1000 Eaton Boulevard
Cleveland, OH 44122
United States
3-ft. Cat5e 350 MHz Snagless Molded Cable
(RJ45 M/M) - Blue
Highlights
Premium cabling for Category 5
and 5e applications—rated for
350 MHz/1 Gbps
communications
IEEE 802.3ab
PVC 4-pair stranded UTP
All cables feature boots with
integral strain-relief and RJ45
(Male) connectors
Retail packaging
MODEL NUMBER: N001-003-BL-R
System Requirements
For 1000Base-T (1Gbps
Ethernet), 10/100Base-T
(Ethernet), 100 Mbps TPDDI,
155 Mbps ATM, ISDN, voice
and Token Ring Type3
applications.
Package Includes
Description
Tripp Lite's 3-ft. blue snagless category 5e (Cat5e) patch cable has 2 snagless RJ45 molded male
connectors featuring integral strain relief. The cable is manufactured from PVC 4-pair stranded UTP and is
rated for 350MHz/1Gbps communication. All cables are offered in a variety of lengths and colors for all
category 5 (Cat5) and 5e cabling needs. Standard category 5e patch cables are also available. Tripp Lite
warrants this product to be free from defects in materials and workmanship for life. Clamshell retail
packaging.
Features
Cabling for category 5 (Cat5) and 5e (Cat5e) applications
Length: 3-ft. color: blue connectors: RJ45 male
Feature molded connectors with integral strain relief
Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off
during installation
Rated for 350MHz/ 1Gbps communication
Meets most current industry standards including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568,
ISO/IEC 11801 and ETL (category 5e draft 11)
Available in other colors and lengths
Also available without the snagless feature (N002 series)
Also available - Cat6 cables (N201 series)
Warranted to be free from defects in materials and workmanship for life.
Specifications
OVERVIEW
UPC Code
037332012449
1/2
3-ft. Blue Snagless Cat5e Patch
Cable
Cleveland, OH 44122
United States
PHYSICAL
Color
Blue
Cable Shielding
UTP
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
0.11 x 0.11 x 0.04
Shipping Dimensions (hwd / cm)
0.28 x 0.28 x 0.10
Shipping Weight (lbs.)
0.11
Shipping Weight (kg)
0.05
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“N001-003-BL-R”相匹配的价格&库存,您可以联系我们找货
