCPI
commands via the standard USB, GPIB, or LAN
interface.
Communication setup
www.bkprecision.com
Bench LCR Meter
Model 891
Specifications
Measurements
Series mode
Parallel mode
Primary
Secondary
Primary
Secondary
Capacitance
Cs
Q, D, Rs
Cp
Q, D, Rp, G
Inductance
Ls
Q, D, Rs
Lp
Q, D, Rp, G
Resistance
R
X
Conductance
G
B
Impedance
Z
Admittance
θ
Y
DC Resistance
DCR
θ
Enhanced Measurement Functions
Bin Sorting Comparator
Limit Setting Mode
Tolerance (TOL) value or absolute (ABS) value
Number of Bins
9 primary bins, 1 secondary bin, and 1 out-of-spec bin
Bin Counts
0 to 60000
Beep Warning
Off, pass with smart tone and fail
Measurement Trigger
Manual trigger
Display Format
Measurement, table, and histogram
Frequency Range
20 Hz to 300 kHz
Sweep Modes
Sweep Points
Up to 300 points
Sweep Step
1, 2, 5, and 10 points/step
Parameters
Primary and secondary
Display Format
Graph and table
Sweep
Measurement Parameters
Measurement Speed
Slow
800 ms/measurement
Fast
200 ms/measurement
Measurement Range
Range
4
Auto or Hold range
www.bkprecision.com
Bench LCR Meter
Model 891
Specifications (cont.)
Test Signal
AC
Levels
Level Accuracy
Output Impedance
Frequency
5%
100 Ω (nominal)
20 Hz to 300 kHz
Resolution
0.01 Hz (20.00 Hz to 99.99 Hz)
0.1 Hz (100.0 Hz to 999.9 Hz)
1 Hz (1.000 kHz to 9.999 kHz)
100 Hz (100.0 kHz to 300.0 kHz)
Frequency Accuracy
± 0.1%
Level Range
Level Accuracy
Output Impedance
1 VDC
5%
100 Ω (nominal)
DC
Impedance Measurement (Z) Accuracy
(1)
Frequency
Impedance
0.1 Ω – 1 Ω
1 Ω – 100 Ω
100 Ω – 1 kΩ
1 kΩ – 10 kΩ
10 kΩ – 100 kΩ
100 kΩ – 1 MΩ
1 MΩ – 10 MΩ
10 MΩ – 20 MΩ
DC, 20 Hz – 1 kHz
1 kHz – 10 kHz
1% ± 1
0.5% ± 1
0.2% ± 1
0.05% ± 1
0.2% ± 1
0.5% ± 1
2% ± 1
4% ± 1
1% ± 1
0.5% ± 1
0.2% ± 1
0.2% ± 1
0.2% ± 1
0.5% ± 1
2% ± 1
5% ± 1
10 kHz– 100 kHz 100 kHz – 200 kHz 200 kHz – 300 kHz
2% ± 1
1% ± 1
0.5% ± 1
0.5% ± 1
1% ± 1
2% ± 1
5% ± 1
NA
5% ± 1
2% ± 1
0.5% ± 1
1% ± 1
1% ± 1
3% ± 1
5% ± 1
NA
10% ±1
4% ± 1
1% ± 1
2% ± 1
2% ± 1
4% ± 1
10% ± 1
NA
Save/Recall
Instrument Settings
Internal
External
10 locations
90 locations
Measurement Results and Screenshots
External
1000 locations
General
Remote Interface
Display
AC Input
Power Consumption
Operating Temperature
Storage Temperature
Relative Humidity
Dimension (L × W × H)
Weight
USB (Virtual COM), GPIB, LAN
4.3” 480 × 272 color LCD display
104 V - 126 V, 50/60 Hz
207 V - 253 V, 50/60 Hz
20 VA max.
32 °F to 104 °F (0 °C to 40 °C)
14 °F to 158 °F (-10 °C to 70 °C)
up to 80%
10.1” x 4.4” x 15” (258 × 113 × 381 mm)
7.5 lbs (3.4 kg)
Three-Year Warranty
Standard Accessories
Optional Accessories
Power cord, Kelvin clips leads, certificate of calibration & test report
TL89F1 test fixture (axial and radial)
(1)
Accuracy is based on test signal level at 1 Vrms with slow measurement speed.
At 0.5 Vrms test signal level, multiply Ae by 1.1.
5
www.bkprecision.com
Bench LCR Meter
Model 891
Measurement Accuracy Chart
6
v052721
www.bkprecision.com
