A
B
C
D
E
F
G
H
B.2; Validé
NOTES
8
MATERIALS
SHELL
COUPLING LATCH
O'RING
SEE TABLE
STAINLESS STEEL
LUBRICATED RED SILICON
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
DURABILITY
SEALING IN MATED CONDITIONS
7
SEALING IN UNMATED CONDITIONS
POLLUTION DEGREE
CORROSION SALT SPRAY
FLAMMABILITY
OUTDOOR SUITABILITY (UV RESIST)
SCOOP PROOF
WIRING FACE
ELECTRICAL
TOUCH PROOF
MATING FACE
28,1±0,5
11,3±0,4
POWER AND GROUND LINES:
NOMINAL CURRENT
15 0,5
IEC61984/UL1977
IEC61984
IEC60529
DIN40050
IEC60529
IEC61984
UL94
UL746C
8
-40°C TO 105°C
500 MATE / UNMATE CYCLES
IP68 1BAR DURING 1WEEK
IP69K
IP67 WITH CAPS
4
MIN 1000H
MATERIAL RATING: 5VA
MATERIAL RATING: (f1)
7
IEC60529
IP2X
UL1977
16A WITH AWG14 WIRE / 13A
WITH AWG16 WIRE
16A WITH 2.5MM² WIRE / 13A
WITH 1.5MM² WIRE AT 60°C
IEC61984
NOMINAL VOLTAGE
NOMINAL VOLTAGE
UL1977
IEC61984
IEC61984
600V
250VAC 4KV 4 FOR CLASS II
500VAC 6KV 4 FOR CLASS I
IEC61984
IEC61984
48V AC
5A
6
NOMINAL CURRENT
SIGNAL CONTAC (a,b,c) LINES:
NOMINAL VOLTAGE
NOMINAL CURRENT
6
ROHS COMPLIANT
23,5±0,5
15,5
1. COUNTERPART REFERENCE UTL RECEPTACLE OR FREE HANGING
2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT
3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16 AND #20 , R*M* OR S*M* TYPES
4. CONTACTS TO BE ORDERED SEPARETELY.
5. WARNING: PHASE AND SIGNAL CONTACTS ARE MALE VERSION
AND GROUND CONTACT IS FEMALE VERSION
6. UNIT IN MM
5
SHELL' S MATERIAL
UTL6102G1W3P
PA GF REINFORCED
BLACK COLOR
UTL6102G1W3P03
PA GF REINFORCED
LIGHT GREY COLOR
4
P/N
3
3
SHELL
P/N : SEE TABLE
x2 #16 POWER
MALE
CONTACTS
2
O'RING
B
06/03/2015
ISS
DATE
Designed by:
x1 #16 GROUND
FEMALE
CONTACT
TITLE
Scale
1/1
__
23869
_ Clearances dimensions modification
Latest modification - by:
RAGAINE M.
COUTY L.
Date:18/07/2013
1
FORMAT
A2
G
F
E
D
C
2
MOD N
CUSTOMER DRAWING
MALE PLUG LAYOUT 6 CONTACTS SIZE 10
UTL CONNECTOR
General linear
Tolerances:
0,2
WWW.SOURIAU.COM
H
4
x3 #20 MALE
SIGNAL
CONTACTS
LATCH
5
NPRDS / PROJECT
UTL
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SOURIAU DRG N°
UTL1-0049A-C01
B
CLASSIFICATION: NOT EXPORT CONTROLLED
SHEET
1/1
A
1
很抱歉,暂时无法提供与“UTL6102G1W3P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+151.378801+18.31972
- 10+131.1955910+15.87717
- 25+115.7586825+14.00901
- 50+103.5777550+12.53489
- 国内价格
- 4+132.64773
- 21+127.29629
